3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy sauerkraut
Easy sauerkraut
  • last photo ←
Sauerkraut made at home has live probiotics for your GI tract health, good source of Vitamin C (or why Viking raiders didn't get scurvy on long sea journeys, despite having no citrus), has no nasty phthalates or BPA from can liners because it isn't canned, and is very economical. If people knew how easy it is to make, no one would ever buy it. So here goes!
Step 1Tools and materials
Tools and materials
You will need:
- fresh cabbage,
- a way to shred it finely
(a food processor, or a hand-crank cone shredder of good quality, are both easy and quick), - salt
[so far as I can tell, it doesn't much matter what kind you use. That's a personal taste issue. It all makes kraut, because the purpose is allow fermentation by lactic acid-producing bacteria rather than spoilage by other bacteria, and all salt will do this]
The proportion of salt to cabbage I follow is roughly
3 TBSP salt to every 5 lbs cabbage.
I know that Kosher salt will measure differently than standard table salt, but Kraut is so forgiving, it really doesn't seem to matter. Let taste be your guide, and use less than the full amount, then taste, and add the rest if it seems desirable.
and
-a place to store it.
I use a glass gallon pickle jar, and it holds 4-5 heads of cabbage. Others may use a food-grade plastic bucket (but is there *really* such a thing as a food-safe plastic? Inquiring minds wander...er, wonder.) or if you are lucky, you have a stoneware or wooden crock specially made for pickling and fermenting. You will need something to weight the kraut down with, but more on that later.
It needs to be at a cool temperature, ideally in the 60-degree range, but can tolerate anything except "wam" and "cold" at which point, it will either spoil because it's warm enough that other microbes take over, or it will cease fermenting properly because it's too cold. That's why kraut was traditionally made in the fall. I keep my jar in the northeast corner of the basement. If you are unsure of the temperature you are keeping it at, a cheap weather thermometer helps. Just set it by the jar. Over about 75 or under about 60 degrees F may yield poor results.
53 comments
1-40 of 53next »
Oct 17, 2009. 2:50 AMtonygoffe says:
Hi, I love sauerkraut ..from my days at junior college in Miami in the 60's..  but  living in Jamaica, where the temp is never below 70 F in the house, so by what you say, it would NEVER ferment??  .. the fridge runs at least 35-40 F, so, THAT's too cold ? Any suggestions?     Oh, let me say that this is the MOST useful site I have come across, bar none !    This is particularly for those living in the developing countries where one often has to "make do"   tonyJamaica
Apr 29, 2012. 2:31 PMTigertame4 says:
maybe an ice chest? You could put jars of cool water in to keep it the correct temp.
Apr 1, 2010. 9:46 PMhenryinpanama says:
I make sauerkraut and kimchee all the time here in Panama. The only effect of the higher temperature is that the kraut makes quicker. Go for it.
Henry
Nov 6, 2009. 11:05 AMdrawe21 says:
Dig a hole 2 or 3 feet down in the sand/dirt.  The temp will be 50 to 60 deg F. (Think Kimchi)
Apr 2, 2010. 5:53 AMhenryinpanama says:
I have been making sauerkraut and kimchee for years at 80+ degrees with never a problem. Sauerkraut makes in about a week at that temperature.
Sep 5, 2011. 6:02 AMoffseid says:
Just finishing my first batch (6 days now, will wait one or two more) in the tropics of Malaysia. I've kept the kraut in the back of a kitchen cabinet. And it tastes fantastic! So I can vouch for what Henry says. Thanks for a great Instructable.
Oct 30, 2011. 1:43 PMQuester55 says:
If you really want an extra treat, at the start, add Fresh Onions {Whole} & or Cucumbers {Pickles} At the top, As well as extra water to cover all. This is best when using Crocks of 3 Gal. or larger Mom's was a whom-ping 20 Gal. size, Purchased at an old cannery. In some cases, Whiskey or Wine barrows could work.
Oct 30, 2011. 1:32 PMQuester55 says:
If using a Crock, My mom had a Wood Disk Cut 2'' Thick from a Fresh Black Oak Log about 1 1/2 " smaller than the opening of the Crock to keep our Burlap covering & the cabbage in place. The wood was Air Cured & dried before use.
Oct 30, 2011. 1:21 PMQuester55 says:
Whenever we made Sauerkraut mom would get out a wooden slide cutter made for that purpose. These were large slicers but better to use than those Cheep plastic versions Ronco sold. The blades were made with Demaskus steel ? [Spelling maybe off] & needed to be washed & dried carefully for storage, but would retain a cutting edge better than most blades today. Just enter Cabbage Cutters on search & you'll find all kinds. Note, Cheaper isn't always better. as for Crocks, Check out your local Farm Supply Stores, Even your local Co-Ops Can get you one. Mine is rated at 3 Gal. is over 1 inch thick & has lasted me more than 20 years.
Jun 3, 2011. 11:42 AMAR10NZ says:
As a kraut / kimchee fan, my wife & I made about 1 1/2 gallons of kimchee 3 weeks ago. A neighbour came over, acted as official weigher of salt, finished off the last of last years kimchee ( still finely preserved in the fridge). She pronounced it " Yummy ! " We make it in the autumn, with Jereusalem artichokes, chokos, apples, garlic, onion, green onion, ginger, chillies, and nettles. We ferment in large glass jars, placed in buckets, in hot water closet. Jars are " semi sealed " with a plastic bag filled with water, which allows the CO2 produced to force some of the liquid out, to be retained in said bucket. Start to finish is short. Cheers, AR10NZ.
Jan 25, 2010. 6:54 AM{tauney} says:
Slicing by hand isn't that bad, so long as you have a sharp knife. I did two heads in under five minutes. Of course, I also cook for a living.
Feb 18, 2010. 11:53 PMlubinka says:
cheater!!!!!!!!!!!
but honestly, if you use cabbage for your salads, it IS an easy task :-)
Oct 13, 2009. 4:28 PMWanderingOak says:
My Grandfather's parents were from the old country. Their traditional family recipe involved mixing shredded apples (peeled and cored) in with the Kraut. I have a spare brew-bucket, so I need to try this sometime. I would think an airlock would be useful, as pressure builds up. I'm surprised your glass jar didn't shatter, unless the lid was less than finger-tight.
Jan 2, 2010. 10:49 PMCalis says:
I think I may try this.  I will want a tight lid though to ensure no pests get in, so I will probably drill the lid and insert an airlock from my wine making supplies.
Nov 9, 2009. 7:57 AMtonygoffe says:
Drawe21, and Megmaine,  not close to sand(the coast) but will do the soil thing)   ...I know this is not a social-networking site, but .."Hi, "Megmaine",.. ( is that Meg from Maine )...looks like you've visited my home.. yes, we do grow cabbages here, and blueberries up in the 5-7000 ft Blue Mts. I, however, only  live at 2200ft up in the central hills, and used to process smoked marlin with a clod-smoke process. ( about to re-start with chicken and pork)...  At present, I "mine" and process local agates and jasper..  I'm thinking of doing a recipe, for here, but most of the ingredients are difficult to obtain in Maine (??)  Do you have an instructable on how to write an auto-biography ? I had a "sad-happy-life-changing-all-about-a-girl-and-international-travel" experience in the late 70's, ...as time flies, the LESS serious it seems, retrospectively..some parts now REALLY hiarious! ( Youth wasted on the Young??  Oh yeah! )   Recipes..  Pimento Liquer, Mango Chutney, guava jams..etc any enquiries abt Ja. history, fruits, cooking traditions, etc..  I'll try and answer tony@peeniwalli.com  (..Its OK, I have a Great anti-spam device my nephew in Wyoming set up for me..)  One Love from Ja.          p.s. INSTRUCTABLES IS AN amazing SITE..Pls continue....
Oct 13, 2009. 4:39 PMkrissi says:
I enjoyed reading your insrtuctions on how to make homemade sauerkraut !I have been making sauekraut for yrs and will never buy sauerkraut again in the stores. It is so much less salty and you just can't beat the great taste of it! What we do is use 5 gallon pails to store the sauerkraut while it is fermenting. We use a large wooden shredder with a blade to slice the cabbage into smaller pieces. Then put that into the pail and we have a wooden stomper that we use to stomp down the cabbage adding pickling salt into  the layers of cabbage. About 2 tablespoons on each layer.When the pail is 3/4 full I cover it with cabbage leaves, add a plate on top of that ,then filled a empty milk jug filled with water to lay that on the plate. Now everything is weighed down. I ferment the kraut for 3- 6 wks checking it everyday. Also I check and scoop off any foam each day until ready. When it is ready we put the kraut in freezer bags and we freeze it.
Krissi
Oct 1, 2009. 7:27 AMJettaKnight says:
Kosher salt doesn't dissolve well in cold water. Pickling or canning salt is a wise choice for this. The salt concentration is key for creating the right "envrionment" that is inhospitable for nasty bacteria.
Here's an equation that ilustrates
9T of Morton Kosher Salt = 8T Morton Canning & Pickling Salt
Oct 1, 2009. 7:28 AMJettaKnight says:
Clean your hands thoroughly to avoid introducing anything nasty at this stage.
Jul 29, 2009. 4:05 PMmeowmeowcatcat says:
I've never tried sauerkraut before, but I love kimchi! Does kimchi have the same taste as sauerkraut, save for the spiciness?
Jul 27, 2009. 6:09 PMYerboogieman says:
I like to eat sauerkraut plain from the jar. Kinda like spam.
Jul 28, 2009. 11:09 AMYerboogieman says:
It's really good on Ruben sandwiches with thousand island dressing.
Jul 19, 2009. 10:04 AMHvysteel says:
I've always wanted to do this but just haven't made the time yet. One question, how long does this keep?
Apr 5, 2009. 5:33 AMshouldhavezagged says:
The BBD reference in the title of step 5 cracked me up! :-) I'm favoriting this. Someone was selling fermented sauerkraut @ our local green market and charging $8 for a quart jar.
Jul 18, 2009. 10:59 AMcerene says:
Now I was thinking Cypress Hill.... :)
Jul 20, 2009. 2:23 PMshouldhavezagged says:
Jul 20, 2009. 3:28 PMcerene says:
*Forehead Smack* I knew that!
But what popped into my head was Cypress Hill's Hits From The Bong. "Pick it, Pack it, fire it up...it kinda has the same cadence.
We must both be old. :)
Jul 20, 2009. 8:43 AMCycrolus says:
Awesome I need to try this.
Jul 17, 2009. 7:01 PMMadBricoleur says:
Mmmm... Mmmmm... Goodd... looks tasty! I want to try this. :D Does it taste like commercial sauerkraut?
Very detailed 'ible. 5* and FAVED!
Jul 18, 2009. 6:21 PMLintballoon says:
I got Sandor's book too, and tried kraut with it. It was so easy, and sooooo good! You can make "Preserved Lemons" in a very similar way, by quartering lemons and salting them. I did those in the fridge and in about 3 weeks they turned into gooey, salty, yummy lemon great for use in cooking.
Jul 18, 2009. 11:06 AMsheepishlion says:
A pic of my sauerkraut. 1 purple cabbage, 2 green cabbage and about 5 lb of carrots. Great Instructable.
Jul 18, 2009. 12:43 PMthepelton says:
I've made coleslaw with purple cabbage and the Cuisinart I inherited from my Mom. Never thought of SauerKraut, but I may have to try. I wonder what Jicama would be like in it?
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
76
Author:megmaine
Trying to live consciously in an age of media hypnosis, bringing up non-school-going kids who look like the Postman. (It's ok, I'm happily married to him!)
