Elastic Band Knotted Ring
Published
Introduction: Elastic Band Knotted Ring
About: Industrial Design student at Eindhoven University of Technology
It all started when I was trying to get my hair in a ponytail. All of a sudden, my elastic band snapped. Yes, the band that I trusted, betrayed me, just when I needed it. So, I promised to take revenge on that traitorous band. And my revenge would be creative :). I hope you like it!
Step 1: Materials
To make a ring like this, you will need:
- (snapped) elastic band
- scissors
- marker
- glue gun
- round object matching the size of your finger
Step 2: The Knot
Start by making a knot in the middle of the band. Make a loop, put the end trough (basically just a simple knot) and pull it, but not too tight, you really want the knot to be showing, not as small as possible.
Step 3: Creating the Ring
Take your round object and place the knot on it. Wrap both sides around it a bit tight, while holding the knot so it remains it's size. Take your marker and draw a line as shown, so you will know where to cut the band. This was the moment I discovered my blue marker was empty, so I ended up using a black one.
Step 4: Cutting the Excess
When the sides have been marked, you can let go of the band again. Cut off the strands at the marked parts. I decided to cut just a little bit next to it, so it wouldn't be too short.
Step 5: Glueing
Take your glue gun and let it heat up. Apply the glue to the elastic part of one of the strands. When the glue is added, press both sides together as shown. For my first try, the glue gun wasn't hot enough, so the glue came off again. The second try gave a much better result.
Step 6: Done
And that's it! What I really like about this project, is the time it takes. Basically, from snapping to wearing, it took about 6 minutes I'd say. I hope you liked it as well, if you did I would love to know!
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    4 Discussions
