Step 2: Prepare the eggshells
If you eat eggs, then save the eggshells when you use them. If you don't eat eggs, ask a friend to save the shells and carton for you.
1. Carefully crack the top third of the egg. You can do this by tapping the egg on the edge of a bowl, or tapping with a sharp knife.
2. Empty out the eggshells completely.
3. Wash the eggshells out well.
Optional step: If you are concerned about salmonella on the eggshells, put the empty eggshells in a pot of boiling water for a few minutes.
Step 3: Add drainage
Take the empty eggshell, and poke a hole in the very bottom with your sharp object. If you are using a thin needle or pin, widen the hole a bit with a pushpin or small nail.
This hole provides drainage, so the roots of your plant don't drown. You only need to poke one small hole; more than one might crack the shell.
Step 4: Add potting soil
Picture of Add potting soil
Using a small spoon, fill the eggshell with moist potting soil.
Optional: If the potting soil is dry, spray it with water from a spray bottle as you fill the eggshell.
Step 5: Add seeds
Think about the amount of light you have available in your home and garden, and use seeds that will thrive in these conditions. Plant your seeds according to directions. The seed package will tell you how deep to plant the seeds, or can find this information online.
If you want quick results, try beans or cucumbers - they usually sprout in a few days.For bonus points, use seeds that you saved from last year's crop instead of buying seeds. Oh my goodness, seeds are AMAZING!
1-40 of 58Next »
ragestarshine8 months ago
This is a great way to re-use dyed Easter eggs and to get kids into gardening #win!
ve2vfd5 years ago
You can also sprinkle broken eggshell on the soil around your plants to prevent slugs from destroying them. Slugs dislike eggshell fragments.
It's also good for adding calcium to the soil.
Fine sand is better for that.
leftover beer (in a lid) works too, seems they like it as much as people do and drown to death
andrej ac-dc3 years ago
leftover beer? there should not be such thing as leftover beer! ;o)
ac-dc andrej3 years ago
Well said, but that last sip in the bottom of the bottle or can is getting warm and is starting to get flat, I'll let the slugs have it and open a fresh cold one instead.
Lei_Kei2 years ago
This is such a cute idea! I will definitely have to try it as spring comes along.
bajablue3 years ago
I love this method and have used in countless times.
But, don't forget to crack and peel away the bottom of the eggshell so the roots can spread out.
Great Ible!
Why don't you try it without the container? Soil Blocks are easy and work really well: http://www.instructables.com/id/Make-Super-Cheap-Seed-Starters/
cheese105 years ago
These look great! I can't wait to make them! One question though: How do you know when they are to big for the eggs? When do you switch them to a bigger planter? Thanks!
hsahrc cheese103 years ago
How about a good old Ostrich egg? Then they can grow for about 6 months!!! Just joking!
choval cheese105 years ago
 You could use duck eggs, they are a bit bigger. (chinatown usually has)
Just get a bigger chicken.
Rofl
redbandita3 years ago
I love the idea! Finally something to do with egg shells rather than throwing them away.
It's nearly easter, so my recommendation is:
Prop the egg shells on a decorative paper ring, just put some moist cotton wool into the egg and use cress seeds. This makes a great decoration for your easter sunday breakfast and if you time it right, everyone can cut the cress from their egg and eat it straight on their buttered sandwich. De-lish!
shantr0n5 years ago
D'you think one could use hard-boiled eggs for this? Or does it not matter?
Awesome instructable -I'm definitely doin' it when I get back from a trip so I can have my own li'l herb garden =)
I think hard boiled eggs would be way easier. You can cut off the top and spoon it out. It's hard to break a raw egg in the right way. It also eliminates the salmonella threat.
And before planting you can easily crack the bottomside of the shell by tapping it on the ground and roots will have no problems breaking through.
I like this idea. :D
I'm using the cardboard packaging directly and have good results!
When having reached the right size, the cardboard sections are cut into separate "pots" and planted "as is".
Roots are getting through the material apparently without any great efforts.
I suspect that it would be very difficult to remove the shell in a sufficiently intact fashion from a hard-boiled egg.
no it think the idea was to use the egg as a growth medium. that'd bee sick. ima try it
ac-dc brian31403 years ago
rotting egg bacteria and mold would destroy the plant... they can resist some but not that much
greenkira4 years ago
I tried this, and the first night I left the seedlings outside to harden off, raccoons went through the flat of them and destroyed most of the seedlings. Raccoons like the scent of eggs. One or two surviving seedlings did get planted out eventually, and they got dug up. Also, I found the seedlings in egg shells just dried out too quickly - it was hard to quickly and adequately water the seedlings in eggshells, and the cardboard packaging wicked away moisture too quickly. I had a similar problem with the experimental newspaper pots and jiffy peat pots - Minneapolis gets hot fast in the spring.
In a greenhouse it might work better, or if there's not chance of raccoons getting at your seedlings, but after that one try I went back to just composting egg shells.
It might make a nice project with kids and marigolds, though, inside a school setting.
I agree. Years ago I planted using egg shells. I punctured some little holes for drainage. But raccoons and opossums dug up everything. I ended up having to replant everything, and some of the seedlings were damaged beyond recuperation. Skunks will also dig up anything with egg shells. Perhaps in a suburban area or urban area it would work OK.. At the time we had about 100 chickens and it seemed like a good idea. By the way, if you roast egg shells you can feed them back to chickens for calcium without them cannibalizing their eggs.
Even urban/suburban areas are not safe from skunks, raccoons, opossums, foxes, and other critters. I live in a small town, and there are skunks all over the place, right in the heart of the downtown area! They'll go right up on to your porch if you leave garbage or food out overnight.
ac-dc3 years ago
Might I suggest that even though the roots can push through cracks in a broken shell, it will still impede root growth. You'd be better off using a bit larger regular pots and taking the shells and finely pulverizing them before sprinkling into the hole you transplant your seedlings into, if not adding the shell fragments ahead of time so they have a head start degrading into the soil.
you should really sprout seeds in a deeper container. if the main root it stopped from travelling straight downwards it will stunt the plants growth. very cute though
I agree although it depends on where you're planting them, how big they need to get to survive their new home. Some plants don't need or have a main root that grows straight down either.
Problem is, if starting a lot of plants at a time and trying to get a lot of growth before planting outdoors, ideally large pots/etc can take up a LOT of space and you'll need all that much more light to cover the larger area. Recently I've been using 3" peat pots and that seems the best tradeoff for my needs though with peat pots you usually need to treat for mold growth at first if they are covered to keep moisture high... something like a 1:10 solution of hydrogen peroxide and water spray is handy, cheap, and effective.
tincanz5 years ago
awesome 4.5* what would happen if you used a coconut shell? would it be to strong and thick?
Much too strong. You can carve really nice pendants out of coconut shell though....
oaberaldo3 years ago
Great idea. My doughter Maria Tereza uses this method for many years ago.
She was used to start many types of seeds.
Groover3 years ago
This would be a great way to make seed bombs. Something like this in a nicer package. :)
Wow this would be great idea for plants that require lime in the soil. Brilliant!
ahmad21174 years ago
heres a way i think will be a good way to transplant cucumbers since there not really good at transplanting crack the egg when its over the place you whant to put it in then transplant the cucmber seedling AND REMEMBER TO WATER IT RIGHT AFTER YOU TRANSPLANT IT. thanks
liz034 years ago
Wow, this would make a great kid project!! will def try this with mine. :()
mamakatfrog4 years ago
 I should have checked here.  I did this.  My first batch I didn't think about drainage so ended up jabbing a chopstick down to crack the bottom of the shell.  If you ant to laugh at my attempt, I blogged it.
brian31404 years ago
this is perfect for tomatoes because they require a high amount of calcium to prevent blossom end rot. you could crush the shell when you plant it.
hypnostics5 years ago
thanks for this! :)
sleeepy25 years ago
Eggshells also help prevent blossom end-rot in tomatoes. But, you should use about 12 crushed eggshells per tomato plant. Great idea!
NOOO! this is exactly what i was going to submit for the get in the garden contest!
1-40 of 58Next »
