Editing in Cube 2 pt. 1
 by Fengathor
Step 1: Things needed
You don't need much to start mapping in cube 2, but here is what you need to start.
Cube 2 Sauerbraten
a keyboard
a mouse
and an idea
Step 3: Baby steps
Alright, we have an empty map and our pistol, but how do we edit?
To go into editing mode you hit the e key, your hudgun and hand will disappear and you will be able to fly around the map.
Now, this is all well and good but how do we actually build the things?
With a left click you can select the current face of the cube you are looking at, to "pull" up on that face scroll back with the mouse wheel, to "push" in on it scroll forward.
You can push and pull on any face of a cube, if you pull up a single cube and push in on a different side, the cube will disappear.
Also, you don't have to select a cube scrolling with out a selection will edit whichever cube and whichever face the crosshair is on.
Note: by clicking and dragging you can select multiple faces/cubes
Step 4: More face work
Next up I'll show you how to make slopes and distort the cubes to different shapes.
To do this you simply middleclick on any corner of a cube, and scroll like you would to create a cube, but instead it will deform the portion of the cube. You can push any corner to the opposite corner, and by middleclicking and dragging you can edit multiple corners at once.
Note: selecting all four at once is the same as selecting the face.
Step 5: Grid size
Now we can make cubes from other cube and turn our cubes into...un-cube like shapes, but theres one more thing to know before moving on to painting your work.
Grid size affects the size of the cubes you're working with. To adjust grid size simply hold the g key and scroll. Editing from there is the same as before, just on a larger scale.
Step 6: Texturizing
Not quite sure if I made that word up or not, but by texturizing I mean painting your cubes to look like grass, sand, or fancy detailed walls. There are a couple ways to do this you can select the cube and hold y while scrolling, to see the textures as you go. Or you can use the texture selector by hitting F2.
Going through the selector is simple, run the mouse over a number to move to that page, and click on a texture to apply it, then hit F2 to close the selector window.
Step 7: Final Recap
So as you have seen editing in Cube 2 is a simple process when you know what you are doing.
These are just basic steps to get you started on building your own maps for this game.
Here are a couple pictures of some stuff I've made.
[EDIT:] So as was pointed out in the comments, I forgot to mention how to save.
To save your new map, hit the / or ~ key, and in the bottom left of the screen a command prompt will appear. type savemap mapname and hit enter.
The command ends up looking like /savemap test
Sorry for forgetting that before.
Thanks for reading this instructable, hope it helps you.
If you want to learn more you can check out the Cube 2 wiki
Landon Sullivan says: Jul 22, 2009. 1:06 PM
This wouldn't happen to work with the original Cube or AssaultCube, would it?
______ in reply to Landon SullivanNov 23, 2011. 12:14 PM
It will work with Assault Cube I play the game.
Landon Sullivan in reply to ______Nov 23, 2011. 2:09 PM
Way to necropost.
Fengathor (author) in reply to Landon SullivanJul 25, 2009. 7:47 AM
I'm not sure, I've never used the original cube but I assume it's similar
AlternateLives in reply to FengathorAug 19, 2011. 3:08 PM
The original Cube does have an editor that works similar to this, but I personally find it a pain in the rear to work with in comparison to Cube 2. You're better off sticking with Cube 2.
AlternateLives says: Aug 19, 2011. 3:04 PM
Here's a work in progress. it will be a steel mill when I'm finished.
zombies are annoying says: Jul 23, 2011. 1:34 PM
I got cube 2 just for this purpose! btw how do you make water?
Fengathor (author) in reply to zombies are annoyingJul 23, 2011. 3:06 PM
To make water, you make your selection like you would normally, but before you remove cubes. Hit f3 and select water, it'll replace that layer with water. Though for every layer of cubes you remove, you have to hit f3 and select water again, otherwise it's just a little bit of water over an empty space.
zombies are annoying in reply to FengathorJul 23, 2011. 4:38 PM
AlternateLives in reply to zombies are annoyingAug 19, 2011. 3:03 PM
you can also type /water for water.
fauge7 says: Dec 31, 2010. 6:41 PM
how do you save
Fengathor (author) in reply to fauge7Dec 31, 2010. 10:22 PM
:o Thanks for pointing that out. You hit / or ~ then type savemap mapname.
So the command would look like /savemap test
hg341 says: Oct 17, 2010. 5:15 PM
this looks like fun im going to download it a school
zack247 says: Jul 27, 2010. 10:29 AM
i had cube once, but a short while after i got it, my computer had lots of viruses (i may be suspecting cube, never figured out the source) the computer got reformatted, and i continuously forgot the website for cube, the maps i made were nice, i figured out how to make a elevator, if you ever need help with that. anywho, great 'ible, easy to follow, 5*s
trevor3693 says: Apr 16, 2010. 9:01 PM
this looks just like roblox.
zack247 in reply to trevor3693Jul 27, 2010. 10:26 AM
but 3000000000 times better
MDude says: Jul 19, 2009. 7:53 PM
Well this is neat. I've played Cube2 before, but I haven't gotten a new version in forever, and I guess they have a new texture picker now, just like I wanted.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
