3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electric Canoe
Electric Canoe
This is a series of 9 short videos about how I set up my electric canoe. It's not exactly instructions, but I do go through a many of the different parts. I hope that others who are building electric boats, or thinking about it, might enjoy some of my rambling. This canoe is unique in that its twin screw (two propellers), and is driven by a wii nunchuck. It's powered by two golf cart batteries. The motors are Minkota Endura 30s.
Also, Here is the original movie I made about this boat last year:
Step 1Batteries and Wiring
Give a general description of the Step
FLexiwire at mcmaster.com:
9620T22 6 Ft. 392 Deg F Hi-voltage/high-flex Wire, 10 Awg, .330" Od, 20000 Vdc, Clear
30 comments
Jul 5, 2011. 1:57 AMsilversurfer2 says:
Hi I'm trying to make a similar launch trolley.
I'd love to see a video of retrieving the canoe from the water.
Jan 25, 2011. 2:51 AMdonovanburton says:
what is the canoe winch / launcher called? where did you get it from?
Jan 8, 2011. 4:25 PMwiglaf says:
Just out of curiosity, when you were experimenting, did you ever try changing the speed and direction (forward or reverse) of the engines as a method of steering, instead of using the servo setup?
Apr 11, 2010. 10:29 PMcsorrows says:
0:05 "One long ASH piece" Made me LOL!
Mar 9, 2010. 4:22 PMel greeno says:
The european style connector block you used is known as a chocolate block here in the UK.
Nov 17, 2009. 1:42 PMtom_jones says:
 Hi
brilliant idea using an arduino and a nunchuck. could you please send me the wiichuck.h and servo1.h firles please as i am struggling to find them.
many thanks and kudos
Tom J
Aug 28, 2009. 5:51 PMJAREDB says:
You could probably mount all of the electronics in a o-ring sealed aluminum housing. You could then heatsink the motor controller to the case.
Aug 4, 2009. 8:31 PMANDY! says:
hi. I wanna put a motor on my small boat for real cheap. Any suggestions?
Aug 5, 2009. 3:40 PMANDY! says:
thanks. do you think a water pump from a car would work as an outboard? batteries are not the problem.
Aug 8, 2009. 2:15 PMANDY! says:
not yet. ill do it though. if a car water pump isnt enough, how about a power washer!
May 28, 2009. 3:53 PMpaukekino says:
great instructable. well made. seems you put a lot of thought and $$$ into project. which says you love what you do.
May 17, 2009. 1:48 PMbaudeagle says:
Hey Timothy, Great job on the construction, you have some talent there. Here is one item that you may want to consider altering. I noticed that the wires exiting the large sprocket rub on the interior of motor tubing. Eventually this rubbing action will wear the plastic coating off the wires and these will short out, especially in a wet environment. This short might have a devastating effect on your control . I would not like this to see this happen out in the middle of a big lake. One more item, since servos are quite expensive then why did you choose to use two individual servos? You may have been able to get away with one slightly larger servo and them mechanically link (with additional chain and idler sprockets) the two motors? If you want to add to your invention a small solar panel could help recharge the batteries while not in use. Baudeagle
May 12, 2009. 1:12 PMJacobAziza says:
Impressive work But... in terms of being "green", it would be even more efficient to just paddle it manually.
May 11, 2009. 12:25 PMPkranger88 says:
Good stuff, Any chance you can include the circuit diagrams? In addition, the overall cost of this project seems like it may be fairly costly given the number of parts purchased through McMaster-Carr. Can you tell us the overall project cost? Otherwise, very good. It's ironic to think though about someone choosing to troll along, rather than paddle, a canoe. It would be nice to have some resources posted where you learn about using arduinos and such. Thanks.
May 11, 2009. 1:39 PMextrordinary1 says:
I did something like this with a huge canoe a friend had and I patched a hole in it. We used a trolling motor, 100 pd thrust Minn Kota, but it was very frustrating when we got into a patch of moss! We had to paddle out of it, clean the moss off the prop. It was dark and we were running trot lines back in 96.
Currently building a tri hull electric pontoon with twin motors, and under water lighting to attract fish. Plan to use high intensity LED's to light up under the boat to conserve battery power. I'm building the hulls with the stitch and glue method making a custom design I created. There are 18 batteries onboard with a wind generator in the rear to extend the run time on the lake. The wind generator will also charge batteries while being hauled back and forth, and while sitting at home to provide surge power for my power inverters at home. Acting like a second bank of batteries for my primary wind generator at home.
May 10, 2009. 9:04 PMWeissensteinburg says:
The construction of the entire canoe impressed me, but when you got to steering it with the nunchuck...that blew me away. Keep up the great work. Rated and Featured.
May 10, 2009. 9:50 PMcool! says:
... hm it looks like you rated it a three, which seems low. Idk, it says one rating and it is at 3.05. Ill rate highly. Great work, this canoe is amazing!!!
May 11, 2009. 6:17 AMWeissensteinburg says:
As Nacho said, ratings aren't as cut and dry as they seem. Instructables uses some sort of an algorithm that evens the ratings disparity between newer and older instructables. Without it, just one person giving it a 5 would skyrocket the instructable to the top of the "sort by ratings" category. Inversely, giving it a low score will not drop you right down to a low rating. It's great because an instructable actually requires a lot of good feedback to appear as a great instructable.
May 10, 2009. 10:20 PMNachoMahma says:
. The "average" rating can be a little flaky until there are more ratings. . Find an iBle that hasn't been rated yet and give it a three (make sure it deserves a three). Last time I did that, the average went to 2.91! And mine was the only rating. . There are a few forum topics that discuss this. Search if you are interested.
May 11, 2009. 2:07 AMhuang.wencong says:
hahaha... I always have the idea to do this, but I have no money and no time to make it... Nice one anyway...
May 10, 2009. 11:13 PMmaxstevenson says:
Truly superb. 5 stars!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:timothy
Here is a site from when I Lived aboard and cruised in a wooden boat: www.slowtimes.com Current blog of randomness: growdown.blogspot.com I am trying to concentrate my dwindling hobby time only on b...
more »
