This a variation on common crystal growing techniques.  Instead of growing crystals on a string, grow them inside a 'geode' made from an egg shell and plaster of paris.
Materials:
Egg shells (washed)
plaster of paris
disposable cup
craft sticks or stir sticks
Water
table salt or other crystal growing material - magnesium sulfate, borax etc.
bowl or pan
optional: food coloring for colored crystals
Step 1: Prepare 'Geode' shell
 Carefully crack an egg in half - try to save the largest part of the shell.
Clean egg shell.  Rinse with diluted bleach water, followed by plain water.  You want to kill any bacteria on the eggshell.
Mix plaster of paris according to directions on package (This is usally about 2 parts plaster powder to one part water.  ALWAYS add plaster powder to water, this minimizes airborne plaster dust.  Stir well and thump cup a few times to force air bubbles to the surface).
When plaster starts to thicken, spread a thin layer of plaster inside the half egg shells - about 1/4 inch or 6 mm.  Try to get a thick edge of plaster along the edge of the shell for a more durable 'geode'.
Let plaster set and dry.
whiteoakart says: Apr 12, 2012. 8:07 AM
I am wondering if there is a way to make this without breaking the shell in half, so that it would be a surprise when you open it, like a real geode. By drilling a hole in each end and blowing out the egg, for example.
wombatmorrison (author) in reply to whiteoakartApr 12, 2012. 9:41 AM
I don't think a blown egg would work very well. I don't know how you would remove the membrane lining the egg shell, and I think the membrane would interfere with crystal formation. Please share your results if you try a blown egg.
Enjoy!
whiteoakart says: Apr 12, 2012. 8:05 AM
Is the plaster just for reinforcement of the egg shell? Could other materials be used to reinforce the shell? Does the porosity of the plaster help the crystals grow?
wombatmorrison (author) in reply to whiteoakartApr 12, 2012. 9:37 AM
I've not tried other materials for lining the shell. I think plaster is useful because it is porous and provides good matrix for crystals to grow onto. Plaster also provides strength. I suppose you could some kind of cement mixture.
whiteoakart says: Apr 12, 2012. 8:08 AM
BTW, this is a really nice science/family project. Great job.
busterbuster18724 says: Oct 7, 2011. 11:45 PM
would Epson salts work faster or the normal salt ones?????
The Ideanator in reply to busterbuster18724Oct 9, 2011. 7:27 PM
That would work just fine, as would anything that would crystalize out of a liquid water solution
The Ideanator in reply to The IdeanatorOct 9, 2011. 7:39 PM
In fact, pretty much any evaporite could be done I think.
wombatmorrison (author) in reply to busterbuster18724Oct 8, 2011. 9:15 AM
I don't think it matters what kind of salt you use. Crystals will form faster if the area is warmer and drier - under an incandescent bulb or near a heat source. But, faster evaporation will also produce smaller cystals.
busterbuster18724 in reply to wombatmorrisonOct 8, 2011. 11:21 AM
thanks
The Ideanator says: Oct 9, 2011. 7:26 PM
Hmm, This sounds like a neat project. I'd do it with copper sulphate (with some iron included for contrast) and bake it in an autoclave for a few days to try to get the egg to pyritize (with the iron). OOhh, I could mix iron filings or other metal nodules into the plaster to see if that would make interesting artificial minerals.
moochaka says: Apr 21, 2011. 6:55 PM
So this is like the same as rock candy solution, but with salt(or other crystal-forming substance), right?
GameNox in reply to moochakaApr 30, 2011. 3:13 PM
Yep! You can also dilute sugar in a cup and then tie a string to a pencil and grow a EDIBLE sugar crystal!
Void Schism says: Apr 22, 2011. 1:45 AM
Copper Sulphate works well and forms really deep blue rhombic crystals. I used to buy it over the counter at my village pharmacy.
stinna2 in reply to Void SchismApr 22, 2011. 6:46 AM
you can also buy copper sulphate at the big box home improvement stores. it usually goes buy septic root killer its usually 99% copper sulphate
wombatmorrison (author) says: Apr 21, 2011. 8:24 PM
Yes, though I've only used salt and magnesium sulfate (epsom salt). I think sugar should also work, but I wouldn't eat sugar crystals grown on plaster, who knows what trace chemicals might leach out into the sugar.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
