3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy build self balancing electric skateboard
Step 29Battery connections
Battery connections
I have used 2 simple 7AmpHour lead acid batteries in series to give 24V.
The main power switch is in the middle and essentially "joins them together."
Diagram below.
Again, make sure power leads go into the Sabertooth the correct way around.
2 comments
Nov 6, 2011. 6:06 AMh3x_your_nightmare says:
i think you can use a relay instead of that switch :D good luck
Jul 7, 2011. 3:14 PManiles jr says:
is this battary good?
http://www.apexbattery.com/dts-12v-6-7-amp---no-leads-battery-sealed-lead-acid-batteries-dts-batteries.html
thanks
adrian
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
127
Author:XenonJohn
