Introduction: Easy Made Brain Teaser Puzzle
Picture of Easy Made Brain Teaser Puzzle
This game was given to me by my father 40 years ago. It took a little while to figure out then, I was young. Recently after being found after many years of hiding I discovered it was still a fun challenge. The object of the game is to get the nut on the b side of the toy to the a side of the toy. The nut does not fit through the center hole. I've challenged many adult friends to take the test and they failed. I wish, I could hide the answer until you were finished making it.
Step 1: Layout
Picture of Layout
Draw out the pattern on whatever you decide to use as a base. I chose a thin wood crate top just because it would be easy to cut with a carpenters knife and drill with a cordless drill. You could easily use cardboard, aluminum or plastic.
Step 2: The Knot
Picture of The Knot
Cut about 2.5 feet of the cord you have decided to use. Fold your cord in half and poke it through the center hole. Pull it through a couple of inches and then put the ends of the cord through the loop. You can now take both ends of your cord and push them through the front of your 1/4 side holes and tie then in a knot. Don't forget to put the nut on one end before tying it off. Now cut the excess cord off the ends.
Step 3: The Solution
Picture of The Solution
The Solution: Pull the nut up close to the hole. Notice the two cords coming out of the center hole.
Step 4:
Picture of
grab the two cords mentioned earlier and pull them through the hole. Keep pulling until it pulls the loops through from the other side. Now you have 4 cords coming out of the middle hole. Now, look at the loop protruding out of the middle hole. Run the nut through this loop and to the other side.
Step 5:
Picture of
Turn the puzzle over and repeat the process. Pull on all 4 cords all the way through until the knot on the other side comes back through. Pass the nut through the loop again.
Step 6:
Picture of
Pull down on the cords and straighten the puzzle up. There you have it. Don't be disappointed if it takes you a while to figure it out. It's not as easy as it looks. Have fun
original "How to" posted on usenet articles
Bban (author)2015-04-12
Nice. The solution was slightly confusing, can you post a video of solution? Thx.
Libahunt (author)2012-06-10
Cool. I tried this out with cardboard and solved without instructions. Now I have to make a sturdier and nicer one to keep somewhere around.
grggfks (author)Libahunt2012-06-12
Alright man, glad it worked out. I don't know who invented this thing but, mine is 40 years old. Just a neat toy...thanks
article directory-DIY
About This Instructable
18,881views
17favorites
License:
More by grggfks:Close up photography using macro tubesEasy made brain teaser puzzle
Add instructable to:
