Easy to Build Desk Top 3 Axis CNC Milling Machine
Step 5Zee Z Axis
Zee Z Axis
Again we are going to reproduce the X and Y Stage to create the Z axis stage. Take a flat piece, here I used a piece of white Plexiglas. Mount some rails and a Motor to it. Then make a moving stage piece with a u channel and a roller bearing. We'll do something a little different with the nut(see picture). The four posts you see on the stage will hold the motor tool. Now since this stage is going to move up and down the weight of the motor tool will make it want to come off of the rails so lets add a few more roller bearings to each side to keep it together.
5 comments
Aug 27, 2007. 9:03 AMlandru says:
can you give a few more details on the four posts, and the bracket that holds the nut that the threaded rod goes through?
Jul 2, 2009. 8:26 PMcre8ev says:
Tom, instead of mounting the entire dremel can i mount one of those flexibles cables that attach to the dremel and put that into your system instead? i have numerous flexible cables around the shop and they would be lighter and less bulky.
Jul 24, 2009. 12:58 PMRedgerr says:
sounds like you could, no resion why not
Jun 25, 2009. 8:44 AMvolto says:
The pictures aren't clear enough to see the pins or how they are attached, or how they hold the nut in place. Also, what about the 4 posts on the Z plane, how do you reckon where to put them, how long they need to be, etc?
Jun 25, 2009. 8:47 AMvolto says:
Ah nevermind on the 4 posts, those are based off the dremel/roto zip dimensions.
Oct 31, 2008. 11:13 AMDodgy says:
re: the small metal strip that holds the ball bearing race. What secures it tightly? Not just that screw ? Surely it'd come loose and the ball bearing wouldn't be pressing against the clear plastic, right?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
348
Author:Tom McWire
