3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy camper van conversion
The biggest problem with converting your van into a sleeping machine is that you forfeit the ability to carry transmissions, beds, shopping trolleys, bits of lumber, and/or cattle, sometimes all at once. This is an easy removable sleeping platform. Simple!
Step 1The only step!
The only step!
Get four milk crates, and a piece of 18mm ply to fit the van. Remember - it must accommodate the inside diameter of the van door, or: make sure you cut it small enough to fit through the door!
You don't want it to cover the entire area, because that makes it hard to get in and out.
Then, place crates strategically and place board on top. I fill the crates with bottles of water (essential for my van which doubles as a high performance spa pool at times), tools, the jack, coolant, (as above) and other extraneous crap. This will weight them down a bit more too, as the entire arrangement does tend to leap into the rear view mirror when navigating potholes. However, once you pack the rest of your crap - surfboards and kiting gear and three square meters of sand - under the platform, they will move around less.
Step three - enjoy!
21 comments
Jun 22, 2010. 8:55 PMeyerobot says:
I dont have much trouble giving up the ability to carry cattle in my minivan. The only real problem I see, Is that I dont know of a single place where I would be allowed to sleep in my van. Unless I wanted to pay fifteen dollars a day camping fee. Or I could just pay the vagrancy fines, Which are probably cheaper.
Apr 3, 2012. 10:45 PMThaikarl says:
where do you live that has vagrancy fines? i've lived in a van for 5 years. being quiet and stealthy is key. industrial areas are usually good. walmart allows overnights. if you have a black curtain across behind the seats, and tinted windows or black curtains that are closed, you simply pull up to a spot, quickly climb in back and go to sleep. no one notices you, it's just a parked van.  don't park in front of somebodies house, even in the city.  although the streets are public, people expect to park in front of their houses.  do your teeth brushing, sorting out your gear somewhere else, then drive to your sleeping spot and sleep. move around so you aren't noticed as always parking in the same place. i cut my plywood into two long boards - easier to get in and out and put aside. i use same size storage bins to float the bed on. you can easily slide out one from the sides or back of the van to get to your stuff.
May 20, 2011. 8:14 AMgorgo333 says:
Walmart parking lots.
Aug 25, 2011. 2:53 PMjblanton1 says:
See if you can get some REAL milk crates, not the ones that they sell in stores for storage of folders and such. The REAL ones are seriously more sturdy than the imitation ones.
Jan 14, 2011. 8:53 AMoravlalainez says:
this seems to be too much work for something that would be done by just putting the mattress on the floor.. please what is the point of this... to waist your time
Jul 30, 2011. 4:04 PMcoastrider says:
easier to just put a single bed into van & secure to seat tiedowns to limit movement
May 20, 2011. 11:49 AMshadowofblood says:
The problem with putting the mattress on the floor is you end up sacrificing floor space. The crates supporting the mattress provide a storage area for small items, while the space under the mattress provides a storage area for larger items. This way you can have your stuff and your mattress both in the back.
Mar 2, 2008. 2:56 AMNoodle93 says:
Only problem is, I'd roll of the bed and break who knows what bone in my body.
Oct 28, 2009. 9:04 PMRichie15 says:
You're not supposed to sleep in it while you're driving the feckin thing!
Oct 14, 2009. 5:13 AMqwertzui says:
I will be realistic in my comments. I think its a silly conversion.
best way:
Use marine Plywood. Light weight.  I have convereted a fewdifferent vans.  use simple L brackets.
If fitting dual battery systems , use redarc isolater, and AGMbatteries. with 16mm wiring. and earth back to battery.
Use led lighting.
Have fun.
Oct 14, 2009. 5:15 AMqwertzui says:
BTW  with the marine Plywood you build a box system , that is lightweight and removable.
Sep 2, 2009. 11:27 AMrambler23 says:
check this conversion out, it has free downloadable plans too: myminicamper.com
Aug 13, 2009. 6:59 AMmisterquigley says:
This was inspiration for my van conversion - I used ratchet straps with flat strapping attached to the tie-down points and over the ply to stop it all bouncing when negotiating potholes.
Jul 28, 2009. 12:01 AMPikesPeak says:
Made one similar for my Ranger Longbed with topper. Used 2x4's for underwood frame support, and put heavyduty sheet of wood on top. Purchased replacement couch foam on Ebay, and sleep like a baby everytime I use it.
Jun 5, 2009. 5:28 AMtehomet says:
Excellent idea. Simple but effective!
Feb 26, 2008. 6:54 PMlebowski says:
That's a pretty good trick. I had a toyota van back in the days for all my windsurfing gear. I always needed all the space I could get under the bed for the sails.
May 7, 2009. 6:01 AMehmbee says:
NIce 'ible-if you are me, however, you'll need a fifth crate under your midsection somewhere or the whole works is caving in-but that's me, I'm a healthy, husky dude. I think if you tried to turn the crates on their side you'll lose the structural strength-they were designed to be stacked vertically.
Aug 5, 2008. 2:12 AMzzzxtreme says:
plastic crate as support, great idea. i'll be using them for my room
Jul 26, 2008. 11:18 PMabadfart says:
im going to do this with my 15 seater van and a full sized mattress then im going to leave 1 seats room in front and put a tv and stereo then blackout curtains
Jun 18, 2008. 9:37 PMbubblewrap74 says:
I would probably flip the boxes around sideways so you can store stuff in them more easily. Otherwise looks great. Too bad I don't have a van.
Jun 9, 2008. 10:34 PMcarpespasm says:
You'd do well to drill out some holes you can attach the plywood to the crates with bungee straps or something so it holds together better and maybe something to hold the mattress down too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kinawera
There's not much to say, I am mostly hair.
