Easy to Build WIFI 2.4GHz Yagi Antenna
 by Biotele
Featured
This antenna will extend the range of your WiFi or 2.4GHz devices (like surveillance cameras) into many miles and kilometers. A yagi antenna is basically a telescope for radio waves. I tired the pringle can antenna and the Yagi beats it hands down in performance.
Step 1: What You Need
This is an absolutely easy project.
You need an ink jet printer/ Computer
Popsicle sticks
White glue
Crazy glue
Big paper clips (you could use any stiff solid metal wire instead)
USB WIFI, preferably with an antenna extension OR a 2.4 GHz device
soldering iron and lead
Sanding papers
Scissors
Pliers or preferably a nibbler (see photo below, available at radio shack)
a metric ruler with millimeters or a metric caliper.
Step 2: Building Overview
The building steps are simple:
1. Print out the scaled Yagi antenna template* (download from next step).
2. Trim paper clips to size and glue them to the template.
3. Use Popsicle sticks to build the antenna's backbone and hold it together.
4. Connect the USB device to the antenna.
*I used a Yagi modeler java applet to generate the diagram. This modeler applet is found on many websites (google "yagi modeler") and its owner is W9CF.
The modeler gives a diagram and the elements' lengths and position. I carefully scaled the diagram and turned it into a template in order to make the building process easy.
You can visit AB9IL awesome website  to get more details on using the modeler for this 15 element Yagi and other fine antenna projects, such as a 20 element WIFI Yagi .
Step 3: Printing the Yagi Diagram
The most essential point in printing the template is getting the correct scale. In the attached zip file below, are three png picture files.
The antenna is longer than an Letter sized or A4 sized paper. So you have to print the template in two parts (labeled part1 and part2 in the zip file). I have also included the full sized unsplit template if your printer can handle large enough paper.
PRINTING:
Make sure to set your printer's properties to ORIGINAL SIZE (not "best fit to page" ect..).
Set the print orientation to LANDSCAPE.
VERIFYING SCALE:
Use a ruler or caliper to measure if the print is of correct scale. You will notice vertical bars crossing the horizontal line. The vertical bars represent the Yagi "elements" which will be made from paperclips. The horizontal line is the backbone of the antenna which will be build out of popsicle sticks.
You will also notice numbers next to the elements. These numbers are in pairs. The first number is the length of the element in millimeters. The second number, is the distance from the start of the diagram to the element, in millimeters.
Measure the size and position of a couple of elements on each prints. If your measurements match the numbers on the diagrams, then your print is to scale and you may proceed. Accuracy need not to be tight for the antenna to perform well.
Now superimpose both prints, until they match at around element 10 or 11, and tack them together with scotch tape or white glue.
Yagi.zip212 KB
Step 4: Cutting the Paper Clips and Fixing Them
You have to trim the paper clips with a nibbler or plier to fit the vertical bars ("elements"). This is fairly straight forward. Lay the paper clip on the template's element and mark the ends with a marker. Snip at the marking.
Make sure that each element fits correctly the length of the bar on the diagram.
Fix the elements in place with crazy glue.
Leave element #2 for later. This is the element that connects to the electronics and is called "the driven element" (as in being driven by electronics).
Step 5: Building the Backbone
The backbone holds the shape of the antenna. I just cut pieces of popsicle sticks and fit them between the gaps of the elements. I used white glue to fix them in place.
Start from element #15 backward. When you arrive to element #2 move on to the next step.
Step 6: Building the Driven Element
The "driven element" in a Yagi antenna, is usually the second one from the start. It is the element that connects to the USB WIFI or 2.4 GHZ electronics.
It is a broken loop and not a straight wire. A loop of wire resonates at a specific radio frequency depending on its dimensions. The dimensions of the driven element in this antenna is set at 2.4GHz, of course.
It just happens that its about the size of a common big paper clip. You need to clip the paperclip so that it loops around and meet in the center but the end not touching, leaving a gap (see photo).
Fix it in place with crazy glue and build the back bone around it.
When all the elements and sticks are in place, reinforce the antenna with another layer of popsicle sticks. Glue full lengthed popsicle sticks on top of the antenna. The antenna should become mechanically stiff. Then rip the paper template of the antenna.
Step 7: Connect the Antenna to the Wifi Modem
This is the most difficult part and depends on the electronic hardware you have. please read this step carefully.
The basic idea is that you need to solder a wire between the WiFi board's RF output and the driven element of the yagi antenna.
But USB WiFi modems come either with an internal antenna or with an external antenna. Those with external antennae, like mine, are easier to connect because you are just replacing the external whip antenna with the Yagi. Those with internal antenna may need to have their on-board strip antenna modified as illustrated in the pictures here. You need to slightly experiment in this case.
I have tried soldering a coax to my board's antenna connectors and the two ends of the yagi's active element loop but it did not work in my case. I have no explanations why that did not work, but other DIYers that have built Yagi antennae connected their antenna in this manner.
In my case, I just connected a single thin strand of copper wire between the active element of the strip antenna and one end of the loop of the driven element.
Please read the annotations of the pictures for more details.
1-40 of 130Next »
brian-kn says: Apr 30, 2013. 4:24 AM
Hi, I thank you very much for the reply about the antenna wiring it is more clear now that you have explained, Kind Regards Brian UK
brian-kn says: Apr 20, 2013. 10:15 AM
Hi can the wires from the yagi antenna be connected with the wires in a a usb connecter and connect directly into my laptop. kind regards brian
popefelix in reply to brian-knApr 29, 2013. 9:44 AM
If you mean just soldering a USB connector on to the feedline for this antenna, no, that won't work. You still need something to handle the actual generation and reception of the wireless signal.
However, if you mean connecting the antenna to a USB wireless adaptor, that's possible, provided you connect the feedline from the antenna to the antenna connector on the wireless adaptor. If the adaptro doesn't have one, you'd have to tear it apart and find where the internal antenna was connected.
popefelix says: Apr 29, 2013. 9:43 AM
sololife.sai says: Sep 30, 2011. 10:53 AM
Can i use a wire if so what is the diameter. Thank you
Biotele (author) in reply to sololife.saiSep 30, 2011. 2:53 PM
Of course, it has to be stiff and solid. I don't think it has to be exactly a certain diameter. Maybe someone with antenna theory can enlighten us further.
Dr.Bill in reply to BioteleMar 3, 2013. 3:16 PM
I think a larger diameter wire will result in a larger bandwith antenna.
For a router with 2 antennas, why not build 2 yagi's and stack them?
A stacked phased array just like the EME array's for moon bounce.
iamdarkyoshi says: Nov 14, 2012. 3:27 PM
I have a major problems that needs solving quick: how exactly do i connect the driven element to the antenna? as you can see, the antenna boom is missing the element, because i popped in my original antenna with the usb card, and worked fine, but not the strongest signal. why didnt it work with the copper wire? because i just took the 2 wires coming off my board, and put them on each end of the element, completely skipping the original antenna? how is the wiring diagram? any help would be greatly appreciated, as im bored of trying to get around the schools internet filter, with this i can mooch off of someone elses:D
estefan2020 says: Sep 19, 2012. 1:15 PM
here is a matching using a piece of coax to get the 300ohm down to 50ohm
http://www.k7mem.com/Electronic_Notebook/antennas/yagi_vhf_feed.html
estefan2020 says: Sep 19, 2012. 12:56 PM
@kiranrpatil01 if your phone has an external wifi jack, or you plan on opening ypur phone and soldering some lmr-400 cable to your phone and have a 2ft antenna attached, go for it.
estefan2020 says: Sep 19, 2012. 12:51 PM
here is an online yagi calc for 2.437 ghz, gives more options
http://www.k7mem.com/Electronic_Notebook/antennas/yagi_vhf.html
chrislarkin says: Oct 3, 2011. 12:23 AM
it did not work because you were completing the circuit at the end of the coaxial cable stopping the signal from traveling through your antena
estefan2020 in reply to chrislarkinSep 17, 2012. 10:21 PM
if this was dc theory, yes, but this is ac theory. the driver element acts much like a loop. just like the old circle uhf antenna, this way is called a folded loop, when the folds are the same distance. dc looks like a short, ac does not.
estefan2020 in reply to estefan2020Sep 19, 2012. 11:01 AM
http://www.youtube.com/watch?v=BGdwIXMexCY&feature=rellist&playnext=1&list=PLD7A103946CE9C072
here is another yagi folded antenna with aproprate matching cable for 50 ohms.
if you need a wifi with detachable antenna, alfa on fleebay is a good choice
estefan2020 says: Sep 18, 2012. 1:26 AM
I would suggest ether placing glue on your sticks and let it dry, or using plastic wrap around the sticks. this will prevent moisture from the wood interfiering with the antenna.
kiranrpatil01 says: Sep 18, 2012. 12:48 AM
is there any danger by using it ,like licence for WiFi and can it be connected to android mobile to access internet?
estefan2020 says: Sep 17, 2012. 10:39 PM
for cable ebay 'rp-sma lmr 400' 3ft 1mcable $13 this is the only thing you don't want to skimp on, as it is for these frequency's cable signal loss can eat up the gain.
you can get 'RP-SMA male flange' and connect your antenna to your usb antenna adapters jack, and avoid the cable loss. just mount the driver element so it hooks up at the bottom instead of the top.
frankortega says: Mar 7, 2012. 1:34 PM
I found a company and there antenna are not too expensive, I try to build
two type of antenna in (easybuild2.4 GHz), but still lacking some imformation, and its end up lossing my time, need more information,kind ofcable,connector,and how long
the maximum leght of the cable.
thanks
Home :: Antennas :: 2.4GHz (Wi-Fi Antenna) Printable
AIR802 manufactures a variety of antennas for WiFi, RFID and ther wireless applications using the 2.4 GHz unlicensed ISM band.
Indoor - Wireless Router Antenna
Mobile - Vehicle
Omni - Mast Mount
Omni - Marine/RV Mount
Omni - Mesh Style
Omni - Uptilt Models
Yagi - WiFi Antenna
Grid
Sector
HomeFAQWhere to BuyPartnersAbout CompanyContactSitemap
Copyright © 2006-2012 Air802 LLC
424 Fort Hill Drive, #105
Naperville, IL 60540 USA
Tel: 630.428.3108
Fax: 630.637.8662
sales@air802.com 2102 Av Fermin Vivaceta
Independencia
Santiago, Chile
Tel: 562.455.0975
Fax: 562.455.0976
ventas@air802.com
http://www.air802.com - AIR802 manufactures professional, reliable and high quality wireless and cable products. Our products are offered direct or through distributors or resellers. Our wireless products include high power and long range access points or routers, usb adapters, antennas and coaxial connectors. The cable products include 50 ohm 195 and 400 series coaxial cable in addition to high quality outdoor CAT5E Ethernet cable.
http://www.air802.com covers USA, Canada, Mexico, Chile, Columbia, Peru, Argentina, Brazil, UK, Australia. Product CategoriesAntennas
Cable - Ethernet / Coax / USB
Connector/Adapters
Lightning Protector
Marine-RV Hardware
Miscellaneous
Power Over Ethernet Injector / Splitter Products
Radios
Switch
Tools
Knowledge CenterConversion Table (dBm to Watt)
IEEE 802.11b/g/n Wireless Standards Comparison, Facts and Channels
FCC Rules and Regulations (2.4 & 5 GHz)
View RF Coaxial Connector Identification Chart
Radio Manufacturer to Coaxial Connector Type Cross-Reference
Customer ServiceContact Information
Hours of Operation
Return Authorization Form (RMA)
Your cart
Cart is empty
Wish list
Gift registry
Our PoliciesShipping Information
Payment Options
Sales Tax
Privacy Policy
Statement of Warranty
Return Policy
Legal Conditions
SupportContacts
Drivers
Firmware
Manuals
AuthenticationSign in
Register
Forgot password?
jbaker22 in reply to frankortegaJun 1, 2012. 1:03 PM
I have a Cisco wrt120n. It has 2 antenna how do I make the yagi antenna?
Biotele (author) in reply to frankortegaMar 8, 2012. 3:45 AM
I don't understand your question. You build this antenna but you can't connect it to the usn wifi receiver? Can you post a picture of what you build so far? Thanks.
jbaker22 in reply to BioteleJun 4, 2012. 4:48 PM
This is router what other info. Do you need?
jbaker22 in reply to BioteleJun 2, 2012. 9:06 AM
It has 2 antena like this shows. The metal parts on the side are the antenna. I would like to attach an alligator clip to 1 antenna which should I clip it to? Then I will attach the other end to the Yagi antenna.
nzammit says: May 28, 2012. 4:39 PM
Hey great instructable! It might be a bit off topic but I have a few old disused TV antennas. Could I somehow change those to receiving WIFI? Thanks.
dbartley says: May 14, 2012. 1:24 AM
Anyone with experience of reflections from the coax itself? I built a 4-element vertically polarized 850-MHz Yagi antenna. With the coax dangling haphazardly from the boom behind, there seemed to be tremendous problems. These problems seem to disappear by looping the coax behind from boom to the mast, forming ROUGHLY another half reflector.
dbartley in reply to dbartleyMay 20, 2012. 4:27 AM
The ARRL Antenna Book (Chapter 27, 1991) describes this problem of antenna currents on the transmission lines somewhat. The outside of the coax is actually part of the antenna, being directly attached to an active antenna element, though it is perpendicular in this region. But also its metal further back interacts inductively with other antenna elements in its vicinity. Directing the coax back along the boom, with a large loop (about 1.5 wavelengths) behind and down to the wooden mast improves reception consistency somewhat, rather than haphazard arrangement. But the ideal loop seems to be obtained from the tightest possible. Because of the peculiar geometry and the lack of actual measurement rather than qualitative evaluation, it's hard to understand why this is.
jbaker22 says: Mar 5, 2012. 1:46 PM
(removed by author or community request)
Biotele (author) in reply to jbaker22Mar 8, 2012. 3:46 AM
you can use a 2.4 GHZ coax cable with adapter hooked to your router.
jbaker22 in reply to BioteleMar 8, 2012. 1:07 PM
Biotele (author) in reply to jbaker22Mar 9, 2012. 3:22 AM
get a solid piece of copper wire that fits into the router's antenna socket, and connect to one side of the dipole. The wire should short.
jbaker22 in reply to BioteleJun 1, 2012. 3:02 PM
It has no socket. I have to solder and hope I don't ruin the router.
frisbeechamp1983 says: Jan 20, 2012. 9:40 PM
If I added like a reflector to the back to send all waves forward, the put it on a slow rotation like radar, would it still work? It would be attached to a modem in my basement,the wired to the roof of my house.
andrew101 in reply to frisbeechamp1983Feb 24, 2012. 6:00 AM
actually if you look at yagi antenna theory, the wire just behind the driven wire acts like a reflector If you added a dish behind the antenna, and the spacing was wrong, you would cause undue interference for yourself, and chances are it would work against you.
a possibility would be to add something covering the back that was grounded, it would act as a shield to interference, and not a reflector though.
Biotele (author) in reply to frisbeechamp1983Jan 21, 2012. 8:24 AM
Yes that will work. Can you post a picture that sounds like a great idea.
khan0daulatzai says: Jan 31, 2012. 1:18 AM
guy can any paste a video of this test,,,plzz
Computothought says: Jan 6, 2012. 3:07 PM
Made your antenna, but have not tested it yet. have to rescue a cable first.
Biotele (author) in reply to ComputothoughtJan 14, 2012. 4:14 PM
you don't need a cable a tiny short wire between the active strip on the board and one side of the loop will work. Photo's please. thanks
andythemac says: Nov 2, 2011. 6:19 AM
Excellent instructable! I've built the antenna but don't know where to solder the co-axial to my DWL-G122 adapter.
Here's some pics of both sides:
Biotele (author) in reply to andythemacNov 2, 2011. 7:30 AM
Check out this site:
http://www.sohtell.se/DWL-G122/
this one is better if you want to solder a coax directly:
http://usb-wifi.blogspot.com/2009/12/usb-wifi-dlink-dwl-g122-modification.html
jzhan says: Oct 25, 2011. 11:49 PM
here's the image
Biotele (author) in reply to jzhanOct 26, 2011. 8:19 AM
Excellent. The top one.
1-40 of 130Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
