3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy and cheap Oil Lantern
If you like to go camping or relax outdoors you know that flash lights can be boring and candlelight can be fun (or even romantic *wink*)
I made this simple and easy to do instructable so that you can use it outdoors, while camping, in your house, for power failures, or even just for fun. Enjoy : )
The thing I like about this is that it isn't easily blown out and you can carry it around and even hang it
If you make this or your own version I would like to see your pictures in the comments thanks...
Step 1What you need
What you need
*A small baby food glass jar (Gerber)
*A Medium sized Aluminum can (I used an evaporated milk can) that is not open
*A coat hanger
*100% Cotton rag
*Olive Oil
*JB Weld
*Scissors and other cutting tools (dremel...pliers...)
12 comments
Dec 19, 2011. 12:24 PM{Havoc}.Goliath says:
Im using canola oil and it smokes alot. Do any other oils work better?
Apr 22, 2012. 3:49 AMcowscankill says:
That just means the wick is sticking out too much. You either have to pull out less wick, or wait for the excess to burn away.
Aug 20, 2010. 1:44 PMTALLJ29 says:
Good idea, by the way i think thats a steal can. The only thin made out of aluminum now is soda cans. just thought i'd let you know
Apr 16, 2011. 4:46 PMTux0r says:
A)Its steel B) Those cans are actually made out a tin and steel mixture if I remember right.
Dec 2, 2010. 3:24 AMEarths_hope says:
Exellent.
Aug 14, 2010. 9:15 PMl8nite says:
Unique idea with epoxying the jar and can together. I usually just place the jar inside the can. Punching or drilling holes in a design around the can is another way to allow light out and can cast some neat effects on the surroundings
Nov 16, 2010. 6:17 PMblodefood says:
I'm not so sure about putting the jar inside the can. The heat build up might cause the oil and air inside to expand and put pressure on the lid resulting in a hotter, higher flame. You would use up the oil more quickly and I think it would be less safe. Besides, the constant heating and cooling of the vegetable oil may make it goopy, rendering the jar, the wick and the lid unusable. Again, not sure, but that's what I think would happen.
Nov 16, 2010. 6:10 PMblodefood says:
This kind of lamp could burn for a long time. Great choice of materials!
The only thing I would suggest is a more squat jar. Because vegetable oil, particularly olive oil is heavy, once the oil level goes below a certain point on the wick, it is hard to light because the oil can't get up the wick fast enough.
Aug 9, 2010. 5:06 PMbruc33ef says:
Excellent. Can't see any reason why this wouldn't work. It recycles common throw-away items into a useful appliance that should last years.
Aug 10, 2010. 6:10 PMrimar2000 says:
Sure, the used cooking oil is a good fuel. I use it to fire the BBQ coal.
Nov 16, 2010. 6:07 PMblodefood says:
You might try peanut oil. It burns a little more cleanly than olive oil.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:norbizzle12
I love music related things and anything high tech. Adventure is what I am all about.
