Egg Substitutes
19,844
84
10
Posted
Introduction: Egg Substitutes
Food Science Challenge
Finalist in the
While some people are content enjoying gorgeous fluffy omelettes and rich, eggy custards, others prefer to get their sustenance elsewhere. Some might be avoiding fats or cholesterol, others might be vegan or vegetarian and want to avoid eggs as well as meat, but for those who don't like to nosh on ovum, it can be difficult to replace them - particularly in baked goods and sauces.
There are some tried and true options that I've seen used from time to time, but determining which is best to use depends on the outcome you'd like to get. Three options: flax seeds, silken tofu, and mashed banana are tested here in the same recipe - scoochmaroo's awesome chocolate chip cookie recipe.
Step 1: Options, Options
Different egg substitutes can be utilized to get a variety of results in all sorts of applications, but the choice of which to use depends on what role eggs need to play in the recipe. In cakes, for example, eggs are used to leaven the batter and make the cake fluffier. Cookies and muffins depend on eggs to add moisture and bind the batter together, while sauces and savory dishes usually rely on eggs for consistency and texture.
In addition to the examples below, there are loads of other things that folks use to replace eggs for whatever reason, including commercial egg replacers.
Silken Tofu1
Perfect for replacing eggs in sauces2 or adding to frosting for cakes, silken tofu is also great in baked goods. It can make baked goods a little bit heavy but will keep them nice and moist, so it's better in brownies rather than angel food cake.
  • Use 1/4 cup silken tofu to replace each egg in a recipe
  • Great for: cakes, cookies, brownies, sauces
  • How: The high protein content in both eggs and tofu make them ideal thickeners, in addition to the fact that they also emulsify well into other ingredients so you're not left with weird lumps and bumps. Upon being heated, protein thickeners like eggs or tofu unwind and then (if at high enough concentrations in the liquid they've been added to) when they begin to cool they set up and make the mixture more solidified.
Flax Seed
Adding a slightly nutty flavor, flax seed is wonderful for heavy or dense baked goods.
  • Use 1 teaspoon of ground flax seeds and 1/4 cup water to replace each egg in a recipe (grind flax seeds and combine with water - let sit for a minute or so before adding to a recipe)
  • Great for: waffles, pancakes, bread, cookies (particularly oatmeal cookies)
  • How: For the same reason the flax can aid in digestion, the stickiness and slimey-ness created when ground flax and a liquid are combined make them an ideal egg replacement. Some people even use flax slime for hair gel! The slime is the result of the oils of the flax seeds combining with moisture, and can even happen if the seeds are kept in too humid of an environment. The slime also makes flax an idea replacement for gluten (when combined with several eggs).
Pureed/Mashed Fruit
Mashed bananas, applesauce, or other fruits can be used in muffins and other treats. I personally prefer to use bananas in things like cookies and applesauce in cakes or things where you're aiming for a more pudding-ish outcome. The end result will be rich, moist, and quite dense (so if you want to lighten things up a little, add a touch of extra baking soda). You may want to add a little extra baking time to help balance out the extra moisture that fruit can add.
  • Use 1/4 cup of mashed banana (usually about a half banana) or applesauce to replace each egg in a recipe
  • Great for: quick breads (like banana bread!), brownies, cakes
  • How: Mashed fruits provide a fair amount of moisture to recipes (as eggs would), and also serve to activate the gluten in flour and bind doughs, etc. together. Unlike eggs, they don't have a ton of "stickiness" of their own and so it can be difficult to get some doughs to hold together using only fruit.
Vinegar and Baking Soda
While not a great option in cookies, sauces, or savory dishes, a vinegar and baking soda combo works very well in cake recipes to keep cakes fluffy and light.
  • Use 1 teaspoon baking soda and 1 tablespoon of vinegar to replace each egg in a recipe
  • Great for: cakes
  • How: More like whipped eggs, the combination of vinegar and baking soda results in a reaction that will really blow the roof off your batter. For the same reason you might use baking soda and vinegar to clear a drain, the combination of acetic acid (what makes vinegar vinegar) and sodium bicarbonate (baking soda) results in the formation of carbonic acid, the bi-product of which is a release of carbon dioxide gas (the bubbles that are produced).
1In addition to silken tofu, firm and extra-firm tofu can be used when making egg-free versions of dishes like quiche or egg salad, or even yummy tofu scrambles!
2I don't know if I could ever get by without the joy that is Hollandaise sauce (which can be made in the microwave!), but this is an awesome alternative (and it would be great with some eggplant bacon on the side).
Step 2: Rolling in Dough
In order to do a side-by-side comparison, I whipped up a half-batch of chocolate chip cookie dough, dividing it into quarters and substituting flax seed, tofu, and banana for the egg portion in each.
Scoochmaroo's Best Ever Chocolate Chip Cookie Recipe
  • 1 1/4 cup flour
  • scant 1/2 teaspoon baking soda
  • large pinch salt
  • 1/2 cup butter, softened (substitute with vegan butter substitute if making vegan)
  • 1/2 cup brown sugar
  • 3/8 cup sugar
  • 1/2 teaspoon vanilla
  • 1 egg (1 teaspoon ground flax seed and 1/4 cup water, 1/4 cup silken tofu, 1/4 cup mashed banana)
  • 7 ounces chopped chocolate
Following the recipe instructions, I combined the butter, brown sugar, and sugar, and then separated the mixture into four portions. I added 1/4 of the egg substitutes, one into each quarter of dough, and then added the remaining ingredients as instructed. Using a cookie scoop, I portioned out the dough on a foil lined cookie sheet and popped it in the freezer over night (this helps allow the gluten in the dough to relax and ensures that the cookies won't be tough when baked). The next morning, I baked the cookies at 350 degrees Fahrenheit for 9 minutes.
Step 3: Results
Flax
  • Most similar to the cookie made with egg in terms of texture and flavor
  • Light but not too puffy, with a slightly nutty taste
Banana
  • Soft and chewy
  • Pleasant, but banana flavor is present
Tofu
  • Moist and soft, but a bit too puffy for my taste
  • Slight change in flavor
In the future, I'll probably stick with flax seed if I need to replace the eggs in this particular recipe, but for other applications, that might not be the case. In a creamy sauce, for example, silken tofu would most certainly be my selection, and in a loaf of banana bread, bananas would be the obvious choice - it all depends on what you're whipping up and how you need your egg (replacement) to work.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    10 Comments
    That's my favorite. I will try it at home.
    I had no idea about the flax seeds and am now very excited! I'm sure you know that flax seeds (in ground form) offer omega-3 fatty acids that we, in general, don't get enough of. Great instructable!
    Thanks so much! Flax is amazing stuff, isn't it?
    I generally use cornstarch and water as my egg replacement option of choice. 1 tablespoon cornstarch, 3 tablespoons water = 1 egg.
    Hmm, I haven't heard that one before. Does it work well in baked goods or only sauces and things?
    So far I've used it for cookies and making tuna cakes. Since I was told to lower my cholesterol a couple years ago, eggs (and cheese *waaa*) are almost entirely gone from my diet and most things that use them with it. But I still make cookies and tuna cakes. There's a fine line with it adding enough to bind ingredients and "too much, tastes starchy."
    That's really interesting, thank you! I'll have to give it a try sometime. I'm sorry to hear that you have to avoid foods you enjoy - perhaps flax would be an alternative to the cornstarch?
    At least I found out early and watching my diet has dropped things into the normal range and didn't have to go on any cholesterol medication or the like.
    Flax isn't something already in the household, but it might be something to think about. Ended up using the cornstarch by searching the internet for 'egg substitutes' and looking to see what already existed in the cupboard.
    Great ideas for people who are forced to avoid eggs, or who avoid them for ethical reasons.
    Obviously, anyone who has been advised by their doctor to specifically avoid eggs should do so, but I thought I would point out that recent research in the UK has indicated that in general eggs are not the bad food they were once thought to be, and the British Heart Foundations goes so far as to say: "The cholesterol which is found in some foods such as eggs, liver, kidneys and some types of seafood eg. prawns, does not usually make a great contribution to the level of cholesterol in your blood. It's much more important that you eat foods that are low in saturated fat."
    However, as I say, these are useful ideas and will help a lot of people catering for vegans, I am sure!
    Thanks so much! I've heard both sides on the cholesterol issue, and it really just makes me glad it isn't something I need to worry about yet.
    Folks should always follow their doctor's advice, but personally I think that adding flax (and/or tofu and fruit) to one's diet is a good idea :)
