loading
Step 12: Winamp Desktops using Irfanview
A few more desktops I did real fast just to have some more examples.
For what it is work, all of the pics used in this were done via the ctrl + print screen and then cropped up with Irfanview. The hardest part of doing all this way actually doing the Instructable.
Post a message if you like this! Post two messages if you don't like this. Post no messages if you just don't care (then hands up in the air).
Cool instructible, original idea. Check out more cool customisation programs <a href="http://www.instructables.com/id/5-FREE-Programs-to-make-your-computer-slightly-e/">here </a>
Why does every one think that it's ctrl+print screen? Just print screen works for me!
Sweet! great Idea!
I use Itunes instead of WinAmp
winamp, bad, jetaudio, good
AIMP2 best media playa ever! low ram usage, great look. :D
that media player looks sweet, ever the classic looks good
You could also use <a rel="nofollow" href="http://www.apophysis.org/">this program</a> to generate cool background pictures.<br/>
good idea, thanks!
Awesome.... its a basic idea, but thanks for hooking me up with the programs, and also, if i were to try it myself, it would have taken longer to figure out, .... but your instructions work, and now i have a kool desktop check it out....
There used to be a Geiss knockoff, I can't remember what it was called, but it had a feature on it where you could set is the background on your active desktop. buggy as hell and ate resources, but it was def. cool.
The thing you speak of is called Dremples. <br/><br/><a rel="nofollow" href="http://www.geisswerks.com/drempels/">http://www.geisswerks.com/drempels/</a><br/><br/>And it also just happens to have been made by Geiss, who also made MilkDrop, I think.<br/>
Great instructable!<br/><br/>As your screenshot on slide 8 shows, it's 16BPP or 32 BPP (not BBP). If I'm not mistaken, it stands for Bit Per Pixel. It is what Windows refers to as &quot;Color Quality&quot; (and what some people like myself refer to as &quot;Color Depth&quot;) in the Display Properties Settings. You can match what appears in the display settings for better quality (for what good that actually means, read further)<br/><br/>However, remember that an image with higher color quality will take more space on your drive and will likely take slightly longer to load even though your might not see the difference with recent computers.<br/><br/>Color depth is directly related to the number of different colors/shades a pixel can take:<br/>16 bits: ~65,000 (actually 2<sup>16\)</sup><br/>24 bits: ~16,000,000 (actually 2<sup>24\)</sup><br/>32 bits: ~4,000,000,000 (actually 2<sup>32\)</sup><br/>Note that the human eye can distinguish a few million colors. 24 bits color depth is way enough for perfect image quility but for some reason, that setting disappeared from most computers so I recommend sticking to 32 bits for quality or 16 bits for performance.<br/><br/>As for the tools you really need, JustBurn is right. You only need winamp and ms-paint. But here is a trick to improve his tricks ;-) : If you're using windows 98 and up, save the image in JPG format, it'll save you a lot of space, especialy if you plan to make several different wallpapers. Moreover if the image size is not exactly the same, it's not a problem as long as it is smaller. Windows can stretch the background image to fit your screen resolution, just choose stretch instead of centered when you select the wallpaper.<br/>
You actually only need Winamp, no need to download and install Infanview just to create a wallpaper once. When you press PRINT SCREEN (CTRL+PRINT SCREEN only copy portion of screen that application is using, since is full screen, it works too!), the entire screen is stored in the clipboard... Fire up the MS-Paint and press CTRL+V (or go to menu and select "Edit" -> "Paste"), now go to menu and select "Image" -> "Attributes..." and make sure it's exactly the same size as your resolution... then "OK" and back to menu and select "File" -> "Save as..." and store it into your Windows directory in BMP format... On desktop right-click and "Properties", in "Desktop" tab find your BMP file in the list. Hope that's clear enough!
or you could use the "new" winamp 5 MilkDrop visualiser witch can be displayed full screen like your background... (may need a good GPU :D)
For active desktop, you could get an animation ready, and put that on a html page, and try that. I haven't used Microsoft Operating Systems for several months now, so i really don't know if that would work. But nice desktops.
Now, if there was a way to take the visualization and turn it into an active desktop, THAT would be cool! (So that it would still change, not just be a frozen picture)
my hands are in the air (but i only posted one message.....i'm so conflicted)
cool idea :P my desktop classifies as boring... but I typically have the terminal, eclipse or a browser full screen :P
About This Instructable
8,435views
8favorites
License:
Bio: Do you really care?
More by pencilneck:Firewood storage rack from a pallets... super simple Padded reclining headboard Hand Truck to Cheap portable computer stand (station)
Add instructable to:
