Recycled Off-Grid Tesla CD Turbine Power-Boost Blender
The movie below shows successful at-home use of this Tesla CD Turbine Blender.
Recirculating Tesla CD Turbine with Air Turbo-Boost
If this video does not play, click here instead
This instructable will show how to make an off-the-grid, Tesla turbine-powered blender made from many recycled parts.
It runs on a self-powered, re-circulating system from the forces of Earth(magnets), Wind(compressed air), Fire(solar) and Water(pressure)!
In tough times or times of disaster, we might need to make McGyver-like contraptions, with the things we have on hand, in order to survive...or to have fun!
Ok, let's say the electric grid power is out...you couldn't pay the bills, or there's some other disaster...but you wanna party anyways.
You need a blender for the party...
You could use a 12 volt battery, with a 120 volt inverter, and simply plug a regular blender into it as an easy solution.
But, hey, why not make a recycled Tesla CD Turbine Blender,
on a self-powered, re-circulating set-up?
With a cool foot-operated, air-powered, Power Boost function for tough blending chores!
From wikipedia , "A Tesla turbine consists of a set of smooth disks, with nozzles applying a moving gas to the edge of the disk".
The Tesla CD Turbine I make is made with recycled CD's, CD spindle case, supermagnets, a nozzle and glue. I have 3 previous instructables that deal with it's basic construction.
This powerful, magnetically-coupled Tesla CD Turbine Blender is different because it works "off the grid", and because it uses recirculated water pressure and air pressure...at the same time!
The way it works is that a solar panel charges a 12 volt battery, which powers a 12-volt air pump and a 12-volt bilge pump. The water pump sits in the recirculating bucket and makes water pressure for the turbine to run.
Compressed air is stored in a tank, which has an air line going the foot-operated valve. An air blast gives additional power and torque to the turbine when required, by way of the foot valve.
Can a Tesla CD Turbine, made of recycled CD's and glue, develop enough power from solar-powered air and water pressure, to perform as a portable blender??
The answer is a resounding "Yes!" (See movies following!)
Any turbine on air pressure can be dangerous. I have added a polycarbonate protective cover over the turbine for personal protection. Something similar is mandatory when using compressed air with the CD Turbine, because of the possibility of CD discs or case exploding at high rpm! (see my warnings in other instructables and movie below of explosion! )
Have fun and blend safely!
I always order from the best selection of neodymium super-magnets from K&J Magnetics here.
The following shows some preliminary testing of the concept of combining air and water pressures in the CD turbine at the same time.
. Tesla CD Turbine Experimental Test Combining Air and Water
If this movie doesn't play, you have a Mac and click here
The following shows the possible result when excessive back-pressure, and an over-exuberent throttle foot, combine with such a funky, recycled, CD cakebox system! (Lesson learned: Don't turn on the air pressure too fast!!)
If movie doesn't play click here to see.
Here is my latest movie of a Science Fair display with the portable re-circulating system:
Step 1Parts List
Parts List
Parts Used for This Instructable
1 - Basic Tesla CD Turbine (see my previous instructable, "SinkScience with the Tesla CD Turbine" (About $50.00 to build)
1 - Magnetic Coupler from my previous instructable (Cost... about $20.00)
Order the BEST neodymium super-magnets here:
http://www.kjmagnetics.com/default.asp?PARTNER=mrfixitrick
Additional supplies and parts required for this instructable...
1 - Blender, from thrift shop, $1.00
1 - Protective shield (I used 1/8 inch x 6 inch polycarbonate tubing, 7 inches long)
1 - 12 volt Water Pump, (on hand, but generally about $50.00)
1 - 12 volt Battery, or series of batteries for 12-18 volts output at 5 amps.(on hand, or used $20.00)
1 - Solar Charging Panel, 12 volt (new, $30.00)
1 - Compressed Air Storage Tank ( on hand, or $30.00 new)
1 - 12 volt Air Compressor ( on hand...or $50.00 new)
1 - Garden Hose Foot Control shut-off valve (on sale, $6.99)
2 - short garden hoses (on hand)
2 - air hoses (came with tank)
1 - Y-connector for garden hose ($2.99)
- misc - air fittings: T-fitting, adapter to garden hose
- Pressure gage (optional)
- Tachometer (optional)
73 comments
1-40 of 73next »
Nov 23, 2010. 10:14 PMmikesnyd says:
I have just watched your video (at the science fair video) with you describing what is happening with a ball bearing on top of plexyglass. You said to make a comment if you wanted too and i think i want too. So i have no knowledge or college degree in this field but here is a guess as to why this is happening.
To pair it with the optical illusion of a car tire. You watch a car tire at slow speeds and it look like it is rolling forward(Clockwise). At high speeds the car tire looks to be rotating backwards(or counter-clockwise). So you have a magnetic feild doing almost the same thing but with a variable. It would be the weight of the bearing. As the tesla coil begins to spin at a slow rate the ball bearing may proceed in the same direction as the coil. At some point the coil will be going faster then the bearing can travel. So thats where the reverse happens. The bearing is the visual illusion of the tire. I mean we cannot process what we are seeing fast enough so it looks like it is going backwards. To the same respect the bearing cant stay with the magnetic field and thus falls behind. I could be totally wrong but it just a complete guess. I am thinking of making two of these coils but a little better built(more metal parts) and putting a fixed stator between them. I dont know what will happen but i think i could get a fair bit of juice out of a 12" dia tesla coil using 2"x2"x1" N42 magnets on my top layer and 6 phase Stator as 70 turns of 14 gauge enameled wire. i wonder what will happen.
Oct 27, 2010. 12:25 AMbeehard44 says:
damn. I tried making a turbine and when i tested it over the sink, the hose disconnected from the faucet and water sprayed all over me. And i hit my head on the cabinets above the sink, ouch.
Sep 17, 2009. 1:53 PMBlackice504 says:
Mrfixits you really need to look at water hammer pump it uses no power at all it just uses a little down ward force and then feed that into your Telsla turbine and you can even have a setup where it uses dirty water to run the hammer pump to high pressure clean water.
Mar 28, 2009. 1:37 PMJBz says:
Wow! Yikes! Shazam! Pardon me while I experience a brain meltdown. Just a thought about your tinfoil beany. I am trying to find out if the mind control rays are radiating up through the ground, instead of through the ionosphere. Wearing a parabolic reflector on your head would concentrate the rays in your cerebral cortex....just where you don't want them. So the proper safety precaution would be to connect yourself to cable grounding straps, like they used to do with cars. This might require wrist and ankle straps, and probes in body orifices, and might be uncomfortable. Possihly attaching inverted metal colanders to shoe soles might serve the purpose as well-reflect the waves back at the senders, thereby melting their brains. Back to more mundane topics. Magnetic coupling is the forte of a guy from my neck of the woods. Jerry Lamb developed a coupling patent which was bought and marketed by a company named MagnaForce in Seattle. Would their design be of use in your device? In addition, I am curious about developing an Acme high efficiency superconducting/diamagnetism generator to be powered by a rotating clothes line pole. This will require clipping the clothes to the lines to catch the wind, then swiveling to feather on the backstroke to avoid a braking action, which is the downside of vertical wind turbines. The instructables on clothes drying energy efficiency might be useful in developing this concept. Meanwhile, I will continue to boggle at your gadget, and try to understand it as I study the videos. Thanks for the great instructable. The only concepts you haven't tied together for me are hyperdimensionality, the face on Mars, the Nazi Bell and Nazi ufos.
Aug 10, 2009. 8:08 PMpoulbran says:
you sound very smart so whould this work thanks ,Brandon
Mar 31, 2009. 9:55 AMJBz says:
Hey Rick, Thanks for the information. I'm doing some 'energy hack' research right now for a local nursing home. This place has loads of wasted heat from clothes dryers, walk in fridge and freezer, and almost no hot water in parts of the building. I keep wondering about cogeneration, energy conservation and energy scavenging. How would a guy who comes up with a Tesla Turbine from scavenged parts make a school or other large institution more energy efficient? Meanwhile, I'll check out the Tesla group. When you get your flyer going, do a flyby over the Olympic Peninsula. I think I'll stay away from 'Spirit Radios' until someone can check out who's sending the messages. John
Apr 2, 2009. 8:35 PMJBz says:
Plans! Ineed Plans! Or even an instructable! To start the ball rolling, I need a quick fix energy scavenging hack. If it's quick, inexpensive, safe, makes the administrator look good at corporate, yeehaa! I'm looking for a 'rock soup' method to introduce corporate types to the concept. This is based on the bum who talks his way to a farmhouse kitchen by asking to make 'rock soup'. He puts some water in a kettle to heat, and puts a big rock in, then asks for some veggies to flavor the rock, then some meat to flavor the veggies, etc. When the soup is done he throws the rock out. So to get my nose in the door, I need something simple and speedy. Today the scavenger hack, tomorrow the vortex disintegrator!
Apr 12, 2009. 10:28 PMJBz says:
Thanks for your ideas and the thought about the Rock Soup story. Anyway, energy scavenging, or conservation, will be crucial in the days to come. Maybe you can come up with a superconducting generator/supercap magnetic coupling system that will take us to high levels of energy efficiency. I kind of expect that Wally Minto's wheel will be a great place to start with energy scavenging. There is a lot of information and speculation about this, but no one has built a large one that works. Any ideas?
Jun 3, 2009. 10:59 AMblackbeardlion says:
who needs a blend-tech blender when you can have a tesla turbine blender! awesome instructable!
Apr 14, 2009. 4:12 PMJupitane says:
Cool! Too bad the video doesn't work......
Apr 14, 2009. 4:13 PMJupitane says:
Just another reason to make it! =)
Oct 30, 2008. 6:55 PMlilshawn says:
i fail to see how this could be "eco-friendly" as the ammount of power consumed by the air pump and your 12 volt battery (which would have to have been charged for several minutes by a battery charger or car) would use less power than running a regular blender for the 20 seconds it would take to make a smoothie. cool, interesting, ingenious? - YES eco-friendly, energy efficent? - NO
Mar 29, 2009. 2:47 PMLightAnvil says:
Nice 'Ible, and thanks for sharing it! Have you considered this: Using the water main as a source, every time you would run a tap or shower, etc. you would generate electricity which could be stored and used in the home! Costly to setup but who doesn't like free electricity?
Oct 30, 2008. 10:33 PMlilshawn says:
okay now we are getting someplace - please reference the title of this Instructable "Eco-friendly Tesla CD Turbine Turbo-Boost Blender" eco meaning economy and friendly meaning.... friendly. soooooo we are helping the economy? I guess sort of. anyway. now to power the electric pumps, a car battery is used - to have had that battery charged either by 1: a battery charger or 2: took it out of a vehicle that used fossil fuel to charge it. using DIRTY DIRTY grid power and/or DIRTY DIRTY DIRTY fossil fuel. (chances are the automotive store does not charge their batteries with solar panels) yes I know the power put there by the big corporations who pride themselves on destroying the planet is long gone, and has now been replaced with super friendly solar energy, but by simply making the system more efficient, you could almost run the system entirely on solar. I have a real problem with cd's as they take an enormous amount of energy to produce them in the first place. Recycling GOOD (otherwise would have been thrown out to a landfill) you can argue for a million years about good energy clean energy eco friendly whatever but the way I see it, it would take years to "pay off" the energy it takes to produce 1 solar panel. I'm still perfectly content living on the grid and help the environment by conserving power and walking instead of driving. I buy rechargable batteries, I choose to fix or repair items instead of throwing them out. besides - what's wrong with nuclear power anyways... uranium produces heat - heat produces steam - steam drive generators - generators produce electricity - ALSO little did you know about 20% of the electricity you use in your house is supplied by nuclear. steam coming out of a cooling tower - that seems pretty green to me. sans the waste. how about hydroelectricity - water flows through turbines that drive generators. sounds green to me (7% of your electricity is hydroelectricity.) don't even start about fish and environ-mental impact. the USA uses mostly coal (49%) power producing practices - I live in Canada, I guess since we all burn whale blubber to keep warm, I'm not familiar with the whole corporate machine. we only use 33% of our power through renewable resources and only 12% on coal but produce 44% of our total output by renewable means. and we still have enough leftover to sell to the USA during those cold winters and hot summers. truth be told every little bit helps, but also too little too late. guess that's why we pay 5.25 a gallon for gas. you have a lovely nick-nack to show off to your friends during parties to make enviromargaritas. now if we can only build a perpetual motion machine.....
Nov 9, 2008. 10:04 AMPlasmana says:
Wow! Really cool instructable!
Nov 11, 2008. 1:53 PMPlasmana says:
Thank you! Yeah, I want to do more experiments, but I have no money after building the plasma speaker project...
Nov 5, 2008. 3:17 PMAnarchistAsian says:
oooohh, nice, you've got my vote! i've got an entry too!
Nov 5, 2008. 4:31 PMAnarchistAsian says:
Thanks to you! i like this simple start, but i think it would be just amazing if you could make one as good as those compressed air power tools you see at hardware stores.
Nov 5, 2008. 7:45 PMAnarchistAsian says:
oooohhhh!!!!
nice, i think eventually i'll make a small one, with disks cut out of acrylic sheets.
but first i have a bunch of coil guns, and pneumatic guns i need ok, want to make...
Oct 31, 2008. 8:05 PMitsme16688 says:
how is this eco-friendly??? did you not hear that the world is running out of water? ... where do you think the water comes from??? just magically appears in your plumbing?
Oct 30, 2008. 10:29 AMcowscankill says:
Hello! I'm at school right now, and I am using this as my science project. If you ever have any modifications, you know, simple things, then I would like it if you PM me. I know your more finished ones look very different compared the ones in the instructions. P.S. I am going to use water pressure from a faucet so I can use it in class. I still do not know what is wrong with my magnetic coupler. It stops the turibine everytime the magnets line up...
Oct 30, 2008. 1:40 PMcowscankill says:
WoW! Thanks for the tips! So I can get good rpm by restricting the nozzle in my science class, use no outlet hose, just straight in the sink. I never knew the magnets had to REPEL LOL. I always thought they attracted. How does it stay on when repelling? Science.. It's great. That reminds me... I have an essay to right....
Dern, it didn't work with repeling fields either. It didn't spin at all.
Oct 30, 2008. 1:17 PMcowscankill says:
1-40 of 73next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
229
Author:mrfixitrick(Mrfixitricks Youtube Channel)
I am re-inventing myself as an inventor, after too many years as a mechanic! I enjoy learning from Tesla disc Turbines, magnetic motors, and Crystal Quantum Radios. "All children are artists. The ...
more »
