iImage Information
I like to take apart my Nerf guns and tinker with them to maximize performance, and when messing with my two Strikefires, I discovered a pretty cool modification you can make. If you read, watch or play Devil May Cry, then you know that the hero, Dante, uses two guns: Ivory and Ebony. Ivory is customized to shoot fast, and Ebony was created to shoot long distances with accuracy. Well, you have two identical Strikefires, why not apply the same concepts? Just one word of advice: if you actually play dart tag and share your guns a lot, this may not be the greatest idea, as it makes the two weapons handle very differently. Also, for my own convenience, I only took apart the blue one. You should still get the idea.
Step 1Disassembly
iImage Information
So, when taking these guns apart, it's nice to have a small screwdriver set like the one I'm using. Just make sure you have a screwdriver small enough that it won't strip the screws. Carefully unscrew the screws on the slide (what you pull back), applying pressure downward so the head doesn't slip off the screw and cause damage. I'm assuming you will want to take them apart again someday. When they're all off, take the slide off. If possible, only take the part off that ISN'T connected to metal pin. Remove all the other screws and carefully remove the top half of your gun. You will the see the guts, as pictured. Repeat with other Strikefire.
http://nerfgunupgrader.blogspot.com/2011/06/nerf-dart-tag-strikefire.html
=3
http://www.hasbro.com/nerf/darttag/shop/details.cfm?guid=9C76C344-19B9-F369-D9E7-4ACA8F2F1EC7&product_id=25577&src=endeca
And this is a scout:
http://www.hasbro.com/nerf/n-strike/shop/details.cfm?guid=FE5DCD59-19B9-F369-D980-0443B171DF74&product_id=25715&src=endeca
(look at the left side of the final picture)
Scouts only come with the titan unity pack which is 50 bucks and so they are hard to come by but I think that they are the best pistol Nerf has.
Just a suggestion.
