Remove these ads by
Signing UpStep 1: Supplies
beads
Crochet hook
Necklace closure, such as toggle set, lobster clasp, ribbon, etc.
Wire cutters or scissors
Small tip pliers, such as basic needle nose pliers or jewelry pliers if you have them.
Ruler or tape measure
For the specific pieces that I've made in the photos, I've used the following items:
-26 gge Darlee Craft Designer Permanently Colored Copper Wire, siver plated (for the necklace with blue pearls), or Gun Metal color as shown with the white pearls
-30 pearls for the necklaces (the navy pearls I used were 5mmx7mm, the white pearls are fresh water pearls in assorted sizes up to 10mm)
-12 10mm grey pearls for the bracelet
-small decorative bead caps if desired for covering the ends of your necklace or bracelet
-One metal toggle set with 2 small decorative metal beads for the necklace closure
-US H/ 5.0mm hook used. Size isn't critical, any medium sized hook will work.
-4 feet of 3/4" wide ribbon
Helpful: a bottle to hold your wire while you crochet.
Visit Our Store »
Go Pro Today »
1) tiger tail is flexible. Based on the few chain stitches I made, it seems to make it easier to crochet the stitches.
2) the stitches therefore are flexible and springy and hold their shape, vs the craft wire.
3) the craft wire can be manipulated when your necklace/bracelet is complete to bend it into a tube shape, or squish it to be thicker, pulled to be thinner, etc. The tiger tail is more likely to spring back into it's original shape if you try to squish it.
Basically, just differences in aesthetics/ design really. You might want to use crimp beads on the ends of the wire when you're adding your clasps to hold the ends of wire in place like you would finish a regular beaded necklace.
