Introduction: Elecctronic Ballast As Flyback Driver Part 2 Output of 200kv
Picture of Elecctronic Ballast As Flyback Driver Part 2 Output of 200kv
Hi,you all have gone through different types of flyback driver like zvs,transistor driven etc.But i will tell you most easiest and cheapiest one and most powerfull one.In my first part i disscussed how to get output upto 100kv. Now,in this part I will discuss how too get 200kv and spark upto 8 inches.
Step 1:
Picture of
Step 2:
Now find the feedback coiling in the flyback transformer and join the remaining two wires to it.that's all you will get massive sparks upto 8 inches and output voltage of 200kv.But don't dare to touch the hv red wire it will be more dangerous than before bacause your body is in contact with earth.you will get it here https://www.instructables.com/id/How-to-find-the-primary-and-the-secondary-coils-of/ finding feedback is just like finding primary coil
Step 3:
Picture of
Yov can connect a pc fan in electronic ballast as it will get too hot and ofcourse it is more powerfull than zvs driver
SaisagarR (author)2015-09-25
I had take a flyback transformer and a pholips sumo slim ballast.
I measure the 4 wire of ballast with voltmeter range 1000v dc one black and one white wire give me 37 reading in voltmeter then i wire a wire around ferrite core of transformer and join thewire of ballast to it but it not work
Plzzzzz help me
basically your black wire is ground terminal of ballactics connect it to one terminal of primary winding and change connection with white wires
and ofcourse you need to use electronic ballastics dont use copper wounded one
first of all you need to find the primary winding of your flyback transformer and different ballatics have different configuration just try to connect alternatly
I used this method but not work
hemant solanki (author)2014-08-27
can you explain how this driver works ?
Higgs Boson (author)2013-01-03
At what distance did the arc actually start?
8 cm sir higgs boson
That would indicate that about 80kv or less was being generated typically. Even so this is very impressive, as most flybacks would die at these voltages (the internal insulation just can't take the voltage).
ssparking rajesh (author)2012-11-13
any technology that requires hv of 200kv and that too of dc can be used with this part
amandaghassaei (author)2012-11-13
so what is the normal use of this part and what are you trying to use it for?
About This Instructable
9,127views
9favorites
License:
Bio: I aM FuNkY LoVeR BoY:p
More by ssparking rajesh:Elecctronic Ballast as flyback Driver part 2 output of 200kvAc to Dc voltage multiplierElectronic ballast flyback driver part 1 to get 100kv
Add instructable to:
