Easy to Build Desk Top 3 Axis CNC Milling Machine
Step 2The X Stage Rails and Motor
Next its time to add the rails for the X axis stage. These rails are 3/4 inch U chanel aluminum that you can get from the hardware store. Put a washer under each end to space the rail off the pipe just a bit. Don't worry about the rails being perfectly parallel. You'll see why later. Now mount the stepper motor with a bracket like you see here. Connect a length of 1/4 by 20 threaded rod to the motor shaft with a short piece of rubber hose (1/4 inch fuel line). Now your ready to set the movable part of the X axis(the stage).
12 comments
Sep 4, 2010. 5:06 AMKilopondio says:
Hi Tom! I`d like to ask you for the long of threaded rod to the motor shaft.If I want to make some square base what would be the size of this square?. Thanks
Jun 15, 2010. 11:02 AMjcskyhawk09 says:
Where can i buy a step motor at.
Mar 15, 2010. 6:14 PMfozzy55 says:
hi there...
can someone tell me what kind of stepper did he use???
please....
bc i don't know what step motor i should to use :S
Mar 19, 2010. 10:07 AMbluumax says:
Unipolar 5-8 wire.
Size NEMA 17
Oct 31, 2008. 10:55 AMDodgy says:
does the far end of the threaded rod (left, on picture) just hang/sit/rub on the steel pipe? Should/can you support it somehow?
Nov 5, 2009. 12:12 AMbluumax says:
Just let it hang.
If you don't it will want to move the table or whatever is riding on the nut all over.
If you support it you'll need bearings on each end.
Nov 3, 2009. 10:26 AMmmason1 says:
I found it easier to just take a few minutes and grind a section out of the pipe that way the coupling nut could travel past the piping for an extensive use of the X axis.  I also welded a sleeve into the slot where I extraced material on the piping, and not necessarily for structural reasons, but for a nicer look(sucks to be OCD).
Mar 16, 2010. 11:54 PMganjamaniac says:
could I see a photo of that please
Jan 30, 2008. 8:22 AMJorg says:
What kind of rubber hose did you use? I'm still searching for it.
Nov 3, 2009. 10:37 AMmmason1 says:
Advance Auto has it for about $1.29 per foot...... and if you're looking into Lowes or Home Depot, it will be a clear line instead of black.  I found that the auto stores have a thicker wall thickness on their lines, and the Hardware stores have a smaller wall thickness(if you are wanting to use the smallest available parts)
May 17, 2009. 1:47 PMkasari001 says:
WHAT MOTORS......PLEASE!
Jun 4, 2009. 6:39 AMdisturbedreaper says:
stepper motors i dont think it maters for a perticular modle just a steper motor becuase u will have to zero everything on the software
Apr 6, 2009. 12:08 PMmsalhi says:
Tom you did not mention anything about the motor specifications ... what kind should i get ?
Dec 27, 2008. 11:52 AMconcretebox says:
The threaded rod will attach to the moving platforms, that'll secure them just fine at the other end.
Apr 19, 2008. 1:43 AMsystemBuilder says:
Ok i'm a little clueless, but what did you use to drill/tap the holes, so that you could screw the rails into the pipe?? Thanx.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
348
Author:Tom McWire
