Step 5Adding pigment
The way we were taught to use the egg medium is to pierce a small hole in the yolk with the brush bristles. Now the bristles have eggyolk (and a slight bit of water) on them. Mix the yolk with the paint using the tip of the brush, then apply it to the artwork. Over time the yolk will ooze out of the yolk sack, that's fine, it's still useable outside of the yolk sack.
The online tutorial is a bit different. It says to pierce the yolk sack and blend the yolk with water, then use the yolk/water mixture with the pigment. I have not tried this, but I'm sure it works just fine.
When you use the yolk straight, it is thick and dries with a slight shine. I would guess that cutting the yolk with water will be thinner with less shine.
Add Comment
