Eco Silver Polishing
A quick and easy way to polish oxidized silver jewelry and other stuff without using toxic* chemicals.
This technique is especially good if you have intricate filigreed jewelry for example.
*or at least they don't SMELL toxic. Are they?
Step 1Put baking soda and foil in water
I put about 1 tablespoon of baking soda and a piece of foil about 4" square or so.
Boil it until the silver starts to look silver.
(Unfortunately this doesn't clean my burnt up old pot) ;)
34 comments
Jan 1, 2007. 2:55 PMlemonie says:
I'm interested in the "black part on the leaves - is intended to be black". Could you explain how this is intended & produced? Also, excepting cutlery & eggs, I had not thought pure silver that prone to tarnishing(?). (Caustic soda can work wonders on tea & coffee pots)
Feb 10, 2011. 10:55 PMpaqrat says:
According to a long time jeweler pure silver doesn't tarnish. It is the copper in the alloy that allows the alloy to tarnish. The problem with the pure silver is its softness. In ring form it would probably deform each time anyone gripped anything. He told of making a silver ring that would not tarnish. He took a regular sterling ring and left it in the pickling pot for some time. The acid in the pickling pot dissolved the copper from the alloy leaving the surface of the ring pure silver. Then he put the ring in a tumbler with steel shot and tumbled it. The steel shot pummeled the ring hardening the silver surface. So he ended up with a sterling ring with a hardened pure silver surface. Best of both worlds.
Intentional blackening on silver can be produced by liver of sulphur.
Feb 11, 2011. 7:16 AMlemonie says:
Old question, but thanks for filling me in on those details.
L
Feb 12, 2011. 7:01 PMpaqrat says:
Oops. I forget to look at the date on these things. Glad I could supply some info.
Apr 16, 2007. 5:10 AMironsmiter says:
This is replying to an old post, I know, but in case you're tracking, or to those new to instructables Liver of Sulphur(smells like rotten eggs) is the "main" chemical concoction used to patina silver to a nice matte black. It's usual use is being painted on, then polished off of the high spots. The black matte color provides high contrast to the brightly polished bits and pieces. There are plenty of other chemicals that produce different colors. Most chemicals react simmilarly, regardless of the metal, but there are special chemicals to produce almost any color, on most metals...penut oil, and heat produce shades of brown... amonia produces green to blue, debending on the base...
Feb 10, 2011. 11:02 PMpaqrat says:
I was just wondering if anyone has tried doing this with an aluminum soft drink can. No foil just the can, sodium bicarbonate and boiling water? Does anyone know if the inside of these cans are coated in any way? If it would work it would sure make cleanup simple. Just pour out remainder of liquid and toss the can into the recycling bin.
Mar 11, 2008. 5:08 AMVery Keri says:
Is this process safe for stones? I have some antique silver stud earrings with an Amethyst in them, I wouldn't want to harm them since my Grandma has entrusted me with them. FYI, same Grandma says the best way to clean stainless steel pots is to make a paste of equal parts baking soda and salt and scrub the heck out of your pans with a scouring pad or steel wool. It really does work, it gets my pans back to their original luster. I'm not sure what the baking soda does, and I'm sure the salt is just an extra abrasive, but it really gets EVERYTHING off your pans. Just for the love of god, only do this with stainless steel!
Feb 10, 2011. 10:38 PMpaqrat says:
Chemically I don't think it would harm the stone. If the boiling water is poured onto the earrings I would be concerned about the expansion of the stone particularly if there are small cracks or flaws in the stones. If the water, w/ earrings in it is slowly brought to a boil then allowed to cool slowly I would be less concerned. What you want to avoid is rapid temperature change. Taking the earrings from boiling water and quenching them in cold water would be a very, very bad idea.
May 29, 2008. 3:20 PMGoodhart says:
it, of itself, should not hurt the stones themselves. But if they are loose (in the setting) they could come free in the hot water since the metal and stone expand at different rates.
Aug 26, 2010. 8:08 PMPosterGrampa says:
Made my wife happy not having to polish all our silver ware and other silver stuff in our home. Regards,PG
Aug 16, 2010. 11:40 AMtheblindferrengi says:
Will this work with aluminium powder instead of foil? Perhaps better because the powder has more surface area and better coverage of the silver.
Jul 19, 2010. 7:22 AMcordelya says:
For this to work well, your silver should be touching the foil. I usually lay the foil flat in the bottom of my basin and sit the silver item on top of the foil. The reaction is electrochemical and the two metals need to touch in order to complete the circuit. See this page for an explanation of the reaction, including the formula: http://scifun.chem.wisc.edu/homeexpts/TARNISH.html
Jul 7, 2010. 8:47 PMkkarn says:
This is a variation on how museums clean silver. Not only is it a more green way to clean your silver jewelry and/or flatware, it's more gentle too.
Dec 23, 2009. 3:50 PMGoodhart says:
There are 2 types of polish out there.
Those that are abrasive, as the one you have described, and those REALLY toxic ones that restore the silver.
It is important to note the difference.  Any "polish" is probably abrasive, so each time to you use it, you lose silver.  With the  "dips" that restore the silver, you lose only the oxidation of the silver, and retain the silver itself.
If you are "polishing" silver Plated items, it would be best to dip them and restore the silver;  if you Polish them,  after only a few times, there will be no silver left and you will be down to the base metal.
If you decide to dip, PLEASE be careful....the chemicals ARE TRULY  TOXIC
Nov 12, 2009. 8:35 AMcontainer_gardener says:
I've read about this method, but I didn't try it until I saw your Instructable. I cleaned some sterling silver filigree jewelry. Its great because its cheap and non-toxic.
Dec 12, 2008. 2:14 PMbreinke527 says:
Ok what am i doing wrong? I boiled my silver in a pan with 1tblspoon of baking soda and it actually turned black!!
Dec 10, 2008. 6:43 AMmeme_mhr says:
beautiful idea thanks
Nov 6, 2008. 6:24 PMdhawktx says:
I've used this for quite a few years now. Hadn't thought to post it here - Great thing to share! Make sure you don't use this on stuff with organic bits (pearls, shell) or porous mineral-y stones like malachite, turquoise, etc. It's safe for quartz stones like amethyst, blue topaz, citrine, etc if you don't get it too hot then rinse it in cold water.
May 13, 2008. 2:33 PMFenris The bbw says:
The reaction smells sulfurous. I wasn't expecting that. Great instructable.
Mar 21, 2008. 6:29 AMlazemaple says:
Keeping the solution hot is enough... boiling could damage some jewelry or stones. I use hot tap water and keep it warm with a cup warmer.
Jan 29, 2008. 5:14 PMBright Shadow says:
Does this only work on silver? If it works on stainless steel, I know what I'm gonna be doin! ;)
Nov 17, 2007. 2:34 PMcowscankill says:
"boil it until the silver starts to look silver" what??
Jul 28, 2007. 7:32 PMtheodorehope says:
The tarnish is silver sulfide. The electrochemical reaction makes the sulfur go over to the aluminum, so you end up with aluminum sulfide and the original silver is nice and clean :-)
I've used this process for quite a while and it's great. You don't _have_ to have boiling water, but it's faster that way.
The process is described here:
http://scifun.chem.wisc.edu/HOMEEXPTS/tarnish.html
Jul 27, 2007. 11:36 AMandrea313 says:
kaytracy: is this with the baking soda & water, or is it just foil (and water?). Sorry to be dense.
Jul 7, 2007. 6:09 PMkaytracy says:
not really any need to boil it, I use a glass pie plate and lay the item on top of the foil. Leave it sit while you go back the "puter for another instructable, andthen go rinse it off. I used to have to use the cream to polish the silverware when grandmother would come to visit, I like this method much much better! K
Dec 21, 2006. 8:53 PMcrestind says:
Interesting. I suppose this involves some sort of chemical reaction.
Dec 21, 2006. 8:25 AMbhagyesht says:
just make sure that you dont try this in an aluminium utensil, else you need to get the mess of the pot then, Stainless steel is fine.
Dec 20, 2006. 11:47 AMLasVegas says:
While I agree that this is probably one of the best ways of cleaning Silver. It actually does use chemicals; Aluminum and Sodium Bicarbonate. Thank you though for not doing what some would and clean that piece until there's no trace of tarnish. The bit that you left is what gives it its character!
Dec 20, 2006. 8:09 PMLasVegas says:
Definitely! :)
Dec 20, 2006. 2:45 PMTheCheese9921 says:
is this just the same thing as those silver lightining things or whatever (they were on g4 in the morning)
Dec 20, 2006. 7:39 PMTool Using Animal says:
Yeah it's the same thing, but closer to free.
Dec 20, 2006. 4:14 PMzachninme says:
Probably, just as those rods to remove the smell of garlic off your hands is stainless steel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:susie(Susie)
My LED (I mean flashlight) Gummies profile photo is inspired by the LED Throwies.
