Electric Bon-tar
736
4
Posted in PlayMusic
Introduction: Electric Bon-tar
Do you want make an awesome Electric Guitar with integrated Bongos?
Step 1: Gather All Your Material & Equipment
Materials
1) Wood sheets to make the rectangular box or body of the guitar
2) Guitar Strings
3) Electric Audio Interface
4) Hooks to anchor the guitar strings
5) A plank of wood to make the neck of the guitar
Equipment
1) Laser Cutter or hot iron to make pyrography
2) 3D Printer
3) Drill
4) Wood Glue
Step 2: Build the Guitar Body
Find or make a hollow rectangular prism box out of wood (to make it a challenge I did a octagonal prism)
Step 3: Building the Body and Personalize With Pyrography
Step 1: For your bongos cut two holes the same size as the two bongos you will print with a 3D-Printer
Step 2: Place the small audio interface inside, under where the strings will be placed.
Step 3: You could either use a laser cutter to etch in a picture or you could use pyrography to draw if you want to
Step 4: Amplifier and Guitar String Anchors on the Guitar Body
Get as many hooks and guitar strings you want or you can fit and drill holes for the hooks next, tie the guitar strings to the hooks on each side
Step 5: Neck and Placing Hooks
find a small plank of wood for the neck and super glue it to the top of the box you will also need a single hook at the top of the neck
Step 6: 3-D Printed Bongos
3-D print two different sized bongos… while your bongos are printing cut two holes the same size as the two bongos in the corners of the body then super glue them inside the holes
Step 7: Gluing
For the bongos wait about three hours for the bongos to dry.
Cut a hole in the top side of the guitar big enough for the neck to fit add wood glue to the neck of the guitar and place it in the hole.
For the neck wait about twenty-four hours and let something hold it up for the amount of time.
Step 8: Attaching the Strings
Get as many hooks and guitar strings you want or you can fit and drill holes for the hooks next, tie the guitar strings to the hooks on each side of the guitar (top and bottom)
Step 9: Party Time
Plug the guitar into an amplifier and enjoy.
I would like to thank Casey,Bess, Ben, Christian, and Troy from Techshop Austin for their encouragement and help
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    3 Comments
    Very cool Jesus, keep up the good work. Once a builder always a builder.
    Troy
    It looks really nice, I bet it sounds pretty interesting as well! Thanks for sharing!
