Introduction: Electric Acoustic Guitar
Step 1: Microphone
The major thing that you will need in this project is a microphone ( any kind ) as you can see i got mine from an old rock band microphone from a broken wii
Step 2: Disasemble Microphone
Only disasemble if it is a big microphone if not, it is completely unnessecary
Step 3: This Is What It Should Look Like After Youve Taken the Top Off
Step 4:
From here you should be able to pull the body out
Step 5: Then the Base
Step 6: Cut the Wire
Cut it as far down as you can at first to be safe
Step 7: You Should Then Be Able to Pull Off the Bottom
Step 8: Strip Wire
Strip the wire so you can remove the actual microphone from the body
Step 9: Strip the Rubber Coated Wire
Step 10: Get an Amplifier Wire
Step 11: Strip the Amplifier Wire
Step 12: Install Mike Into Altoids Can
Connect the wires from the amplifier and mike in an altoids can or any mthing like one
Step 13: Install Foam
Foam will support the mike and prevent scruffy sounds
Step 14: Poke Holes
Poke holes to enable sound through can
Step 15: Sound Filter
Install a thin layer of foam above the mike for better sound qualaty
