Easy Tomato Drying Rack.
12,715
252
16
Published
Introduction: Easy Tomato Drying Rack.
Need a quick tomato drying rack? I grow tomatoes and found myself with a lot of tomatoes, so many that I wasn't using them fast enough. I happen to love sun dried tomatoes and chili's and decided I would throw together a quick drying rack. This is what I came up with from things I had around the house.
Step 1: Secure Tomato Cages Together
Using larger zip ties I attached all the vertical rods on two tomato cages together with the rings offset enough to make several layers.
Step 2: Paint (optional)
Thought it would look nice in white.
Step 3: Prep the Screen.
Purchase or clean some old screen door mesh.
Step 4: Make Shelves
Cut the screen to fit the rings. Using zip ties secure the mesh to the layers.
Step 5: Shrink Wrap.
I wrapped the cages to to bottom leaving one slit down the side to access the shelves.
Step 6: Fill It.
Find someone to full it full of fresh tomatoes!
Step 7: Sun Dry.
find a nice spot to catch some sun.
    • Casting Contest
      Casting Contest
    • Spotless Contest
      Spotless Contest
    16 Comments
    I love snacking on them, the tomatoes lucky enough to avoid that go into bruschetta, pastas or baked onto bread. I have purchased it in powdered form for cooking and may eventually make some. I like to make chili powder from the Bhut Jolokia chili's on the bottom rack.
    I like the build. What foods do you usually put your dried tomatoes in? Or do you just snack on them?
    muy buena idea.
    Insteresting, thanks for sharing.
    How many days (average) you must wait?
    nice. I'll try your version. ha! I heard bugs don't bother them too.....false. I tossed a whole tray bc flies found a way under my cheesecloth.
    Good idea & Perfect Machine .. :)
    The plastic wrap was to help keep it hot inside as well as clean, as for the bugs, they don't seem to be interested in them.
    What about bugs? No bugs crawling in the little hole in the top?
    Pretty creative. Question: Why did you use plastic to wrap the outside? If you used screening, wouldn't that keep the bugs away and allow better air circulation, or do you need a greenhouse thing going on to raise the temperature inside?
    I like how you used a tomato trellis to make it.
    Thanks for the comments! It only took two days with good sun, and quarter inch slices. I cover them in a little salt and pepper.
    Great way to dry erb's thanks for the diy
    would it be possible to put a material that absorbs water on the bottom of this device to speed up the drying process?
    Multi-level drying system! That's so awesome, and you gotta love the price point! Thanks for sharing!
