3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electric Bicycle (ebike) Conversion Kit assembly - hub motor, controller and battery pack installation
  • C:\Documents and Settings\phantom\My Documents\E-BIKE\manual\myebike.jpg
This instructable is intended to help you save time and trouble should you decide to convert your own bike to an electric bike using an electric bike conversion kit.
11/18/2010 updates:
I now double check all suppliers from China now for factory seconds (items of inferior manufacturing quality). Design concerns are becoming somewhat less but the Chinese still tend to design and manufacture in the style of the machining only working surfaces or in some cases the opposite - only for looks. Kelly Controls (http://www.kellycontroller.com/) seems to offer the best choice so far for hub motors, controllers and kits from electric bikes to enclosed vehicles for the dollar but beware that factory seconds kill all expected value. This is why top value is said to remain with the best quality regardless of price..
For this reason I no longer endorse or support Golden Motor. It turns out they are a trading company and not a manufacturer. Outsourcing factory seconds only to foreign markets explains why it is easy for Western customers to find critical defects in all of their exported products, which would be less of a problem if they paid return costs and accepted third party quality assessment. One continuing example is that instead of using machining to correct hub cover and rotors assembly imbalance balance based on inspection they have used machining only  to enhance hub cover looks. Hub covers are  structural components and machining only to enhance looks of an unbalance hub cover/rotor assembly to attract unwary buyers is the main reason I no longer endorse of support them. .
In addition to reading engineering reviews for new electric bikes and kits out there I suggest monitoring Endless Sphere forum (http://endless-sphere.com/forums/) as the best and most reliable source of accurate electric bike information  and visiting ebike.ca (http://ebike.ca/). I also suggest using a rear wheel kit and lithium IRON phosphate batteries (not Magnesium or Cobalt). I still use my old industrial grade SLA batteries but I moved them to a trailer carrier since I use my bike for errands and not for sport.
With this setup I can also mount two 20" front hub motors on the trailer and mount only the controls on a regular bike.
If you live a few miles from a grocery store, school or place of employment and run errands or commute on a bike day after day after day even in sunny Florida, Arizona and LA it can get older than you'll ever hope to be especially if you are already not as young as you used to be. Before getting another Tin Lizzy, however, I wanted to give a sport bike a shot but settled for an electric bike instead.
US Federal law limits the speed of all electric bicycles to 20 MPH (no tail wind and level ground) and power to 750 watts. With a limit of 20 MPH, 750 watts means the power to lift 18.75 lbs, 1760 feet in 1 minute or lift 18.75 lbs, 29.333 ft in 1 second.) To still be classified as a bicycle an electric bike must also have functioning pedals, otherwise you need to have it tagged. Range and speed depend on bicycle mechanical fitness; bicycle weight plus rider plus battery pack plus passenger plus cargo, etc., battery type and rating, terrain and a bunch of other factors. Typically with a 12 amp hour lead acid battery pack, 40-60 lb bicycle including hub motor, 20 lb battery pack, 220 lb rider, stop and go traffic and course with ten 10 to 50 foot rolling hills without wind on a full charge will provide a measured range of five miles.
Ni-Mh batteries weigh a third less than lead acid while LiFePo4 batteries weigh the least at slightly over half the weight of lead acid allowing for higher amp hour capacity and therefore greater range. Five miles on an electric bike is a lot more doable everyday than walking, jogging or peddling especially for older people. Electric bikes in general help reduce fatigue associated with daily commutes and allow lower strain, higher speed exercise that is better for the cardiovascular system than high strain, low speed exercise associated with using a higher gear at a lower speed on a conventional bicycle.
Electric bikes that can carry an adult plus groceries start at around $679 plus tax and/or shipping so I began looking for some good DIY instructions and motor sources. As it turns out the cost in time and money to get up and running within a reasonable amount of time when scrounging, buying or making parts from non-electric bike components can be a lot more expensive than even pricey electric bikes found online. (Maybe one of you Instructables author guys or girls will prove me wrong someday!) Fortunately there is a lower cost alternative (less than $200) in the form of an electric bike conversion kit.
Step 1First things first: On delivery day check the package for damage before the driver leaves!
Notice in the picture the battery charger company did not secure the white box with tape and sometime during shipment the battery charger slipped out of the box. Nothing was damaged but checking the contents in the presence of the delivery driver may save you time if something is actually broken. Ask the driver for the service manager's phone number and a damage claim form if he says he can not wait.
32 comments
Oct 31, 2008. 11:27 AMozetzioni says:
Hey, I am building a pedal generator bike with a battery. at the end of the day i want to transfer the electricity i made of riding into a bigger battery and then use it for lighting equipment... anyone knows of a method to transfer the electricity from one battery to a bigger one without losing voltage or too much energy???
Oct 26, 2009. 1:02 PMaudioredneck says:
This was posted a year ago, but since no one answered,  I figured I'd take a shot at it:
I understand you to mean, you are adding a battery to your bike that you want to charge with some of the spare energy you use to bike with, to the answer is-
Yes and no:
Charging a battery is partly a chemical reaction that uses energy and discharging one is the reverse chemical process and uses a similar amount of energy.  So a battery is not going to transfer energy to another battery without significant loss (greater than 10%).  I large capacitor (bank) would transfer the energy more efficiently, but could be more dangerous and complex to put together.  Then there is the flywheel method which would be outrageously expensive to implement (and not work well on a bike)
You would probably be better off directly connecting to the battery pack from the bike to the pack that you use for lighting, even if you are only adding 1Ah.   Adding is adding, and directly connecting will be the most efficient method.
Lots of other things to factor in, like how the other batteries are charged.
Jul 20, 2009. 4:17 AMElvenChild says:
What the heck is an alloy fork?
Aug 23, 2009. 11:48 AMYerboogieman says:
An alloy is a partial or complete solid solution of one or more elements in a metallic matrix. A bicycle fork is the portion of a bicycle that holds the front wheel and allows the rider to steer and balance the bicycle
Jul 23, 2009. 1:40 AMtheburn7 says:
I only have aluminum forks :(
Oct 9, 2008. 3:59 PMzenithfab says:
The "over locknut dimension" on most front hubs is 100mm. Which should closely match the inside of the forks. The "OLD" of the rear hubs on most newer bikes is 130 or 135mm, 130 for many road bikes, 135 for mountain types. Again matching the rear dropouts.
Jul 20, 2007. 1:28 PMsarujin says:
No matter what I do I cannot find someone who will sell just the hub motor. That is all I want. I have an old scooter I took apart and can salvage the whole deal from that except for the motor.
Jul 25, 2008. 11:47 AMichiwazaryu says:
I belice crystalite will sell just anmotor and the radio shack in sebastopol Ca. has them.
Oct 15, 2007. 1:09 PMpepe123 says:
Hi, I just bought a e-motor in ebay, it is a Heinzmann 400W 24V that sold for a mere 70 EUR..... Strange that the emotor is a front wheeler, why?
Apr 13, 2008. 10:46 PMmilokp says:
You would want the motor in the front so you don't have to worry about the ratcheting gear works on the rear tire. More of a cost-of-manufacture thing, but also a motor can be a large thing, and there is typically more space for such in the front fork.
Aug 15, 2007. 9:44 AMcamiller says:
electricrider sells kits and parts. Here is the motor page
http://www.electricrider.com/parts/motors.htm
I have had no business with them personally, just stumbled across them when I was looking at doing something like this.
Jul 20, 2007. 7:42 PMsmarterthanu says:
That's why they invented eBay.
Jul 21, 2007. 1:52 PMsarujin says:
Thanks, I would have never thought of ebay! I can only find the kits on eBay as well. As I said, I cannot find anyone who sells JUST the motor. So unless you have a better idea...
Jul 21, 2007. 6:43 PMsmarterthanu says:
My dear boyz. Back in zee lab in zee Germany vee could notz buy only onez kerbuklespinzer. No, vee had to buy two kerbuklespinzer. Youz are zee more fortunate ven der is eBay! Doz youz getz vat I'mz drivinks at?
Jul 26, 2007. 11:50 AMsarujin says:
It does not appear that there is an ebay seller who sells just the hub motor or even a case of hub motors.
Jul 26, 2007. 6:33 PMsmarterthanu says:
My boyz, my boyz. Ven vee bought two kerbuklespinzer but only needed one vee ditz not look for an eBay seller. Now doez zee meaninks of what I am sayink rinkz zee oldz bell?
Apr 24, 2008. 12:32 AMhahazel says:
am looking for 750w hub motor conversion kit that will do 35 mph and have 30 m range
May 20, 2008. 2:27 PMFoxtrotman says:
Can you read? they can't go over 20 mph
Jun 14, 2008. 1:27 AMZeratul256 says:
Unless you register it.
Jul 6, 2008. 9:53 PMconrad2468 says:
i live in a small town the cops arent gonna pick me up for going 30 mph on my friggin bike! lol
Jul 10, 2008. 7:53 PMac-dc says:
Even worse, in a small town they will stop you just because they want to check it out, look it over, waste some time in their day.
Oct 15, 2007. 4:32 PMusa50cal says:
How do I get one of these kits?
Nov 5, 2007. 1:44 PMusa50cal says:
Well I think I found a company that sells these kits for less than $200. Thank for all the help and advice !
Oct 22, 2007. 8:24 PM2lazy2work2nervous2steal says:
My first post so I don't know if this should be here or on a forum. Anyway.....What am I looking for in an electric motor suitable for powering a bike like this? Is a hub motor the only way to go or would other types be OK? What about voltage, watts, amps, torque and all those other tech words I can spell but can't explain? Thanks!
Oct 23, 2007. 7:29 PMFalconEV says:
Any parts / motors needed, email me. see falconEVdotcom
Jul 20, 2007. 10:23 AMZaen says:
wasn't this one already done? I know I've seen those same pictures on this site before...
Jul 21, 2007. 12:57 AMbleachworthy says:
No, this is a full installation, the one you're thinking of, was some switch replacement in this same device, but it was a rear-wheel conversion.
Jul 21, 2007. 12:07 AMZaen says:
ohhhh. kinda stinks that you lost all your veiws and comments.
Jul 20, 2007. 7:58 AMrimar2000 says:
Genial.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
