Step 2Materials And Tools
- You should be able to wire an LED to light up and not burn out.
- You should be able to use a rotary tool with some precision without causing irreparable damage to yourself or others.
Materials and Tools:
- Clear plastic. I recommend this polyester sheeting from McMaster-Carr. (Thanks EMSL!) CD cases will also work, but they tend to chip and crack.
- LED(s) 3mm or 5mm, any color, though the brighter (more mcd) the better. The white one used in this tutorial is a 6000 mcd 3mm.
- Power source for LED. If you don't know how to power an LED use this calculator to find out. You can also use a CR2032 button battery.
- Rotary tool A Dremel or similar with a fine grinding bit to carve or etch your plastic. A needle or craft knife will work in a pinch. If you're using acrylic you can laser etch, but the polyester sheets will just melt. CNC mill would probably work great.
- Craft Scissors (aka: Not the good scissors) To cut the clear plastic. A saw, hobby knife, or rotary cutoff disc can work too. (Don't use scissors on CD cases or other acrylic, or it will crack.)
- Aluminum tape Usually sold in the hardware store in the HVAC department to seal ducting. You can also use plain black electrical tape, but your display will be dimmer.
- Safety equipment. Yeah, I know, it's no fun, but eye protection is a must when using power tools. And I recommend a breathing mask too.
Time:
- About 10-30 minutes, depending on your tools, materials, and the complexity of your design.
I just had a query about the engraving tool. There is a special tool by dremel called the 'engraver'. does it work on acrylic?
I dont have the rotary tool by dremel either.. So planning to buy the right tool..
Kindly comment on what tool should work well...
Thnx!
