Easy wall mounted storage bins for hardware parts
If you're a maker, they you probably have acquired a vast assortments of parts, screws, widgets and assorted random bits. And if you're like me, then they've all disappeared into cabinets and drawers, never to be found when you really need them.
I decided to organize all my parts into bins that allow me to easily see in a glance what parts I have. At first I was going to build standard shelving, but then I came upon a solution that's inexpensive, easy, flexible and fast. And it looks pretty cool, too!
Step 1The storage bins...
The storage bins...
The key to this project is the bins. I picked up these made by Akro-Mils at a local Grainger store. They're also available on the web for $0.90 each, in cases of 24. This is the model that is 5.5" deep by 4" wide by 3" tall. Blue, yellow and green.
The key feature for the bins is the hook along the back, that is designed to fit into their shelving systems.
These bins also have a 3" by 1" slot in the front for a label.
Other brands & models may work well, but I can vouch for these.
43 comments
1-40 of 43next »
Jul 10, 2011. 11:41 PMagatornz says:
I am using the large bins - and so used lengths of scrap inch angle iron, cutting off two inch piece, and welding them opposite to each end so they acted as feet.. to keep the rail away from the wall, then drilling through and screwing in... Angle also required a quick dust with the angle grinder to make the edge thin enough to take the bins... - was about to do and instructable on it...
Apr 20, 2011. 2:31 PMmarc.cryan says:
Nice -
I'm using J-channel from the drywall section of home depot, it is about $2 for 10ft.
Apr 14, 2011. 10:46 AMhammer9876 says:
What no "before" photo? Good instructable!
Apr 16, 2011. 8:42 PMstatic says:
Speaking about the plywood on the walls, I found it interesting you got a delivery of plywood with so many sheets with the knots lined up. Almost like printed wall paneling.
Apr 17, 2011. 12:12 PMnoahspurrier says:
That's because plywood is made from veneer which is made by "unrolling" a log using a giant peeler. The roll is flattened out to make a veneer. Knots in a log will repeat every time the log rolls back around to the same spot. Of course, the repeats will be a little closer each time because the log diameter gets smaller as the wood is stripped off.
Apr 14, 2011. 3:30 PMkyzla says:
I always do this sort of thing by myself... like shelves (the uber simple kind, wood (1"x8"x8') on L brackets) and my husband comes home and just looks in astonishment.
"How? What? You could have waited!"
"You'd only get in the way," I say.
I've been doing it solo for 15 years...
It's almost easier when you're trying to balance the length of wood/flash/bracket/whatnot and the level and the pencil and the drill as opposed to just the pencil.
ha!
Apr 14, 2011. 3:26 PMhailster says:
I use a very similar set-up on my RMA service bench at work. It makes keeping different parts organized very easy and I've thought about doing something like this at home but have always put it off because of the cost. Using your idea I might actually do it now.
Apr 14, 2011. 11:21 AMefgal says:
That does look like a great, easy-access system! One question, though, is how much sawdust do they also end up holding? Or is there a suggestion for minimizing the problem? My workshop is a rather tight space, and where I'd put such a setup wouldn't be very far from my things-that-create-sawdust.
Apr 14, 2011. 3:05 PMNickGriffin says:
My solution to the sawdust problem might be a flap of 6 mil plastic attached to the wall above them-creating a "flap" for each row of bins. If they are labelled, you should still be able to see what is in them, and no sawdust! Just reach under the flap.
Apr 14, 2011. 2:10 PMiritm says:
I love your ideas. Maybe you have an idea for my beads.
As a 'beader' jewelry making, I have a lot of boxes but they are not accessible and not so visible!
I keep the beads in boxes that are transparent and divided, and also little transparent plastic bags, and every type of beads in a larger plastic bags, so every time I need beads I spend a lot of time looking for them. It is tiring makes the planning cumbersome and takes out all the fun of the creativity that I love very much!
I am in a very large community of beaders in my country and all over the world, we are all connected more or less together. I am sure all of them will be glad to have a solution for this problem!
Dec 15, 2007. 10:24 PMberserk says:
I had to smile... I am not the only one who stores clamps in rafters. :-)
Apr 14, 2011. 1:58 PMcriggie says:
Honestly? Who wouldn't. I have a sash clamp up there, and all my G and F clamps are fastened to a truss too.
One trick for storing stuff is to use either hooks, or put 6" nails in but with a bend to stop stuff falling off in a quake.
Apr 14, 2011. 10:14 AMdesertdog says:
Great idea. One question. How strong are the metal rails and will they bend under the weight?
Apr 14, 2011. 12:28 PMmarkeike says:
This is a great idea, but I have a suggestion to possibly improve it. I'd consider replacing the sheetrock channel with a more structural standard aluminum channel (with a 1/16" or 1/8" wall depending on the groove on your bins). On the downside, you'd either have to rip one side of the channel down on the table saw for screw clearance, or drill some thru holes to pass the screw thru the front into the back. The advantage would be the ability to use much larger bins (they make many more sizes than these), carrying far more weight. Great job!!
Apr 12, 2011. 9:37 AMchaosrob says:
Way kool. I'll have to visit my local "G" store and see what they've got. But, if the parts are 'classified' and I don't have clearance, are you gonna have to shoot me??? ;-)
Apr 11, 2011. 9:02 PMilpug says:
This is going in my workshop NOW. exactly what iv'e been looking for. are the bins available in that size only, or are there other bin sizes available that would work with this system?
Apr 12, 2011. 8:55 AMilpug says:
thanks a bunch for all the info. i have bought things from Grainger in the past, on my dads business license. I am a minor, technically, so tax returns are not my problem (yet :/)
Mar 16, 2008. 2:27 PMAlexCphoto says:
Absolutely what I needed for my work space!!!
Mar 23, 2011. 9:21 PMKalait says:
Bought a bin for outside storage of the propane tank, I recently had the same problem. I used a shelving system from Home Depot for most of the stuff, got a tool box and still working on other items needing storage. Good luch with your storage projects.
Jan 6, 2011. 5:31 AMTRANSLTR says:
Awesome. This is on my list of must-do projects now.
Feb 25, 2009. 10:14 AMtmfDan says:
Thanks for this. I bought 12 bins from Grainger then saw that my Home Depot had this set of 8 bins for $6.97. They come with little plastic hangers so you don't need to buy the drywall mount. I do like the plastic hangers better than the drywall mount - they hold the bins a little tighter to the wall - but on the bins themselves the slot for labeling is smaller and nearly unusable. Wanted to let people know about the option though.
Jan 31, 2009. 10:21 AMkolowinter says:
I appreciate how you value your time and "random bits" enough to give them the attention and organization they deserve. Hopefully our (former?) throw-away society will embrace your mindset. Thanks for taking the time to share
Dec 11, 2007. 10:12 PMtrebuchet03 says:
Drool.... How I wish I had a workspace that wasn't in my living space :p
Dec 12, 2007. 3:25 AMT3h_Muffinator says:
Drool... I wish I had my own living space! (So that I might be able to work in peace) Oh, and nicely organized storage bins, too! My room's a bit..... messy....
Jan 23, 2009. 10:47 AMjongscx says:
Ugh... I wish I had one big abandoned/repurposed hangars instead of 3 smaller ones... so that I could fit my workbench next to the metalwork instead of having to haul the project from one to the other...
Feb 2, 2008. 4:38 PMjuggalo_assassin183 says:
lol i could use my own living space to work in to i dont even use my room ushualy our living room my room is a bit ah ... disasterific
Dec 16, 2007. 7:14 PMGorillazMiko says:
do you think they would sell these little boxes at Home Depot?
Jan 23, 2009. 10:45 AMjongscx says:
Yeah, $5 for a pack of 3 small ones, the 5" ones get to be around $2-4 each...
May 22, 2008. 10:19 AMpappyld04 says:
They should have them but you may want to look up Harbor Freight Tools first. Should be cheaper there. Atwoods carries them also!
May 22, 2008. 10:17 AMpappyld04 says:
I amass quite a few of these at about .25ea at thrift stores and Salvation army shops in a bigger city. I also have a few that are about 4x as big as the lnes you have that I was told to throw in the dumpster. Also have 4 of the smaller red ones with those cheesy plastic rails that hold all 6 in each box but the end ones stick past an inch or so. I hung mine on my new unfinished garage with a couple of pieces of the angle iron we used to use on oil storage tanks. I just cut a slot into the bottom of the angle that would slip over the galvanized upright posts and still have a spot to run my water and air compressor lines to the door! None of that weight will ever bend 1/16" metal!
Dec 12, 2007. 8:21 AMclothbot says:
Another approach is to screw glass jars underneath shelves. Works very well for mixed small parts.
Feb 1, 2008. 6:29 AMwperry1 says:
My grandfather did the same sort of thing with about an 8" 2x2 and 16 baby food jars. He put 4 on each side and attached it to the wall with a bracket so it could spin and he could get to any of them.
Dec 12, 2007. 6:23 PMAustringer says:
I just did something like this via the standard shelving route because the plastic rails that came wit the bins looked like picking up a million small parts to me, I thought the shelves might help keep dust and such out of my parts and premade metal flashing never occurred to me! I'll have to post a picture of mine and ride on your coat tails. ;)
Dec 12, 2007. 4:25 PMGorillazMiko says:
nice work area, AMAZING INSTRUCTABLE! finally, i really needed something like this, if i can, i will do this in my room (favorited) this is just AMAZING!
Dec 12, 2007. 12:46 PM!Andrew_Modder! says:
nice work area :-)
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Mike Begley(SeattleLumin.com)
Hi! I'm a general-purpose maker geek, living in Seattle. Interests include beer brewing, robotics and woodworking. I like to go camping in the desert. I enjoy hiking to hot springs. I'm learning ho...
more »
