Easy way to get metal filings for ferrofluid
 by Punkguyta
After some searching on here, it seems a lot of people get metal filings using acetone and old tapes. Others "can" go into a shop and ask for filings, but chances are they aren't that fine to begin with and might be "dirty". I'll show you how to do it yourself with a chunk of iron, steel, basically any chunk of metal that you have that is magnetic.
Also, I apologize for the poor pictures as all I have is a web cam that's probably around the 0.7mp mark. I did have a 2mp digital olympus digital camera, but it decided to stop working. If anyone would be willing to give me a old digital camera or something (2mp seems like old tech to people these days but it works for me >_<).
Step 1: Gather your killing, err regular tools
Well, I'm sure this could be done with a file, but dremeling would result in much finer and more filings.
What you need to start:
1xDremel
1xStone cut off disk
1xScrap of metal you want to use
1xContainer to collect the filings
1xMagnet to play with it afterwords
And perhaps some eyewear so you don't get nast things in your eys. Also, I happen to have one of these "rainbow vac" vacumm cleaners/air filter. For those who don't know what this thing is, it is basically a "water" vacumm that uses water instead of regualr paper or bagless cups to collect the dust/dirt. It is also designed to run without the hose to filter the air. So in short words, it's a 2300 watt vacumm (not kidding, says right on the spec sheet) and I sat infront of it while doing this. You will find it hand to have a vacumm or something as there is a lot of dust/fumes and isn't too good for your cloths/lungs and or eyes.
1-40 of 54Next »
busterbuster18724 says: Jan 22, 2012. 6:24 PM
how much would they be ? email me and i might buy them
Andrew546 says: Feb 22, 2007. 11:13 PM
Think I could make money selling this stuff? xD Thats a 1 gallon bag filled with iron fillings that i collected in about five minutes from the dry wash behind my house. And there's plenty more where that came from. That thing in the upper left corner is the big ol' magnet I used to collect it with. Supposedly it came from some sort of radar equipment or something like that. Second image shows my size 12 shoe next to the magnet in the bag, covered in iron. And all around me on the ground is the iron.
hedgesci in reply to Andrew546Oct 11, 2011. 10:55 AM
hey andrew, if you have that much iron in your dry wash, i would look for gold in it. ya never know
mitch and sean in reply to Andrew546Jul 8, 2011. 5:58 PM
What is a "dry wash"
bears0 in reply to Andrew546Oct 30, 2009. 1:41 PM
 hey can you send me a bag please
email back and i can give you my address
Punkguyta (author) in reply to Andrew546Feb 22, 2007. 11:46 PM
What the hell?!?! What is a dry wash? This is insane, you could make thermite with that eh
austin in reply to PunkguytaFeb 23, 2007. 5:39 PM
thermite is not made out of only iron its iron oxide. But with a few steps like rusting you could make ferrous oxide
Andrew546 in reply to PunkguytaFeb 23, 2007. 10:17 AM
A wash (AKA arroyo) is like a creek that runs only seasonally. In my case, this thing only has water in it 0-3 times a year. At all other times it a bone dry bed of sand with iron particles everywhere. Its only purpose it to drain water during flash floods.
Wikipedia knows all
Now I just need to get my hands on an etch-a-sketch or two and some magnesium ribbon.... :-p
Punkguyta (author) in reply to Andrew546Feb 23, 2007. 1:16 PM
Speaking of which, I actually started dremeling this iron off chunks of metal for that purpose, I wasn't planning on making ferrofluid, that would just be a waste. Do you think aluminum off a ladder would work? Cuz I got a old ladder that one of the metal feet fell off I'm sure no one would miss.
creid in reply to PunkguytaJul 15, 2009. 2:47 PM
Be extremely careful when you do this. Thermite is much hotter and much more dangerous than you think. You can order fine aluminum powder off of ebay as well as the iron oxide powder. If you're trying not to spend money find an old piece of iron, scrape the surface rust, wet it and set it out. should give you enough eventually. For aluminum powder a cheap harbor freight portable bandsaw (or use someones) with a fine blade and just cut away. A metalworking hobbyist reportedly accidentally created thermite with a bad outcome. People with my hobby watch out for that. Make sure it is aluminum. If it has a HARD surface it is either magnesium or a heat treated "aged" al alloy.
Andrew546 in reply to PunkguytaFeb 23, 2007. 1:41 PM
I mentioned etch-a-sketches because they use a very fine aluminum powder, but i suppose a ladder might work. Just seems a little time consuming. If only aluminum powder was as plentiful and easy to collect in my backyard as iron. *sigh*
jocket in reply to Andrew546Oct 29, 2011. 11:26 AM
If you have a Dremel or electric sander, then attack that ladder with it and soon you'll have a pile of aluminum powder. I use a belt sander with 80 grit
sandpaper and in 10 or 20 minutes I've got a big pile of aluminum on the newspaper I put under it to catch the powder.
Punkguyta (author) in reply to Andrew546Feb 23, 2007. 1:48 PM
I'm sure if it were magnetic, there would be "lots" to collect, but unfortunatly it isn't and even if it were, how would you know or even seperate the iron from aluminum. The world is full of "ifs" *shakes head*. How much are etch a sketches? Then again, I prolly shouldn't buy one because I would end up playing with it and never taking it apart :-). The reason I asked about the ladder is because I'm not sure if that would be pure enough aluminum.
moep in reply to PunkguytaJul 29, 2007. 1:54 PM
Yes, a ladder would likely be pure aluminum... so would a street sign or a screen door... but you're going to want something finer than filings for a proper reaction... it really should be a powder, and I imagine an etch-a-sketch is perfect for that.... Come to think of it, I never really realized that's what's in an etch-a-sketch, but it makes perfect sense now... Isn't aluminum powder controlled in some way? Do they still use pure aluminum in etch-a-sketches?
trialex in reply to PunkguytaFeb 27, 2007. 10:20 PM
Why are you bothering with Aluminium?
Andrew546 in reply to trialexMar 5, 2007. 3:00 PM
Thermite. It's a mixture of iron oxide and aluminum that makes molten iron and a nice fireworks show when lit on fire. In industry, its used for such purposes as welding train tracks together.
Moogle says: Feb 23, 2007. 9:16 PM
I collected a large amount of filings from a friend who was using a dremel to cut coils of steel wire to make chainmail. You can also clean the filings by doing pretty much what Andrew did and putting a magnet in a plastic bag, waving it over the pile to pick up the iron bits and dumping the rest, then invert the bag, pull off the magnet, and repeat a few times. I was dumb and used vegetable oil for my ferrogoo. Mineral oil should work better I'd think. Lately everyone's being lame and buying their rings for chainmail online. :/
FrenchCrawler in reply to MoogleFeb 23, 2007. 10:20 PM
I bought a chainmaille shirt (and coif) off of eBay like a year ago for $85 including S/H. My brother decided that he wanted to make one for himself this year and started making the coils on the metal rods and cutting them off with my dremel. He, of course, gave up once he realized just how long it was going to take him. I had started making a "machine" to quickly coil the wire for him, but never finished it cause he quit before I could. It would have also been faster if he let gravity cut the rings off the rod for him. This is more or less how far he got....
bears0 in reply to FrenchCrawlerOct 30, 2009. 1:37 PM
 what do you man by letting gravity do the cutting
beehard44 in reply to bears0Mar 23, 2010. 3:01 AM
lol uranium knife swinging down at the rings........
Punkguyta (author) in reply to MoogleFeb 23, 2007. 9:52 PM
Wonder if canola oil would work
Weissensteinburg says: Feb 22, 2007. 9:05 PM
Just to point out with your camera...it doesnt make a whole big difference, but when it comes to megapixels, its not the size that matters, but how they're used (the Image sensor). For instance, Nikon's D2H is 4mp, but alot better than the 10.2mp D200. And thats your photography lesson of the day :D
Punkguyta (author) in reply to WeissensteinburgFeb 22, 2007. 9:40 PM
Well I knew that much man, however, this is a webcam and any digital camera would take better and sharper pictuers than this.
reedz in reply to PunkguytaApr 4, 2009. 11:44 AM
tee-hee... my cell-phone has a 2 mega-pixel camera in it.
Punkguyta (author) in reply to reedzApr 9, 2009. 11:40 AM
Whenever I decide to re-write this instructable, it'll be done with 5mp pictures, and macros, mmmmmm macros. I bet your phone's lens don't let you do macros
bears0 in reply to PunkguytaOct 30, 2009. 2:28 PM
 my brothers camera has super macro
its a canon powershot A470
Punkguyta (author) in reply to bears0Oct 31, 2009. 8:55 PM
 the ironic thing is, I have a 5.2mp camera now, I should really update this instructable.
beehard44 in reply to PunkguytaMar 19, 2010. 1:42 AM
well, do it
Punkguyta (author) in reply to beehard44Mar 20, 2010. 11:22 PM
 Ok, I will! I also have a newer, better dremel.
ToastyTofu says: Mar 9, 2007. 10:50 PM
i love how everyone failed to remember beach sand.... you do understand that white beach sand contains a fair amount of iron?
Gjdj3 in reply to ToastyTofuJul 10, 2008. 7:53 AM
I almost did an instructable on this and how to make one of those magnetic face guys! Then my brother lost the sand. :-(.
master-of-chaos in reply to ToastyTofuApr 12, 2007. 5:15 PM
what we want is much more pure than beach sand also the only way to make beach sand into pure iron would be to melt off all the "glass" so all you got left is the iron which would take more heat time effort and a beach nearby
bears0 in reply to master-of-chaosOct 30, 2009. 2:30 PM
 or you could use a mortar and pestle to crush it off
at least thats on guy did in his instructible
j626no in reply to master-of-chaosMar 18, 2009. 3:22 PM
or...put a magnet in a plastic bag, run through the sand, flip the bag....you are left with a bag full of iron powder and a clean magnet.
Sandisk1duo in reply to master-of-chaosAug 6, 2008. 10:49 PM
lol, ive got like 10lb of sand which i brought back from San Diego, i'm too lazy to get the metal out of it!
xenobiologista in reply to master-of-chaosJun 10, 2007. 11:29 PM
The instructable on how to "mine" magnetic particles from sand is here: http://www.instructables.com/id/EGPTPN17FFES1764M3/?ALLSTEPS
brainspater says: Dec 26, 2007. 9:36 AM
that is cool but it dose it have a use?
Punkguyta (author) in reply to brainspaterDec 26, 2007. 6:47 PM
Yesm, but I'm not the one to ask.
joshuaism says: Nov 29, 2007. 10:30 AM
Personally I think the easiest way to get what y'all are trying to make is to go buy it. It's cheap. About 5 bucks for a pound of it. Just go to your local pottery supply and ask for the black iron oxide. Finely ground to the nanometer size, dry bagged and pure. Also some clarification on some matters. One cannot take larger clumps of molecules add some acetone, let the acetone dry out and be left with smaller clumps of molecules. The only way to get smaller clumps of molecules is to grind them, like with a ball grinder. Magnetite is Fe3O4, which is combination of FeO the first oxidation state of iron, known as ferrous oxide, or rust. It varies in color from yellow to orange to red, depending on how much water is molecularly bound to the FeO molecules. The black iron oxide Fe2O3 is known as ferric oxide. This is the stuff you want and is harder to get from the earth as it only oxidizes in an anaerobic atmosphere, i.e. underground, underwater, or in a fire.
westfw says: Feb 23, 2007. 3:37 AM
The problem is that for ferrofluid, you don't want "filings." You want particals so small that they'll remain suspended in the carrier fluid indefinately. (the technical term is "colloidal.") Magnetic tape yields very fine particles, I suppose. magnetic ink is probably somewhat coarser, so it's not quite as good (?) Ideally, you create the particles chemically within a fluid, so they never get a chance to aggregate into larger particles...
1-40 of 54Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
