This is a CHEAP version of my first Instructable
If you need to get a BIG stove going right now, this is the one.
Video of stove operation at end of Instructable.
Read and BUILD!
Remove these ads by
Signing UpStep 1Tools and materials
- Tin snips
- Sharp chisel and hammer
- Corded or cordless drill or screwdriver
- Optional hacksaw
- Optional Dremel with fiberglass cutting wheel
Materials:
- Large tin can. 10 inches wide, 11 inches tall (roughly)
- Smaller can about 8 inches wide. #10 food can type
- Computer style fan. (80 or 92 mm)
- 1/8" diameter metal tubing (flux brush, golf club tubing, small copper tubing from old fridge?)
- 2 1/2 inch deck or drywall screws. Any long screws will do.
The large tin can might be a popcorn or cookie tin. It can be a 5 gallon kerosene or hydraulic fluid container. It could be a metal paint pail with lid that seals. The container has to have a flat top and be completely intact.
The inner burn pot can be made from a #10 food can, or 2 stainless steam table pots (bain marie).
I use the inner pots from my other instructable in this one. Look there for more info.
The single wall burn pot will work fine. It will radiate enough heat to melt your computer fan though.
The fan pictured below melted in this close configuration.
Cut the top hole in the outer can with a sharp chisel and hammer. Or use the chisel and hammer to get a hole started, then use tin snips to finish the top hole. Take your time and make the top hole PERFECT. The #10 food can/inner burn pot must fit TIGHT. This allows the gasifier to work best without needing weird exotic sealants you have no access to.
Next step will show how to make a basic duct to keep the fan a small distance away.
All this instructable shows is how to make a fan duct and gasifier if you have barely any tools and supplies.
A tube would work just fine for a plain computer fan. I built square ducts out of metal 2x4 wall studs for a few of these stoves.
Hair dryer is out because you can only use it near a house. It's too much air also, fire will burn really hot and die out fast.
I'll get my old gasifier out and try to do this idea, will then add the pics to this instructible.
They have CPU fans in the 3D warehouse I bet.
My duct was similar, I made a rectangle box and had the fan blow down then do a right turn. I didn't have any tubes available.
Did you check out my other Instructible? The silver gasifier? No tubes needed. Part of the reason I did the better stove.
Here is what I'm thinking of. Just drew it in Sketchup.
http://sketchup.google.com/3dwarehouse/details?mid=ebd00cc74bd9486a155fd428fcb8c5ea
Take a very close look at that pic. You will see the gap between the fan and the plate with tabs cut.
You can also take put the tabs inside the pipe. Screw small sheet metal screws from the outside of pipe inwards (into the tabs). This would create better air sealing. Or just use high temp RTV on it all. Whatever ya got.
If you have a powerful enough fan it won't matter. If the fan is wimpy it won't allow a big gasifier like this to work right. You have to get the right fan power for your enclosure to get the correct burn rate. In a smaller gasifier, any old computer fan would work perfect.
Thanks for the inspiration. I'll work on the fan tube drawing some more showing how to attach tube to gasifier body.
You can take the drawing and run with it too. Learn Sketchup. I've been using Sketchup for 3 weeks now and the drawing still took me 2 hours. Takes a while when you are thinking out concepts as you go. It's easier to make things in real life. But...without documenting things for other people...it's all a waste of time. Hence the Instructables website ;)
Could you explain the benefits/detriments and or purpose of each configuration?
The pictures with the small holes depict a completely different double wall burn pot. This pot is detailed in my other instructable.
It's basically a large stainless pot with another smaller pot that fits inside.
The smaller holes on the top and bottom of this setup create a very different (and better) burn.
I used the pot assembly from the better stove just to illustrate how well it works with different fans.
You use what you have on hand to create one of these stoves.
Build the simple one, then get some money together and build the better one later.
I like lamp oil also. Clean burning, and it soaks into the pellets quickly.
Heet would be cheap and easy to get anywhere. I'll try that tomorrow.
Going to do another startup video with my final gasifier.
Make sure you look at my other video. It shows the construction of the double wall burn pot.
I'm going to make a smaller double wall pot gasifier soon. This one is way too hot for most jobs. You can stay warm at night standing around it for sure.
I'm going to design a heat exchanger to go over it to do small scale hydronic heating. That is where this design is heading.
