Easy to Build Desk Top 3 Axis CNC Milling Machine
Step 7What's it Do
What\
If you were interested in this project it's likely you have already seen what can be done with an 3 axis(XYZ) computer controlled milling machine. What is suprising is what kind of accuracy you can get out of this thing after you tinker with it a little bit. Make sure all the rails are held firm and straight. Tighten the roller bearings so the stage doesn't shift.
I used it to make PC boards. It's real good for engraving name tags and signs. And it's pretty exciting to see it carve a 3D object out of a block of foam or plastic.
WARNING there's a lot to learn about the software. Some venders offer package deals of motors, drivers, and software. That makes it easier but you pay for it.
I'll add more to this later. Send me comments and questions.
7 comments
Jan 12, 2010. 10:19 PMfrmco says:
I am convinced that you are a very smart person, and I congradulate you.I can make the machine, no prob. But don't no sht. about the elctronics or programs. excuse the language. I am very frostrated about it. I need help on the step motors and programing. Plz help.I live in LA. and dont have much info. on where to get stuff.
Aug 27, 2009. 11:31 PMdecarus says:
i'm wondering, how does it make PCB from scratch?.. how do u remove the conductive parts while leaving only small conductive traits(circuit) on the board? all i can see is the machine doing it the other way around....
Sep 12, 2009. 9:16 AMchriswillb says:
HI, no all it does is makes holes in the PCB board (i Think) PCbs are usually made with a photo etch method google it to find out more
Sep 14, 2009. 11:43 AMbluumax says:
It's easier to route the traces with a mill than to dink around with etch.
http://bluumaxcnc.homestead.com/Demo-PCB.html
Sep 3, 2009. 3:06 AMbluumax says:
Sep 3, 2009. 3:20 AMbluumax says:
This is a demo board I cut on a machine like this one, but modified.
http://www.bluumax.com/Demo.html
Aug 28, 2009. 9:35 AMDavetech says:
Lots of design programs have an output option that will create an outline of what you have drawn/designed. In Diptrace you can select an "Edge" output which creates a G-code file and saves it as a .dxf. Then you import the .dxf into your machine controller program (Mach, Cambam, K-Cam...etc) and use a "V" shaped engraving tool to mill the circuit trace outlines. If you are making a double-sided board, you have to set it to "mirror" the bottom set of traces and use a couple of reference points to exactly align the board when you flip it over to mill the back side.
May 12, 2009. 12:53 PMlenny25 says:
Any progress on the controller and software. Is there any open source software that will work?
May 15, 2009. 11:52 AMjosheeg says:
Looks to me like linuxcnc is free open source and uses ubuntu. It only runs on a decent computer thow.
Apr 11, 2009. 2:13 PMmarco1970 says:
UPDATE: I also have three Vexta pk268-01 2 phase, 1/8" step stepper motors. I don't know much (well, almost nothing), about CNC but love the concept of creating your own tools and parts :)
Apr 11, 2009. 2:10 PMmarco1970 says:
What kind of materials can be used with your CNC milling machine? Can it also cut through metals? If yes, what kind? I have an old Prolight program, will it work? I also have IronCAD, but I don't know how to work it and don't have the manual for it. Another program I have is Mach... but i have the same problem (no manual). Where can I find these manuals? a Manual for Solidworks?
Feb 6, 2009. 8:00 AMhawk0120 says:
Thats really awesome. I used to run a Hydra-Jet cutting system. Cnc systems are just cool. I'll waiting for your tips on the software.
Aug 4, 2008. 9:32 AMdaman07 says:
tell me about computer controlling of machine
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
348
Author:Tom McWire
