3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Egg boat candle
Egg boat candle
“In the darkness, an egg is shining ..., It’s an egg boat.”
Egg boat is an egg that filled from candle and is floating on the water. That shine for many hours in the night.
Step 1Materials
Materials
  • Egg
  • Solid paraffin
  • Candlewick: 2.5 cm (for each egg)
22 comments
Aug 26, 2011. 4:21 AMfonzuzu says:
I made one, the wax cools and the wick secures faster if you hold the candle while it is in a bowl of water.That way it floats and cools down so you only hold it for like 30seconds
Oct 15, 2011. 11:02 AMthemadjeweler says:
i like the little caution symbol :). good 'ible.
Sep 5, 2011. 3:28 AMfonzuzu says:
Ok
sure
Jul 18, 2011. 2:20 AMsunshiine says:
I am going to remember this! I love it! Thanks for sharing.
May 2, 2011. 3:48 AMcopilarim says:
Beautiful idea indeed!! Good luck:)
Apr 24, 2011. 9:17 AMCheeseman says:
Just a few grammar corrections for you:
For "The paraffin should become fuse with water heat"
You're looking for: "The paraffin should melt from the water's heat"
fuse means to join two things together, while melt means to turn something from a solid into a liquid.
For "hold it with your hand until become fixed"
You want: "hold it with your hand until the paraffin solidifies"
fix means to repair something or to attach something in a way that it cannot move, solidify is the opposite of melt.
Good 'ible though, keep up the good work!
Apr 24, 2011. 12:15 PMskiminoangel says:
Actually the use of "fixed" was correct. Fix is an abreviation of Affix, which means 'fasten; cause to be firmly attached; set or place definitely; stable or stationary; put something somewhere firmly'. You can have "a fixed moment in time" which refers to a specific moment in time not a repaired or corrected moment in time. My English education teacher always drilled the proper use of this word into our heads. You correct a problem because if you fix it you make it permanent. If you are holding the wick in the wax until it is permanently attached then it is fixed in the wax.
Apr 25, 2011. 4:16 AMMadrigorne says:
I wonder what it would look like with easter dyed shells...
Apr 24, 2011. 10:51 AMstengah says:
Beautiful idea - we will try this out. Thanks! :-)
Apr 24, 2011. 10:41 AMaparks1 says:
You can also clean out a big can, such as soup, and put that in the water to hold the wax.
Apr 24, 2011. 8:37 AMporcupinemamma says:
Thank you! Beautiful! Well done! :0)
Apr 23, 2011. 10:50 AMrpowling says:
so pretty! thank you.
Apr 23, 2011. 7:25 AMh0meIandsecurity says:
Yeah!
Apr 22, 2011. 2:35 PMChrysN says:
They look beautiful, I like your drawing too!
(ps: flouting means to show contempt or scorn, I think the word you want is floating -borne up by or suspended in a liquid).
Apr 23, 2011. 1:07 AMcrobson says:
communist cat likes these.
Apr 22, 2011. 6:42 PMhaakon.k says:
What a beautiful idea!
Apr 22, 2011. 2:48 PMTristaGee says:
Beautiful. Will definitely try these.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:farzadbayan(Baghbagho)
The World's Biggest Show and Tell
