loading
Step 3: Electrical connections
The wiring is pretty easy, you can see it in the diagram.
What you'll need to do first, is replace the small multi-turn potentiometer with the big one, it'll make the voltage controlling easier.
Then connect the voltmeter and the spring terminal in parallel at the converter output.
<p>Is it possible to replace the 2 wire digital voltmeter with a 3 wire one without adding an extra power source? My voltmeter needs a 5V current to light up</p>
<p>You can use a 7805 regulator, but make sure it doesn't overheat.</p>
<p>But then does that mean that the input has to be greater than 5V? Because I want to be able to mesure 1V for example, and my voltmeter needs 2,7-5V to light up</p>
<p>Then,you would need another 5v power supply.</p>
<p>Also, one last thing: the amps written on the adapter is the max amps it can support, so it won't necessarly be that much current in the DC-DC converter?</p>
<p>You can use your 3 wire meter just fine. The 3-wire meter I have has a red wire for its &quot;+&quot; power, black wire for its &quot;-&quot; power, and white wire for its reference voltage. Connect the red wire to the power supply &quot;+&quot;, connect the black wire to power supply &quot;-&quot; and connect the reference to buck converter &quot;+&quot; output.</p><p>* This will work as long as your meter can take the power supply's voltage. Mine can be powered by anywhere between 5V and 30V, my power supply was 19V.</p>
<p>Could I use binding posts instead of the audio spring terminals?</p><p>Thanks!</p>
<p>hi my cars fan stopet working and they dont have the fan controller, so i got a potentiometer and am wondering as how i would hook up the car battery to the potentiometer the potentiometer to the DC motor? please answer me. i need help</p>
<p>Although fan speed is controlled by a resistor in series with the fan motor, those fans draw a serious amount of power. You would need to find the ratings of the fan speed switch in your car to find out what values they used. A 10W to 25W potentiometer can be purchased after finding out what values produce minimum speed for your fan. You could get several 10W 100 Ohm and 10 Ohm resistors and experiment. No resistance will be maximum speed, obviously. To use a much lower power resistor you will need to use a transistor with a heatsink or an encapsulated fan speed controller module. Like this one available on Amazon: ELEGIANTFurmores3317 This is a 90W PWM motor speed controller that will run from 12V and cost about $7 US.</p>
<p>Hi,</p><p>I would like to build this power supply, one of my uses will be as a car battery charger, what would be the best way to add an amp meter to the device that can let me know what the battery is taking? Also would that be a cheap addition?</p><p>Thanks for your assistance</p>
You can't use this powersupply as a car battery charger,not only it wouldn't handle the curren needed, you also need current limiting to charge a battery.
<p>Thanks, for your prompt response, I was hoping that I could have a more versatile unit with this project than a standard battery charger, but it looks like I will just have to get a battery charger.</p>
<p>But you can totally build your own car battery charger. Buck converters with amp control are not expensive and are used for DIY chargers.</p>
very good idea!<br> i dont found pcb??may be send this<br>thank you
nice, cheap and easy!!! thanks for the idea!!!
<p>Hi, </p><p>You mentioned that I could make the power supply to deliver up to 3 A if I make my own. How could I do that? Would I have to get an AC power adapter that can supply that much current? </p><p>Thank you</p>
Yes, the power adapter has to be able to deliver at leat that current.
<p>can i use a 40-45 power adapter?</p>
<p>How did you decided to use a 10k potentiometer?</p>
<p>Use the same value as the one that came in the board.</p>
Can I use LM317 with a 5kpot at the output of adapter instead of DC-DC converter??????<br>Please reply fast
<p>Yes, but the lm317 will need a heatsink.</p>
<p>Actually the pot is just a simple resistor divider, 1k or 50k generally work well so.</p>
I just want to know that why are u using dc-dc buck converter??????
<p>I made this! Unfortunately is't really easy to tear out the vias on these cheap boards when de-soldering the trim pot. I ended up finding a schematic for my buck converter and wiring in my 10k pot directly to the output power and through a 330 ohm resistor to pin 4 (feedback) of my power converter chip (LM2596).<br><br>Schematic I used: http://www.haoyuelectronics.com/Attachment/LM2596_BUCK_DC-DC_module/LM2596%20BUCK%20DC%20DC%20module%20schematic.jpg</p>
<p>What variable output DC-DC converter did you use? Most of the ones I see are quite a bit larger than the one in your photos.</p>
<p>Hi. I got the same version of this project. Can i change the power adapter to car power supply ? </p>
<p>I made it, great idea. My Power suply gives only 12V, and my potentiometer has a 4-32 range, so mine only has 4-12 range (Enough for my purposes). Also my power suply had no space, so i put the project in an old transformer, I'll work on the project boxing when i'm done with the led project i'm gonna manage.</p>
<p>Hint: Do not test Intensity without a circuit or you'll burn the device. I've just finished it and i have to buy another DC-DC converter</p>
<p>Can I use this?<br>You could send the link of what you use you</p><p>http://www.ebay.com/itm/ADAPTADOR-CARGADOR-impresora-32V-16V-375mA-500mA-para-HP-Deskjet-F2180-/281289025645?pt=LH_DefaultDomain_186&amp;hash=item417e21e86d</p>
<p>Yeah, you can. If you see on my comment above, i used a 12V one, but you just have to get the cable and test with a polimeter which cables have 32V. (in my case black (generally negative) and green were 5V and another black (doesn't matter which one) and green had 5V. I removed the 5v one and worked with the most powerfull one.</p>
<p>@tru-dhillion yeah i know what kind of vape.....<br>Obs: you do'nt need a pwm controller, the PS already has one.<br>I build electronic vapes all the time, it isn't really hard if you know a bit.</p>
Anyway of connecting a PWM? I was considering building this as a vape station.
<p>Hey, I was inspired by this project enough to make my own little version. I used a slightly more expensive voltage regulator than yours, but mine had a screen built in. I designed a 3D printable case for it too because I didnt want to try cracking open the adapter case. You can check it out here if you're interested:</p><p> <a href="http://www.thingiverse.com/thing:745463" rel="nofollow">http://www.thingiverse.com/thing:745463</a></p>
<p>Nice project, this looks like something that would be really handy to have. Your graphic on step 3 looks good too, what program did you use to draw it?</p>
I used photoshop, but any drawing program would do.
Could I use other terminal? Like a Weidmuller?
<p>I love that you're reusing the plastic casing of the PSU... <strong>Brilliant</strong>!</p>
<p>Hello,</p><p>Can you tell me how does it work, what we are actually doing. Please provide a detailed explanation.</p><p>Thank for help.</p>
<p>The little board is a switching converter, you can look for the theory behind it. What you have to know is that you can put a voltage on the input, and the output will go from almost 0v to the imput voltage minus 2v, just by turning the potentiometer.</p>
<p>Hello,</p><p>Thanks for the inscrutable, it was a very nice instructable.</p><p>I have a question, my printer adapter has an input of 200-240V but in the you uploaded it read as 100-240 V; will my printer adapter work?</p><p>Another question, can you give the link from where you bought the components, because when I searched it on ebay it showing product costing more than you specified.</p>
<p>If you live in a country that has an outlet voltage of between 200 and 240V</p><p><a href="http://www.ebay.com/itm/1-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-/181409861491?pt=LH_DefaultDomain_2&hash=item2a3cdecf73" rel="nofollow">http://www.ebay.com/itm/1-DC-DC-Buck-Converter-Ste...</a></p><p><a href="http://www.ebay.com/itm/Lithium-Battery-Digital-Voltmeter-DC-3-3v-17V-Red-LED-Small-Panel-Meter-FO-/291361070424?pt=LH_DefaultDomain_2&hash=item43d6791d58" rel="nofollow">http://www.ebay.com/itm/Lithium-Battery-Digital-Vo...</a></p>
<p>very good Instructable, but i have one question, i would like to use my old laptop charger but in output signal have 4.97A, can i use that DC-DC buck converter which his max A is 3A without problems?</p>
<p>Yes, no problem. Your circuit will only draw current (amperes/A) as needed from your 4.97A PSU. In fact, having more current capacity than required by the circuit is ideal as long as your load does not draw more current than the safe limit of ~2.5 A (the 3A limit of the buck converter's LM2596 IC should never be reached - especially not without a heat sink). </p>
Where could I solder an amp meter to this board?
Any way to get an on off switch on there?
what if i wanted ac output? specifically 9-12v at 1500-2000ma?
This circuit only works for dc, for ac you'll have to find something with a variable transformer, there i can't help you.
<p>Hello everyone,</p><p>does anyone know how he does thet graphical drawing? </p>
<p>could you use a 20V power adapter, and get smaller hardware?</p>
About This Instructable
180,953views
1,176favorites
License:
Bio: I love electronics and all about DIY.
More by pinomelean:IN-12 nixie clock Li-ion battery charging Mini line tracer
Add instructable to:
