One Dozen Egg Lights
Published
Introduction: One Dozen Egg Lights
Eat eggs. Save shells. Make egg lights.
Step 1: Materials
  • Eggs
  • Egg Carton
  • Balloon Lights
Step 2: Eggshells
Gently tap the top of the egg against a hard surface until it has a small crack. Use your thumb to push in on the cracked part of the shell. The shell should break and leave you with a small hole. If you can, remove any shell that has broken off and throw it away. Now that you have a small hole, use your fingers to gently pick off small pieces of the shell until you have an opening big enough for the yolk to fit through. Then, pour everything out, wash the shell and let it dry.
Step 3: Light It Up
Twist the balloon lights to turn them on. Place one light in each compartment of the carton and cover with an eggshell. Or, put the light inside the eggshell and place it down. Done.
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
