3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Eco Office Rocket: Build a Rocket from Trash
Don't throw away those old papers. Turn them into a rocket!
Whether you're just bored at work or want to have your own 'space race' at the office while your boss is on vacation, the Eco Office Rocket is for you. It's a great way to kill time, recycle trash, and take a break from a your day-to-day activities.
Step 1Materials and Tools
Materials and Tools
Materials:
4+  Sheets of paper
1     File folder or similar sturdy paper
1     Plastic bag of any size
1     Sheet of toilet paper
1     Good rubber band
1     Paperclip
1     Pen
Tools:
Ruler (print one)
Scissors
Tape
7 comments
Nov 20, 2011. 8:54 PMchuber3 says:
Running a "bead" of super glue around the nose cone end of the body tube will help both stiffen and "toughen up" the tube with out adding a lot of weight. This will help to keep your recovery system from Zippering your body tube.
Nov 25, 2011. 7:29 PMsokamiwohali says:
If you did that you would blow up the rocket when the ejection charge ignites OR you will blow the motor out of the rocket and no parachute will deploy. which according to the NAR is illeagal.
Apr 3, 2012. 3:22 PMI luv Duct Tape says:
no its not. estes produces alot of "tumble" recovery rockets ei. 220 swift, quark, etc.
Apr 4, 2012. 1:19 PMsokamiwohali says:
there is only a couple rockets that estes make (or used to make) that are TRUE "tumblers"...i cannot remember the name of it, but it had small sections of plastic tubing that interlocked with each other and connected by a shock cord...that is a break apart tumbler...perfectly legal in accordance to the National Association of Rocketry (NAR). that kind is legal because its design prevents it from completing the apogee in a nose down dive (which...is illegal according to the NAR). the "tumblers" that estes makes ALL have some sort of streamer to slow the rocket's descent, and to keep it from going into a nose down configuration. plus those rockets you mentioned dont have the same power as a standard rocket motor would have.
Oct 30, 2011. 5:51 PMal_packer says:
Commercial model rocket engines have several big advantages: They are consistent--same thrust and same duration from one to the next. They incorporate a reliable recovery mechanism--same delay and same ejection charge from one to the next. They don't require you to mix highly flammable powders and pound them into a tube (do you know which metals are non-sparking and which to avoid?).
Sshuggi's instructable is really true to the roots of model rocketry. Back in the beginning you HAD to make your own body tubes, because there were no ready made ones available. So a big thank-you to sshuggi for taking model rocketry back to its roots.
Aug 8, 2011. 1:47 PMjavajunkie1976 says:
Instead of buying rocket motors and keep it within the materials found in an office, why not make this a sugar powered rocket?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:sshuggi
