3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy to build Headphone amplifier using Mosfets
This instructable is about how to build a simple headphone amplifier using easy to obtain components :)
The amplifier is based around a standard N-Channel Mosfet (IRF740 in my case) and is quick and easy to build with quite acceptable results. I scavenged the heatsink for this off the voltage regulators on an old motherboard. Its rated at about 9C/W (9 Degrees raise in temperature for each watt dissipated). When this cirucit is running, the heatsink is cool enough to touch :)
This circuit uses a simple Class A Common source configured mosfet to drive nearly any set of headphones (8Ohm+). This circuit works through the mosfet being biased into class a operation with a quiescent current of ~150mA. Maximum power output is limited to about 52mW @ 8Ohm through the 33R Resistor in series with the headphones, this power is with onset of some distortion. I test this circuit using my Sennheiser HD201 headphones, they are quite efficient and sound pretty tasty with this circuit! :P
It only uses a handful of components which most electronics builders can find in their component boxes etc. This circuit can work on any voltage from 6v-24v aslong as heatsinking the components is taken into consideration. The lower the voltage, the less power can be delivered to the headphones before distortion occurs.
Any questions on theory or building, please go ahead and ask! If you have any requests for some simple breadboarding circuits, if I have time, i'm happy attempt an instructable on them :)
Enjoy but stay safe!
Warning! I will not be held responsible for any loss/damage of hearing done through use of this circuit, this is for educational purposes only and hearing loss can occur if built improperly!
Step 1Gather Components
Gather Components
The first and most important step!
Gather all the required components for the circuit:
Resistors:
1x 100K resistor
1x 33R resistor
1x 680R Resistor
1x 47R Resistor (This resistor will need to be rated for 1W as ~0.73w will be dissipated)
1x 4.7R Resistor
1x 4.7k Preset Resistor
Capacitors (All rated for atleast 16v):
1x 0.1uF Capacitor (This capacitor will be used for the input)
1x 220uF (Or higher) Capacitor
1x 1nF Capacitor
1x 22uF Capacitor
Semiconductors:
1x N-Channel Mosfet (I used an IRF740, and mosfet rated for atleast 500mA an 20v will do)
Other:
12v Power Supply
Heatsink for Mosfet
13 comments
Nov 11, 2011. 6:40 PMblinkyblinky says:
How many watts can this deliver?
Nov 12, 2011. 5:40 PMblinkyblinky says:
Thanks. You should try ics such as the NJM2073. I built one and it can deliver a few hundred milliwatts but current consumption is high. Lm386s have less but will do. Same thing with LM358.
Nov 12, 2011. 6:21 PMblinkyblinky says:
Do you know how to make an amplifier using 1 AA battery that can act as a good hearing aid. One of my family members needs such a machine. The one he has now is 1 AAA battery (in which he doesn't enjoy) and will last him two months. However, the one I am requesting only needs a one month life. Thanks.
Sep 22, 2011. 9:00 AMJimmy Proton says:
Would one amp be too much current for this?
May 17, 2011. 6:32 PMJimmy Proton says:
Could this be used to amplify a constant current, like say a battery?
Aug 1, 2011. 7:56 AMaandrade3 says:
Instead of a 12v power supply would it be possible to use a USB port to power it?
Sep 13, 2011. 6:52 PMironsmith says:
we are studying mosfet at the moment in my semiconductors class. I have harvested a few out of my e-waste pile and would like to use them to learn a little more about them. do you have any circuits made up for higher voltages as a learning tool for me?
thanks for posting this one...
Feb 20, 2011. 4:46 PMPhil B says:
Very nicely done. I tried building a MOSFET project once, and destroyed the MOSFET. I think static electricity was the culprit. I am a little gun shy about MOSFETs now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pyrohaz
I'm a student from Cheshire, hoping to study Audio Electronics. I play bass and enjoy listening to music :)
