Electric Bike (Assisted - not full electric) Step one
 by mark101
How to turn an average bike into an electric assisted one. Step one.
Step 1: Get a second back wheel - geared axle.
To start this project you need to get a second back wheel. This backwheel that has a gear on it will become your new front wheel.
The image here of a geared back wheel does not have a freewheel. The freewheel is the part with five or six gears on it that can only apply force in one direction.
randomness72.5 says: Apr 12, 2011. 8:55 PM
First what type and model batteries did you use second how did you put the gear on the motor you found?
I have a motor with a 3/8 inch X 1.25 inch shaft and a 10mm inner shaft?
What does inner shaft mean also could normal bike freewheel be put on it how would that work
Thanks
mark101 (author) in reply to randomness72.5Apr 13, 2011. 9:03 AM
Re:Battery?
I used six 12 volt lead-acid batteries. They were relatively cheap.
I had a two stage switch. The first switch stage was 36 volts (or three batteries in series), when the bike got moving to a decent speed I then went to the full power of all six batteries. 72 volts total. Had to stop when the batteries got too low, if you drain the batteries too low, they might not recharge or be damaged. Then you flushed your money down the toilet.
This is only a for fun project, reliability is very low. I can not depend on it for regular travel.
RE how did you put the gear on the motor shaft?
It was very difficult.
There is a freewheel removing tool.
http://www.parktool.com/uploads/images/blog/repair_help/fr-1w-freewheel.jpg
I mounted it to the axle of the motor, and used a bolt and large washer to hold the freewheel on. The bolt fit inside the shaft on the motor.
To glue I used this epoxy designed for metal.
If the fit is the tiniest bit off, the freewheel will wobble, and you cant have any wobble if you want the chain to stay on.
Motors can be very different.
You can have a high amperage 24 volt motor, or like I had a high voltage motor with lower current. Both add up to high wattage.
24 volts times 15 amps = 360
72 volts times 5 amps =360
You need a minimum of 300 watts to push the average person.
PKM says: Jun 4, 2008. 7:40 AM
I like the simplicity of using a "back wheel" for the freewheel, but this feels a little unfinished even for a "step one". If you've finished the project I suggest you write it all up as one Instructable, if you haven't then it is probably wiser to hold off on publishing until you have enough for a substantial Instructable.
mark101 (author) in reply to PKMJun 4, 2008. 3:40 PM
I have made a complete electric bike, but it broke after every run. It broke due to its complexity-too many moving parts. I decided to go simple here, as in KISS. The next step in this project will be finding an electric motor and attaching a freewheel to it.
mark101 (author) in reply to mark101Jul 19, 2008. 12:33 PM
mark101 (author) in reply to mark101Jul 8, 2008. 9:34 AM
sinfante in reply to mark101Aug 13, 2009. 11:36 AM
Hi mark !, do yo write the next step yet? thanks
mark101 (author) in reply to sinfanteAug 14, 2009. 4:39 AM
I must make one! You need four (4) things for an electric assisted bike. 1) motor including gears that propel the front or back wheel 2)battery package 3)electric control circuits 4) bike The front wheel project (here-step one) is part of the motor project. I made a battery package that fits inthe triangle frame of the bike. The battery package will be the next instructable.
mark101 (author) in reply to mark101Jul 19, 2008. 12:34 PM
sorry about not having a write up yet. I will do soon as possible.
PKM in reply to mark101Jul 8, 2008. 10:21 AM
That's more like it :) Are you going to write up the rest of the project for an Instructable? I'm quite taken with this design, if my current junker bike didn't have suspension forks I would look into doing it.
mark101 (author) in reply to mark101Jun 4, 2008. 3:42 PM
I have several DC motors from the last bike, "find" is the instruction.
theRIAA says: Jun 4, 2008. 6:42 AM
step one? k...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
