3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy and Light Skate Box Setup
Step 5Assembly Part 4
Assembly Part 4
Now the final step!
Depending where you purchase the metal bar it could be a different measurement on the side. The one we purchased from Home Depot was just about 2". Regardless, you should install the metal piece first and then measure the proper width for the masonite piece.
Important: make sure that you countersink all the holes for the metal bar (the ones on top and on the side) AND all holes in the masonite that border the metal bar. You want to make sure that the heads of the screws do not stick up above the surface. Nothing sucks more than having your board chipped away by screws.
"Important #2:" most metal bars have a bit of a curve on the inside corner and ours was no exception. We cut away the edge of the plywood facing that inside corner to allow the metal bar to sit perfectly flat and secure (see pic below).
2 comments
Oct 10, 2010. 5:38 PMsk8rforlife says:
Where did you drill the holes for the metal bar?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:nonoodlez(Find, Fix, Design, Make)
