Introduction: Egg Carton Flower Lights
Today, I thought it would be fun to give you instructions on how to make a string of flower lights out of empty egg cartons. This project is pretty simple, but it can be time consuming. It takes me about 2-3 hours to finish a string of 20 lights.
Step 1: Gather Your Materials
For this project you will need the following:
Egg Cartons (Cardboard or Styrofoam)
Acrylic Craft Paint
Sharp Utility Knife
Foam Paintbrush
Hot Glue Gun
String of Christmas Lights
Cutting Mat
Step 2: Cut Your Cartons
Using the utility knife cut the egg cartons along the red lines in this picture. With a styrofoam carton, not every cup will make a good flower shape. This carton yields 16 poppy shaped flower. The cardboard carton on the right will yield
5 lily shaped flowers. Save up your cartons or ask your friends and family to donate theirs to your project.
Step 3: Shape Your Flowers
Step 4: Paint Your Flowers
Now it's time to paint your blossoms! I've found that sponge paint brushes work best to cover the irregular surfaces and works the paint into the little creases and dimples well. As you can see on the orange flower, the styrofoam will show your brush strokes. This gives the flowers a watercolored look. The cardboard will paint up nice and evenly. I recommend painting the insides of all the flowers first. By the time you've painted the last flower, the first should be dry and you can then begin painting the outsides.
Step 5: Assemble Lights
Once all the paint has thoroughly dried, use the utility knife to cut a small X shaped slit in the bottom of your flower. This slit is where you will insert the light bulbs.
Insert one of the light bulbs through one of the flower just far enough that you can remove the bulb and change it if it burns out.
On the back side of the flower, hot glue the flower in place. It helps to hold the flower in position until the glues is set. Repeat this step for each flower, making sure the glue is cool before moving onto the next light.
Step 6: The Final Product!
These lights make a whimsical decoration for your room. They also make wonderful night lights, providing a delicate and colorful glow.
Egg-Bot Challenge
