Easy to make concrete bowls and planters...
 by WUVIE
Featured
Step 3: Allow proper concrete curing time...
Concrete creation is generally not advised in temperatures exceeding _____ or under _______. Work in the shade if you simply cannot resist a Summer project.
CONSIDER A WATER BATH - Concrete is not as easy as mixing, setting and forgetting. It requires a period of time to harden, or 'cure'. Unfortunately, concrete is notorious for setting before the ingredients have had a chance to bond as securely as they could have. The result of a rushed concrete job is cracking, weakened durability and a crumbled project. I allow my projects to remain in the mold for a minimum of 24 hours, longer for thicker items, then carefully remove, and gently set the item into a deep bath of water for a minimum of one week. Okay, fine, I admit it, I stuff them into pond plant containers and sometimes in with the Koi, who is going to know? Often I submerge the entire project to avoid any damage. DON'T rush it, don't be impatient. The reward to patience is well worth it. A week. I mean it!
Many people also merely cover their projects with wet burlap (thanks, Cyoung13) or plastic wrap and such. Unfortunately I've never used such methods, so I cannot speak for them, but they are equally wonderful methods of preventing your project from drying out too quickly.
For those who simply haven't the time or the means to ensure your project stays moist, you might consider an acrylic concrete cure & seal, available in most home improvement centers in liquid form. Brush, roll or spray this formula onto freshly set (not freshly poured) concrete. Look for the deep yellow jug with green and black labeling in the concrete section. This product can be used on recent projects, or even existing concrete.
http://www.quikrete.com/ProductLines/ConcreteSealer.asp
cclark1 says: Aug 26, 2012. 10:45 PM
I have often thought of makeing some of these I just never have actually had the courage to come up with a way to try it. Great idea useing the cooking spray as a mold release.
I will probably make me some here in a few weeks when I have the spair cash to grab a damaged bag of quickcrete at lowes. (They sell damaged bags at greatly reduced prices here at the local one.)
I do want to point out that you might want to reconsider sticking the cureing product in with your Koi. Cureing concrete wreaks havoc on PH levels in the water. I suspect your pond is large enough to absorb the PH swings with out really messing with the PH in the pond. But if you put something really large in there to cure it might just be bad enough to damage the pond.
I have done some of the DIY hydrolic concrete and styrafoam backgrounds in a few of my fish tanks. (They look marvelous from the get go, more so when they are covered in growth, and weigh next to nothing) The cure time for them to stop effecting the PH levels was well in excess of a month. Most people that do 'oystercrete' for marine aquariums cure it for several months with daily/weekly water changes.
All that being said one of the most clever ideas I saw for that kind of cureing was to simply load the items in the tank of your toilet. So the water gets changed every time you flush the toliet. The water changes help speed the curing process apperently.
Any way thanks for the great information and keep tinkering away!
- Clark
(Frequently Z-man12 around the net)
hardwarechick in reply to cclark1Aug 28, 2012. 10:24 PM
I have been wanting to do something w/ concrete. I have been digging into my pins on Pinterest to decide which project to start and came across your Instructable. Have you ever done the hupertufa containers w/ the concrete, peat moss and perlite mix? I was actually ready to start on some but we're locked inside w/ Hurricane Isaac making his way to us. So I won't be playing in concrete for now. I know that I've seen something you've done before. Did you do the inside out tire planters on another website a few years back? I know I've seen Wuvie somewhere besides instructables. Well maybe you'll enlighten me. If not, thanks for the great ideas and instructable. I w/ be trying this and w/ let you know how it turns out.
WUVIE (author) in reply to hardwarechickDec 19, 2012. 4:44 PM
Hello Hardwarechick,
My sincere apologies, I tend to forget about the comments section, and I really do need to check on them more often. Thank you so much for the wonderful compliments! I actually haven't tried hypertufa, though it sure looks fun! Yep, that was me and the tires. That seems like soooo long ago. Hope you will give these a try, and definitely hope you will share. :-)
hardwarechick in reply to hardwarechickAug 28, 2012. 11:09 PM
I was just reading thru some of the older comments and I couldn't stop. So many great ideas. I have been making hypertufa containers. I don't know if you're familiar w/ it but if not, you might like the change. It's 1 part concrete mix, 1 part peat moss and 1 part perlite (from the garden center). Everything else you described is done the same exact way but this mix is very light weight. I think it's used to make troughs for succulents in arid climates but I use 2 sizes of buckets and pack the mix in between the two buckets(about 2" thick) or you can make your own forms. Laminated boards work really well. Just like your mix, you have to lube it up so it w/ release. The curing is the same and I drop mine into a koi-less pond. Everythings the same as w/ yours but I also use dowels to make drainage holes. I would do an instructable but I've never even uploaded a photo before and wouldn't know where to start. Of course, you may already know about this mix and I'm rambling on about it. Anyway, I'll be watching you for more great ideas. Thanks.
cclark1 in reply to cclark1Aug 26, 2012. 10:54 PM
Oh and once its finished its PH leeching its totally safe. (At least the hydrolic type cement.) Unlike what seems to be a common opinion. If it wasn't there would be a lot of guys with some very dead reef/fresh water tanks out there. My self included. I have some things that a few bits of copper in the water would kill in a few days. None of them have shown any signs of ill effect over the last year plus.
Oh and I don't know if you have seen it or not by hydrolic concrete is a very fine premix. If some one is looking for something fine and smooth I think it would be excelent.
Patouzorus says: Oct 16, 2011. 5:53 PM
I assume you are not sure what temperatures concrete should be used at. In reality the temperature will simply alter the speed at which concrete solidifies. The hotter the weather, the faster the concrete will harden. You could even do these bowls when its at freezing point but it may take several more hours to harden vs. a regular spring/summer day. One thing to consider might be very excessive heat, where concrete could crack because of thermal stresses. In the scenario where you wanted to pour concrete and it was 100 + outside, you can water the concrete once it's hard to cool it down down. (Do NOT add more water to the mix! A concrete with more water = a weaker concrete).
cyoung13 says: Aug 11, 2011. 8:32 AM
I know from working in construction that covering in burlap and keep the rap damp works well. Commercia manufactures of concrete products use this method.
WUVIE (author) in reply to cyoung13Aug 11, 2011. 10:48 AM
Excellent mention, Cyoung13. I'll amend the Instructable to include the burlap, and give credit where credit is due. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
