3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Eco-Friendly Plant Waterer - Made From Recycled Bottles!
This Is a Simple,Efficient and Green way to Water your Plants.
Why Is It Green?
1. Reduces Plastic Bottles in Landfills
2. You Don't Over Water Your Plants (Saves Water)
3. Uses Natural / Renewable Resources (Rain)
4. Saves You $ Money! $ (By Saving Water)
How It Works:
When soil is wet, it is very dense. As it dries out, it becomes ready to absorb more water.As water in the soil evaporates and is used by the plant, it draws more water out of the supply held in the top reservoir, then into the bottom reservoir and out the holes.
In Simpler Terms:
The Water Replaces the Air Gaps in the Soil.
Therefore the soil Brings in or "Sucks" water from the Bottle.
Bonus!- When it Rains It Fills up the Bottles For You!
NOTE: When I made this Instructable it was Still Winter. So I didn't get to take any pictures of it in the Soil. (Because its Frozen) And any of the Hole Sizes Can Be Changed. Experiment to find the ones that work best!
Step 1What You Need...
What You Need...
You Will Need...
1. Drill and Drill Bits or Something to cut holes in plastic.
2. Hot Glue, Epoxy or Waterproof Tape
3. Scissors
4. 2 Bottles- One Small and Thin, One Large I.E Liter Bottle (I Didn't Have One)
24 comments
Jul 13, 2011. 12:36 AMvangan says:
You could use a lighter to put the caps together by connecting them when they are a little hot
Apr 18, 2010. 3:37 PMrera says:
I don't understand why you did all this work, I just put bottomless bottles into the ground.
May 18, 2011. 4:37 PMyuppersmainia says:
yeah i agree, the idea is cool but it's sort of a waste of time
Apr 27, 2011. 2:06 AMjwoo2023 says:
the height of the holes also determine how far the water flows from the bottle.
the higher the shorter the lower the longer
Feb 14, 2010. 8:26 AMyuppersmainia says:
this is cool i cant wait to out it in my back yard. just one question. If it rain why would you need it?
Apr 27, 2011. 2:07 AMjwoo2023 says:
good point! :D
Jun 15, 2010. 12:57 AMShallMaBear says:
Could I just drill some holes in a piece of PVC pipe, attach a 2Ltr bottle with the bottom removed, stick that in the ground where I wish to water, and fill the 2Ltr bottle???
Apr 23, 2009. 5:06 PMBrowncoat says:
Do you think SuperGlue would work?
Apr 18, 2009. 10:17 AMsolberto says:
Interesting idea to create a rain-trap with an underground reservoir. A few points I'd like to address. If the system depends on rainwater, wouldn't I be just as effective at trapping water by digging small channels directed to or encircling my plants*? I could also add 2" deep mulch around the plant/tree to reduce evaporation at the surface. *Trench in accordance to plants size and depth of roots. Then again, if there isn't enough rain, this is a clever supplement for "catching" and concentrating all you can especially for those plants establishing root mass. Another point: once the integrity of the plastic bottles begin to breakdown (not that plastic goes away (ex: Pacific Vortex), the home gardener can take the plastic bottles to the recycling plant --if one exist in your location. Also) If the DIY out there doesn't have a glue gun and drill or unable to borrow from a pal, you can create your seam with electrical tape available at any hardware store. Seriously, it is a vinyl tape (ie waterproof) which will stretch under tension and it works better when warmed up to 75(F). It will take a little exercise holding two bottles neck to neck as you go. Stretch the "black tape" 'til it begins to show "gray". If you stretch too much it breaks, but don't sweat it -just reapply and go! Start on one bottle and work it overlapping 1/3 each wrap. best results when finish tape job in center of taped area and not at edge. Finally, the plastic bottle system the above author created can be inverted and used as a heat (sol) and moisture trap for starters. Place the open end over your starters and push into soil. Once they establish roots, then you can flip the system over and bury the bottom section next to your row
Apr 16, 2009. 6:26 PMA good name says:
If you are going to upload an instructable, then don't bother if you haven't tried it out. I did it once, and when I did try it out, it didn't work. I've seen literally hundreds of these sorts of instructables that just assume because you can build something, it will work. Logic rarely works in real life. That's why America voted for Bush.
Apr 18, 2009. 9:39 AMA good name says:
Ah, okay, thank you for clearing that up.
Apr 18, 2009. 9:40 AMA good name says:
NOTE: You can also put socks in the bottom bottle to make it retain moisture
Mar 15, 2009. 1:02 AMHolden_vy_s says:
Wont the dirt end up going through the holes over a period of time?
Mar 16, 2009. 10:40 AMpeanutbutterancheese says:
yeah, but unless your soil is extremely liquidy mud, it won't fill the bottle up much. a few cm of dirt in the bottom of the bottom bottle won 't make much of a difference, after all. incidentally, this is also a very good system for liquid fertilizer application. I use fish fertilizer and compost tea with a similar system, and it's pretty spiffy.
Mar 14, 2009. 6:47 PMvincent hua says:
Great idea! But i afraid it will breed mosquito if the water in the top bottle is dirty.
Mar 15, 2009. 7:09 AMrimar2000 says:
Don't worry, that water does not last much: it is absorbed by the earth.
Mar 15, 2009. 7:06 AMrimar2000 says:
Good idea. I did something similar (only the top, and a pipe that went under the ground) to irrigate a small willow, and gave me good result. It is much more effective than normal Irrigation.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:I Got A Cup Productions
Im Just A Guy.... Heavily interested in Engineering and a Huge Geek/Nerd/Hacker. FYI - I dont Hack Illegaly. I like to work on electronic projects in my spare time. So if you need some tips mess...
more »
