Easy way to solder EL wire!
 by Bluelux
Featured
Step 2: 'Cutting' through the inner coating
The trickiest part for most people is stripping the inner clear coating off the EL wire without cutting the thin wires that run down the outside of the phosphorous core.   The first picture here shows those two wires under the clear coating.
To make this easier, I don't cut the coating, but melt it with the soldering iron!
Run the soldering iron around the inner coating where you want it cut it off.  The soldering iron will quickly 'cut' through the coating and will be done in under a second.  This does not appear to do any damage to the wires or phosphorous core and if far easier than using wire cutters.
Gently pull off the end of the coating and you should be left with something like I have in the third picture.
Remember, each time you do this, clean the soldering iron on a tip cleaner to get any plastic off the tip!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
