Edison-Smoke-Human-Detect System Using Twilio (Python)
Published
Introduction: Edison-Smoke-Human-Detect System Using Twilio (Python)
Connect motion sensor and infrared detection sensor to count people entering a room. Use smoke sensor to detect smoke/fire. Send text to cell phone using Twilio API to inform about smoke.
Step 1: Flash Latest FW Image
Copy the FW image files to Edison.
Check the COM port for Edison
Connect using Putty
Then on Putty Console - reboot ota
Connect to Wifi - configure_edison --wifi
Set-up root password - configure_edison --password
opkg update - to get the list of packages
opkg upgrade - to update the packages
Step 2: Add the Base Shield From the Grove Kit
Connect the base shield provided in the grove kit so that the other sensors can be connected. Connect the Infrared detector to D0. Connect the display to the I2C connector.
Step 3: Install Pip and Twilio Python Library
Follow the below steps on the Edison console -
wget --no-check-certificate https://bootstrap.pypa.io/get-pip.py
python get-pip.py
pip install twilio
Step 4: Send Text Using Twilio Library
Create an account on Twilio and get an auth key. Use the python example to send a custom message when object moves or some other sensor condition.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
