Easy Steampunk Coat Hooks
936
48
5
Published
Introduction: Easy Steampunk Coat Hooks
Full set of ingredients for a set of five coat hooks:
  • 5 x back plate elbow joints for 15mm pipes.
  • A standard piece of 15mm copper pipe.
  • Pipe cutter for 15mm pipes.
  • 5 x 90deg elbow joints 15mm - I used push fit ones.
  • 5 x end caps 15mm - I used push fit ones.
  • 5 x couplings 15mm - also used push fit ones.
  • Copper paint.
  • Dark silver metallic paint.
  • Clear spray varnish (optional).
First cut 10 small pieces of pipes, I like to have them slightly different lengths so they don't look too uniform.
The pipe cutter is very easy to use and I cut them all in a matter of minutes.
I then sprayed the back plates using the copper paint but I left the copper parts as they are.
I then sprayed the cut pipes with the dark silver paint.
This is optional but I sprayed a layer of clear varnish just to protect the paint.
Then just assembled them together and screwed onto my wall. SIMPLE!
    • Casting Contest
      Casting Contest
    • Stick It! Contest
      Stick It! Contest
    5 Comments
    Thank you very much!
    Thanks, yea, first post, need to figure out how to post step by steps as well :)
    Lucky for you, there's a good 'ible that might help:
    https://www.instructables.com/id/How-to-Make-an-Instructable-Using-the-New-Editor/
    This looks awesome! You should put the finished picture first so everyone knows what you are showing us how to make :)
