3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy glass engraving with the Cricut
Create your own engraved beer mug! (or give a great personalized present)
We'll be taking a dollar store beer mug and turning it into something much nicer - just in time to celebrate the New Year!
Although I'll be using a Cricut vinyl cutter to make a stencil for your name, you can do this without a Cricut by various other tracing methods, and cutting the vinyl with an exacto knife.  (So the choice is - use the right equipment, and it's an easy project; or do it the cheap way and it'll exercise your artistic talents a lot more!)  If you don't have a Cricut, either this Instructable or this one will show you how to skip that step.  And of course a lucky few with a laser engraver could use that instead.
Now let's get started...
Step 1Here's what you'll need
Here\
Cricut or other vinyl cutter (and computer) - or x-acto knife and superlative skill!
Vinyl (eg Contact Paper(tm))
Scissors and/or paper trimmer
Armour Etch(tm) glass etching cream, and small paintbrush
Beer mug (smooth sided)
SAFETY GOGGLES and nitrile gloves
Outdoor work area and garden hose
The safety googles are essential. The etchant we'll be using is based on hydroflouric acid and will seriously mess you up if you get it in your eyes. You might also consider nitrile gloves. This is NOT A PROJECT FOR CHILDREN. Keep the etchant well out of reach.
Pick a beer mug with smooth sides. We'll be sticking your name on the side in vinyl so you can imagine how difficult that would be with a dimpled mug. My local dollar store does great mugs - which you can afford to trash if you mess them up. (Although I'm pleased to say my first attempt came out just great)
Remember that stores like Michaels and Hobby Lobby often do a "one item at 40% off" coupon, so use it to buy the Armour Etch!
Finally, for what we're doing, run-of-the-mill contact paper is just as good as the expensive custom-sized flat sheets sold by Cricut.
32 comments
Jan 19, 2012. 11:42 PM55fanatic says:
Thank you so much for sharing!! The pics & descriptions are very easy to follow!!! :)
Dec 27, 2011. 11:23 AMwmkcross says:
Make The Cut' software is apparently no longer compatible with Cricut machines according to the Make The Cut' software web site
Mar 1, 2011. 5:00 AMseabeepirate says:
Hey I just wanted to share a pic from my own project. I used Armour Etch, A dollar store mug just like yours and Avery self adhesive laminating sheets(for the stencil). Thanks for the instructable, I've been having a lot of fun making custom mugs!
May 28, 2011. 8:50 AMpmowers says:
I had not thought of using contact paper, it seems that it is a lot cheaper, and may mold to the shapes better- Thanks for the tip.
Regarding the transfer paper, you might be able to get a couple of pieces from a local sign maker- as scrap or partial roll.
The transfer paper is very similar to a very wide masking tape, the adhesive is not nearly as strong as the vinyl adhesive. you basically cut out your design on vinyl, remove the portions that you want to etch, this is referred to as "weeding", then smooth a piece of transfer tape over the image. When you gently peel off the transfer tape, the vinyl will come off with it, holding all of the little pieces in place.
You then just position the transfer where you want it, rub it down with either a stiff squeegee or a tongue depressor to adhere the vinyl, then gently peel off the transfer tape, leaving the stencil on the glass, ready to etch.
Nov 18, 2011. 4:14 PMcj8675 says:
i run a sign shop and can mail scrap to u.
Nov 19, 2011. 12:52 PMcj8675 says:
i have a 40 inch graphtec vinyl plotter
Mar 1, 2011. 11:29 AMseabeepirate says:
The suits and values were actually the easy part, it was the shapes of the cards that I actually had trouble with. I understand what you're asking though. I actually made a stencil that I taped over my laminating sheets, then I was able to stick the laminating sheets onto the mug with the stencil on the outside where I could still work with it. I cut out the shapes of the cards and then peeled away the design.
It wasn't a perfect method though because as I cut out one card the others would become loose. If you look carefully you can see that my lines aren't all very straight. Because I was manually holding the stencil in place as the edges got loose sometimes the stencil would slide a little bit. I was able to trim up the crooked lines for the most part after I pulled the stencil away, but it still wasn't perfect.
For smaller designs I suppose I could have used printable labels, but those don't help much on a larger project. I'm still trying to figure out a way, if you think of something be sure to post it, and I'll do the same :)
May 26, 2011. 6:15 AMEinarjon says:
Just a thought:
How would it work to leave some gaps in the letters that have a hole (1 mm "spacers") to keep the cutouts in place and then cut them off with an x-acto knife before applying the etchant?
Jan 29, 2011. 7:48 AMlabratmikey says:
Theres a software called Sure Cuts A Lot 2 and it completely eliminates the need for any other cartridges. You only need the one it came with. So because of that, I jacked my girlfriends new cricut.lol
Jan 20, 2011. 6:52 PMartsman23 says:
Hey, great tutorial. I thought about giving the cricut a try but then decent to just get a larger vinyl cutter. You can see it in the new video I made on here: http://www.instructables.com/id/Glass-Etching-with-Sandblasting-and-Acid-Cream/
Please check it out and leave me a comment. Thanks -Eric
Jan 12, 2011. 8:36 AMrecrisp says:
Good instructable! :) I just wanted to point out that with a Cricut, a machine designed to also take your money in a LOT of ways, you can help remedy that too... On YouTube you can watch this video that shows how to avoid the high prices of the font cartridges, (I don't have a Cricut, but I do have a CraftRobo Pro, which does all of the above, I just happened across this one day) http://www.youtube.com/watch?v=QH2flUV2s2Q
I hope the link works out, if not, just type in 'cricut cartridge', it'll be on the first page.
Jan 10, 2011. 1:34 PMSteuben Glass says:
W00T!!!
Thank you for the awesome walk-through.
I didn't think there was a way to accomplish etching w/out having access to some far more expensive equipment.
Jan 4, 2011. 12:02 PMjnifrwebb says:
Great idea, I got a cricut for Christmas and have been looking for things to do with it. And I have everything I need already!
Jan 4, 2011. 1:18 AMadrian09 says:
is it still poisonous after washing?
Jan 3, 2011. 8:08 PMRonyon says:
Love this, I will try it on the backs of plates, everyone in the family will get one with their name...If yours isn't clean, you don't eat!
Jan 3, 2011. 1:01 AMricharno says:
Nice trick!
Jan 2, 2011. 8:46 PMDuhDuhDave says:
This is great work. The cricut looks like a great product to me, and I have always been sorry it was so cartridge based. And this is brilliant.
HF is nasty stuff. It is pricey, but you might consider keeping a tube of calcium gluconate gel around. Fluoride ion can go right for the Ca in your bones, and deposit it in your bloodstream as crystals. Painful, and often fatal. I don't think small quantities like this are likely to kill you, but who needs to worry- the gluconate gel calcium binds the fluoride. When I worked in an analytical lab digesting rocks (!) with HF, we had a tube handy. I was sufficiently paranoid that I never had a mishap, but I was glad it was there.
Jan 2, 2011. 8:30 PMBlardo says:
My roommates and I did this with drawer contact paper instead of vinyl. I think you chose better.
Jan 2, 2011. 1:35 PMsonicdrive says:
good work dude very nice
Jan 1, 2011. 10:35 AMyokozuna says:
Excellent instructable, you should also enter this into the Holiday Gifts contest.
Jan 1, 2011. 3:26 AMlemonie says:
Yes very sensible.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:gtoal
