When the plants get too big for the shells, you can transplant them straight to the soil, shell and all.
Remove these ads by
Signing UpStep 1Materials
Eggshells
Egg carton
Potting soil & spoon
Awl/needle/pin - anything long and sharp
Knife
Seeds
Optional:
Pot & stove
Spray bottle
Egg cups/miniature clay pots for display
But, don't forget to crack and peel away the bottom of the eggshell so the roots can spread out.
Great Ible!
It's nearly easter, so my recommendation is:
Prop the egg shells on a decorative paper ring, just put some moist cotton wool into the egg and use cress seeds. This makes a great decoration for your easter sunday breakfast and if you time it right, everyone can cut the cress from their egg and eat it straight on their buttered sandwich. De-lish!
Awesome instructable -I'm definitely doin' it when I get back from a trip so I can have my own li'l herb garden =)
And before planting you can easily crack the bottomside of the shell by tapping it on the ground and roots will have no problems breaking through.
I like this idea. :D
When having reached the right size, the cardboard sections are cut into separate "pots" and planted "as is".
Roots are getting through the material apparently without any great efforts.
In a greenhouse it might work better, or if there's not chance of raccoons getting at your seedlings, but after that one try I went back to just composting egg shells.
It might make a nice project with kids and marigolds, though, inside a school setting.
Problem is, if starting a lot of plants at a time and trying to get a lot of growth before planting outdoors, ideally large pots/etc can take up a LOT of space and you'll need all that much more light to cover the larger area. Recently I've been using 3" peat pots and that seems the best tradeoff for my needs though with peat pots you usually need to treat for mold growth at first if they are covered to keep moisture high... something like a 1:10 solution of hydrogen peroxide and water spray is handy, cheap, and effective.
She was used to start many types of seeds.
Wow, this would make a great kid project!! will def try this with mine. :()
shantr0n: It doesn't matter if you use hard-boiled eggshells, as long as you can get the egg out without breaking the shell.
thunderstruck: They are biodegradable, but they can take quite a while to fully degrade.
RoBear: You could also use the egg carton. I just think the plants look nicer coming out of the eggshells.
cheese: I would repot them as soon as they are strong enough to be moved, which depends on the particular type of plant. Check out this helpful blog post about transplanting seedlings and 'seed leaves' vs 'true leaves': http://donnabalzer.blogspot.com/2009/03/seed-leaves-vrs-true-leaves.html Good luck!
tincanz: I have never tried it, but i think a coconut shell might make a nice planter (you might need to drill some holes for drainage). I'm not sure about starting seeds in it, because the roots might not be able to break through the bottom. Let me know if you try it!
