Easy way to solder EL wire!
 by Bluelux
Featured
I'm working on my first EL wire project and I read lots of guides on how to solder the EL wire, all of them warning about cutting through the very thin radial wires that run outside of the phosphorous layer.
I tried a few times and it can be tricky, but I think I have a much easier way of doing it.
I'm not going to go into much detail about how the wire works or about the various layers that make up EL wire - I'm sure you will have read this elsewhere.
A couple of things that I found made this process easier (other than the usual EL wire tools) are:
 - Solder flux pen - helps the solder take to the wire and copper tape
 - Old computer CPU heatsink - by moving some of the fins closer together, it makes a perfect clamp for holding both wires while soldering, much better than croc clips because it doesn't damage the wire
 - Sharp craft knife - I use a knife to cut through the EL wire outer coloured coating (but not for the clear inner coating)
Step 1: Cutting the outer coating
I need my solder joints to be as small as possible for my project, so I only cut of 7mm off the outer coating, but you can cut more if you want to.
Measure what you need to cut and gently roll the EL wire with the blade, using just enough pressure to cut through the outer coloured coating.  If you cut slightly into the inner coating, this isn't a problem, so long as you don't go completely though both.
forte1994 says: Nov 4, 2012. 9:49 PM
Amazing job!!! VERY well done.. i was thinking of doing these mineature joints and evrywhere they use up so much of the el wire its crazy:P
tobychan says: Oct 15, 2012. 11:00 AM
What fantastic photographs as well! Highly detailed! Well done.
Spokehedz says: May 17, 2012. 7:18 AM
Wow. This should be a model for what Instructables should be like.
Clear pictures, showing more than one angle for each step. Each step showing a single step in the process. Explanation as to why you should do it this way, but also exploring other options. And finally showing the completed project as photographed--not another one that they made up ahead of time.
100% nailed it.
DieCastoms in reply to SpokehedzMay 17, 2012. 8:12 PM
100% agreed! Your comment says everything that my tired mind couldn't put into words tonight! The Ible is a great example of what an Ible should be!
DIY-Guy in reply to DieCastomsJun 8, 2012. 1:49 PM
Agreed, again! I've voted this a 5 star instructible based on my concurrence with SpokeHedz comments. This is well done.
t.rohner says: May 20, 2012. 12:22 AM
Very nice instructable. 5*
The idea with hot glue shavings inside the heat shrink is very clever.
I used to work on El ribbons.
Most of the time, i had to repair the inverters after the FET's smoked away.
DieCastoms says: May 17, 2012. 8:10 PM
Although I have never handled EL wire before, I HAVE handled plenty of heat-shrink and plenty of hot-glue, and am getting better with soldering now that I have learned the secret ways of the Flux Fairy. I've never thought of using both the hot glue and the heat shrink together, that is such a great idea!
You ible is very well put-together and based solely on it, I think I could confidently handle soldering wires to EL wire (especially if I started with heavier stuff first..). Your pictures are well done (Would you mind telling us what you used? Cellphone with home-made macro lens?)
Thank you for taking the time to post this Ible.
Mike, from "DC".
Bluelux (author) in reply to DieCastomsMay 18, 2012. 2:11 AM
Thanks Mike,
The photos were taken on a HTC Mozart with a cheap 10x eye loupe in front of the camera lens for the close up pics.
For example: http://www.amazon.com/3PC-EYE-LOUPE-3X-10X/dp/B000XGGF0U/ref=sr_1_12?ie=UTF8&qid=1337332126&sr=8-12
abraxas1 says: May 17, 2012. 9:47 AM
why apply hot glue while hot, give it a shave first! great idea for such delicate work.
is the finished project going to be an instructable?
thanks so much
Bluelux (author) in reply to abraxas1May 17, 2012. 4:23 PM
Thanks for all the positive feedback!
Not sure that I will make an instructable out of the final project - it's overly complicated and I wish I could start it again.
I promise to do one for the next EL wire project - by then I will have learn from my mistakes!
robbied says: May 17, 2012. 3:58 PM
You have made it all so simple. The website I have looked at to purchase some El wire made it sound like they had some difficult method or special tools to solder it. A well written, and high quality instructable.
agittins says: May 17, 2012. 3:23 PM
Really nicely done - some great tips there and not just for EL wire!
killbox says: May 17, 2012. 9:07 AM
Love your use of a old socket A or 378 heatsync as your helping hands!
djimdy says: May 17, 2012. 8:42 AM
Love the heatsink-as-helping-hands trick.
sharpstick says: May 17, 2012. 7:40 AM
You can get heat shrink tubing with hot glue inside it.
Another alternative would be squirting silicone sealer on before sliding the tubing on. Another layer of tubing over all with a stiff "batten" to prevent flex would also help. EL wire is very fragile if exposed to any movement.
verence says: May 14, 2012. 1:44 PM
Very nice 'ible.
GuiltyPixel says: May 12, 2012. 7:23 PM
Genius, thanks for sharing your hacks. The hot glue shaving bit is really brilliant.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
