Easy system to irrigate tomatoes by torx
Penso Che NEL this Caso di Pubblicazione e di Più Che Una Presentazione instructable delle Nazioni Unite. Interessante sembra altrettanto per la 'implementazione di facilitatore e di Che io posso vedere TUTTI I Giorni.
Step 1: Why
This is actually meet two different needs that now will explain:
1) the first need is to achieve through the watering the land concerned roots minimizing waste.
(2) the second requirement (but in this case I am still of the idea) is to collect whenever possible rainwater .why not be lost.
This second need is accentuated by the fact that I have covered the culture medium with a nylon anti weeds, which plays very well his work but in case of rain is a screen nearly complete.The first need is readily understandable, I believe.
1-2BGardening says: Nov 21, 2010. 11:26 AM
What a cool concept. I want to give it a try. Thanks!
rimar2000 says: Jun 14, 2010. 4:48 AM
Very clever! I planted in front of my house a willow tree to provide shade in summer, and they recommended that it watered until it grows long enough. Then I did something similar to what you propose, with a large bottle (3 liters) and a PVC pipe that came about 20 cm underground. At first I filled only the bottle with the garden hose, but then became a "pot" among the roots of the willow, and entered dozens of gallons of water. This greatly facilitated the tree growth, which in any case took 3 years to provide shade. By the way, I make a serious warning about the willows: their roots are very aggressive to pipes, floors and walls. It is imprescidible to do them an underground perimeter wall at least 80 cm deep, to force the roots to go down the construction. Otherwise, they break everything in search of water, it is a very thirsty tree.
torx (author) says: Jun 14, 2010. 1:35 PM
Thanks for the compliments, then you've done something like that? But operated by collector for rain if I understood correctly ...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
