3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy wardriving wireless antenna booster- wifi - wlan
In this instructable i'll show you how to build a very easy wireless antenna for practically no money. I made it by recycling some stuff that we were otherwise just throw away. So it's kind of green too! =)
The idea is to catch the wifi waves that pass near your laptop without reaching it, and make them bounce into your wireless antenna.
I use it standing behind my laptop when i'm.. reading my mail..
..to make it.. load faster..
**hmm...**
..yeah..
It actually nearly doubled the signal strength i got from a certain access point.
It's really easy you'll see, so get into it right now!
Step 1Gathering materials
Gathering materials
What you're gonna need is:
-Aluminium paper
-A big cardboard sheet
-some light pipe
-Duct tape
-Some other cheaper adhesive tape
-some screws
-a wood bit
-some (pretty soft) metal parts you can cut and bend
-tools: screwdriver, saw
17 comments
Nov 6, 2011. 7:43 PMAymanElsayed says:
Thanks Will Try This but what about measurements
Mar 21, 2011. 12:41 AMarian1101360 says:
i have a waimax network for a cofenet but my connection become disable frequently and the clients become angri ,what can i do?
Mar 21, 2011. 12:37 AMarian1101360 says:
very good mersi
Oct 8, 2009. 4:57 AMMcGyver2 says:
I have two questions: how do I connect it to my laptop and do you have video footage that it prooves works?
Mar 18, 2011. 10:03 AMwintergoat says:
You DONT connect it. It simply reflects the waves to your computer.
Apr 22, 2009. 10:24 PMwee_man says:
Im not completly sure but in this sort of dish all the radio waves collect at a curtain point the focus have a look at thishttp://en.wikipedia.org/wiki/Parabolic_reflector
Im gonna try it to improve the wireless signal coming to my sleepout.
Jul 27, 2009. 12:14 AMPixels303 says:
Aluminum foil will work no worse than any other conductive material.
Focus is important. Simply divide the width by 4 and you have your focus - Or use the 45 degree reflection points for the focus. You will also find that orienting your antenna 90 degrees with respect to your diagram will also boost your signal quality by a significant amount.
http://www.ctforumgroup.com/forum/viewtopic.php?f=36&t=19202&sid=27f6b605012f2cb9b3f94733115c0345
Apr 24, 2009. 9:26 AMsysadmn says:
Or you can use excel to graph a parabola, print it, and use that as a template. Don't forget to mark the focus point on the template so you'll know where the antenna should go.
Jul 27, 2009. 12:17 AMPixels303 says:
draw your own graph. Draw lines from the bottom center to the outer marks, and mark dots one left and one intersect up, two left and two intersects up, and so on. Simply divide the width of the paper by four and mark that measurement above center for the focus. That simple, no calculator or computer required.
Jul 27, 2009. 12:18 AMPixels303 says:
width from Center to edge I mean
Jul 5, 2009. 2:43 AMthrobscottle says:
Cool project - better than fiddling with trying to connect a pigtail inside your laptop!
Jun 9, 2009. 5:45 AMgrandavi says:
Does anyone think using a sheet of Aluminum (not foil) will work at all? I am trying to get my wifi from my place to my brother, about 40 yards. I can use a laptop at his place and it can find wireless, but when I try his pc with a wireless card and no long antenna to it, it can not find a connection. Why would a laptop work and not the pc, both have wireless cards.?
May 3, 2009. 3:05 PMBadMonkey63 says:
All of the people above are right about a focus point for the reflector. There are allot of online calculators to make this calculation and get the best reception for your project. Look at my posting for the pop bottle reflector and read down in the comments area... A nice guy from south america had sent me a page of calculators and it did make a difference in the percentage of gain in the RF signal. Otherwise great job! :)
Apr 22, 2009. 4:56 PMrhackenb says:
Do you wire this to your computer? If not, how do you use it?
Apr 22, 2009. 9:50 PMthreecheersfornick says:
Agreed. How do I connect this to my laptop?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:faustologa
