What I came up with was this Eggcellent Night Light. It's minimalistic. It looks modern. It also shares some creepy Pagan relic "lunar" qualities.
MATERIALS:
(1) large white egg
(1) mint tin box - just the bottom half
(1) double AA battery pack
(1) white LED 3+volts
(2) AA batteries
(1) slide or push switch with two leads
(1) black paint or black spray paint
TOOLS:
-glue gun
-awl/screwdriver
-soldering iron
-metal punch or drill
-chopstick
Remove these ads by
Signing UpStep 1: Let the hollowing commence!
(optional step)
If you are not confident with yourself in guesstimating where the bottom of the egg is, take a small piece of paper, color it with colored chalk, and place the egg upright on the paper. The chalk should mark where the utmost bottom is.
(/optional step)
Use an awl or small screwdriver to tap/carve a hole at the bottom of the egg. Once a tiny hole is made, start tapping along the circumfrence of the hole to make it larger until the hole reaches 1/4in in diameter.
Due to pressure and surface tension, the yolk and white of the egg doesn't just come gushing out. I found out that the most efficient way is to stick a chopstick in the whole and just move it in and out to let the innards leak out fairly quickly.
Rinse the inside with water and let dry.
Visit Our Store »
Go Pro Today »
the amazing cancer giving glowing egg lamp of death im gunna print out a hazard uv rays sticker i will put it on the base
Great instructable!
second, use a Pysanky
