Electric Acoustic Guitar
2,683
36
5
Posted
Introduction: Electric Acoustic Guitar
Step 1: Microphone
The major thing that you will need in this project is a microphone ( any kind ) as you can see i got mine from an old rock band microphone from a broken wii
Step 2: Disasemble Microphone
Only disasemble if it is a big microphone if not, it is completely unnessecary
Step 3: This Is What It Should Look Like After Youve Taken the Top Off
Step 4:
From here you should be able to pull the body out
Step 5: Then the Base
Step 6: Cut the Wire
Cut it as far down as you can at first to be safe
Step 7: You Should Then Be Able to Pull Off the Bottom
Step 8: Strip Wire
Strip the wire so you can remove the actual microphone from the body
Step 9: Strip the Rubber Coated Wire
Step 10: Get an Amplifier Wire
Step 11: Strip the Amplifier Wire
Step 12: Install Mike Into Altoids Can
Connect the wires from the amplifier and mike in an altoids can or any mthing like one
Step 13: Install Foam
Foam will support the mike and prevent scruffy sounds
Step 14: Poke Holes
Poke holes to enable sound through can
Step 15: Sound Filter
Install a thin layer of foam above the mike for better sound qualaty
Step 16: Close Can With Tape
Step 17: Make Small Holes in the Bottom of the Can
Step 18: Install Sucktion Cups in the Hole
Step 19: Done It Should Work
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
5 Comments
Btw thanks for the info i never would have known that. I am 12 years old and have little experiene or knowlage for microphones and i just threw this thing together with no directions hoping it would work and i guess im luckey it did so again thanks for the info
Well it works and it works very well and you can amplify anything you could use it as a microphone or any thing you want, and it has suprisingly good sound qualaty
"The major thing that you will need in this project is a microphone ( any kind )"
Nope. You got lucky. Your Wii/Rockband mic must be a dynamic mic, meaning it generates a signal without needing external power. A magnet and a coil. This is good.
A lot of cheap microphones use an electret capsule. These produce no signal unless they are powered, and a guitar amp won't provide the low voltage bias needed to run them, so you now will have to add a battery, a resistor, a DC blocking capacitor. Otherwise, no signal.
Stick with dynamic mics for ease, else look up powering electret mics -- it's only 2 components and a battery, but they are essential!
Genius! Never had an elec guitar. My kid doesn't even play Wii anymore. I just need an amp and guitar then learn how to play.
